Question about Garden
What is the mixture ratio? - Garden
  • 1,514 Answers
It depends on the make. Stihl, Husqvarna and Jonsered use 40:1 mix. Use good quality 2 stroke oil for chainsaws not the cheaper stuff sold at some service stations which is meant only for boat engines.
Posted on Nov 07, 2010
Code P0171
P0171 - System Too Lean Bank 1 Share
1 ' Add Comment Possible causes
- Intake air leaks
- Faulty front heated oxygen sensor
- Ignition misfiring
- Faulty fuel injectors
- Exhaust gas leaks
- Incorrect fuel pressure
- Lack of fuel
- Faulty Mass Air Flow (MAF) sensor
- Incorrect Positive Crankcase Ventilation (PCV) hose connection
What does this mean? Tech notes
If the P0171 is combined with the P0174 code, it's very likely that the problem is caused by an intake leak. If there are no intake leaks, the next step is to replaced the air filter and clean the air flow meter. If the problem persist the front oxygen (O2) sensor may need to be replaced.
What does this mean? When is the code detected?
- Fuel injection system does not operate properly.
- The amount of mixture ratio compensation is too small. (The mixture ratio is too lean.)
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Excessive Fuel Consumption
P0171 Description
With the Air/Fuel Mixture Ratio Self-Learning Control, the actual mixture ratio can be brought closely to the theoretical mixture ratio based on the mixture ratio feedback signal from the heated oxygen sensors 1. The Engine Control Module (ECM) calculates the necessary compensation to correct the offset between the actual and the theoretical ratios.
In case the amount of the compensation value is extremely large (The actual mixture ratio is too lean.), the ECM judges the condition as the fuel injection system malfunction and light up the Malfunction Indicator Light (MIL) (2 trip detection logic).
Read more: http://www.autocodes.com/p0171.html#ixzz3t65yA9xI
Dec 01, 2015 | 2004 Nissan Titan
What is the code 171 mean on my dodge ram 1500
P0171 Chrysler - Fuel System Lean
Possible causes
- Intake air leaks
- Exhaust gas leaks
- Lack of fuel
Tech notes
Possible symptoms
P0171 Chrysler Description
P0171 Chrysler Fuel System 1 1 Lean
Sep 04, 2014 | Cars & Trucks
What does the check engine code 0173 mean for the 1999 Mazda Millenia S?
In case the amount of the compensation value is extremely large (The actual mixture ratio is too lean.), the ECM judges the condition as the fuel injection system malfunction and light up the MIL (2 trip detection logic).
Read more: http://engine-codes.com/p0173_mazda.html#ixzz3C76zKyGq
Sep 01, 2014 | Cars & Trucks
What is code p017.2 for a 2002 dodge caravan
This is the closest I've come to the code you are looking for. I searched all Dodge codes and didn't see any with a "point 2" but I found code P0172. According to EngineCodes.com your fuel mixture is probably too rich. This is what the site had to say:
Possible Causes for this Code:
- Exhaust gas leaks
Read more: http://engine-codes.com/p0172_dodge.html#ixzz35waCcFhN
This code is detected when:
- The amount of mixture ratio compensation is too large. (The mixture ratio is too rich.)
Read more: http://engine-codes.com/p0172_dodge.html#ixzz35waXE700
Possible symptoms:
Read more: http://engine-codes.com/p0172_dodge.html#ixzz35waruoIU
P0172 Dodge Code Description:
Read more: http://engine-codes.com/p0172_dodge.html#ixzz35wbfFdyj
Hope this helps!
Jun 27, 2014 | 1999 Dodge Grand Caravan
Down to the final OB code on my truck...Po174
P0174 FORD - Fuel Injection System Too lean Bank 2xicon.jpghttp://engine-codes.com/p0174_ford.htmlForum CodePossible causes- Intake air leaks
- Exhaust gas leaks
- Lack of fuel
- Incorrect Positive Crankcase Ventilation (PCV) hose connection Tech notes The codes is usually set when there is an intake leak after the air flow meter, before replacing any parts check for loose or broken hoses and intake gasket leak. On Ford some models dirty air filter, and dirty or faulty air flow sensor are the cause of the problem.
It's a very common problem for the Ford Windstar. Here a link to a web site with information how to repair:
When is the code detected?- Fuel injection system does not operate properly.
- The amount of mixture ratio compensation is too small. (The mixture ratio is too lean.) Symptoms- Engine Light ON (or Service Engine Soon Warning Light)
- Excessive Fuel ConsumptionP0174 FORD Description The Powertrain Control Module (PCM) monitors the engine Air/Fuel mixture ratio, the actual mixture ratio can be brought closely to the theoretical mixture ratio based on the mixture ratio feedback signal from the heated oxygen sensors 1. The PCM calculates the necessary compensation to correct the offset between the actual and the theoretical ratios.
In case the amount of the compensation value is extremely large (The actual mixture ratio is too lean.), the PCM judges the condition as the fuel injection system malfunction and light up the engine light.
Oct 08, 2012 | Cars & Trucks
Code 0171
Here is the definition.
Causes could be a faulty O2 sensor or a fuel problem.
P0171 CHRYSLER Description With the Air/Fuel Mixture Ratio Self-Learning Control, the actual mixture ratio can be brought closely to the theoretical mixture ratio based on the mixture ratio feedback signal from the heated oxygen sensors 1. The Engine Control Module (ECM) calculates the necessary compensation to correct the offset between the actual and the theoretical ratios.
Read more: http://engine-codes.com/p0171_chrysler.html#ixzz24c6wxqAd
Aug 25, 2012 | Chrysler Town & Country Cars & Trucks
I have a code reader and the code is P0171 P0174 System too lean. what makes the system too lean?
P0171 - Fuel Injection System Too Lean Bank 1
Possible Causes:
- Intake air leaks
- Front Heated oxygen sensor may be faulty
- Injectors may be faulty
- Exhaust gas leaks
- Lack of fuel
- Mass air flow sensor may be faulty
- Incorrect PCV hose connection
P0174 - Fuel Injection System Too Lean Bank 2
Possible Causes:
- Intake air leaks
- Exhaust gas leaks
- Lack of fuel
What Causes These Codes: Fuel injection system does not operate properly. The amount of mixture ratio compensation is too large. (The mixture ratio is too rich.) The Powertrain Control Module (PCM) monitors the engine Air/Fuel mixture ratio, the actual mixture ratio can be brought closely to the theoretical mixture ratio based on the mixture ratio feedback signal from the heated oxygen sensors 1. The PCM calculates the necessary compensation to correct the offset between the actual and the theoretical ratios. In case the amount of the compensation value is extremely large (The actual mixture ratio is too lean.), the PCM judges the condition as the fuel injection system malfunction and light up the engine light. The codes is usually set when there is an intake leak after the air flow meter, before replacing any parts check for loose or broken hoses and intake gasket leak. On Ford some models dirty air filter, and dirty or faulty air flow sensor are the cause of the problem.
Jan 16, 2011 | 2000 Ford Explorer
Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
May 26, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
25cc trimmer gas ratio mixture
the correct ratio is 50-1 mix
Jul 01, 2009 | Homelite Garden
Garden Logo
75 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
