Question about Bosch SHE4AP06UC Dishwasher
Our brand new Bosch she4ap06us dishwasher is stuck in the "quick wash" cycle. I have followed directions in the mediocre manual for canceling a cycle. It is still flashing but when I turn the on/off and start switch you can hear a clicking in the dishwasher. On-line customer service was unable to find an answer! It will be a couple of days before Lowes can send out a repair person.
here2helpBSH
  • 27 Answers
SOURCE: Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Posted on Mar 19, 2009
SOURCE: my bosch dishwasher whistles when on washing cycle
it is your wash pump
Posted on Apr 16, 2009
SOURCE: Bosch Dishwasher wont drain
Crazy! I have the EXACT same problem....sounds like it wants to drain...but won't ...Water has been stuck in the bottom for days now
Posted on Jul 18, 2009
  • 122 Answers
SOURCE: I have a SHU5316UC dishwasher. How to cancel and
hold down scrub wash and the delicare or the 2nd one past scrub wash, for 3 seconds.
Posted on May 05, 2010
  • 414 Answers
SOURCE: How do I run Test mode for a Bosch SHU5302UC
Don't hold me to this but I believe to reset during a cycle you press simultaneously the two buttons with a dot under them (2nd in from the left and 2nd in from the right) 0.01 or 0.00 comes on the screen and the pump will run. To run a test cycle turn machine of, press and hold the same two buttons and turn machine on whilst holding them in, the machine code should show in the display (usually a number in it's 20's), release these two button and then immediately press them again, this should initiate the test cycle. The d/w should now run thru a test cycle. If no fault is detected the display will show 0 or 1. If anything else, please repost and I will try to let you know what the fault code represents. test sequence is usually is as follows.
Pump, fill, circulation motor, dispenser (listen for it to open), heat to 65 degrees, regeneration flush, intermittent pump, sensor recalibration (if the d/w has any), alternate fill/pump, pump, finish. Take approx 10-15mins to complete.
Hope this helps, pls feedback or reply if unknown code appears.
Posted on Jul 12, 2010
Bosch Logixx won't start - Stuck on "Close the door" even though door is closed.
Open the door, look along the top stainless on the door and you should find the ENr number (model number) etched into the stainless, may need to give it a wipe and look at an angle to read it. Post the ENr and that should help with diagnosis.
Mar 15, 2013 | Bosch 24 in. SGS69L02 Logixx Built-in...
My Bosch dishwasher fills with water but when it comes to the wash cycle it does nothing.
If your dishwasher is brand new, then call Bosch service as they can repair it under warranty.
Feb 26, 2012 | Bosch Dishwashers
When I press the start button, Bosch dishwasher (model SHY56A 05UC) just keep running the motor pumping the water out of dishwasher, irrespective of: 1) the wash cycle it is on, 2) whether the door is...
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Nov 26, 2010 | Bosch SHY56A02 / SHY56A06 Built-in...
After the wash cycle dishwasher beeps
Hello, welcome to FixYa. While I don't have access to my PC files at the moment as I am on my iphone, I believe this is the procedure for most B/S/H/ built dishwashers ( that means Bosch, Thermador, Siemens and Gaggenau ). To Enable or Disable the Cycle Completion Signal... 1. Open the door, hold down the ?Quick Wash? button and simultaneously turn the Dishwasher on. The ?Quick Wash? light will blink (program mode). 2. While the light is still blinking, push the ?Quick Wash? button. ? If the machine beeps, then the Cycle Completion Signal has been enabled. ? When you push the button again and it doesn?t beep, it means that the Cycle Completion Signal has been disabled. 3. Turn the Dishwasher off to take it out of program mode. I hope this answer's your question. Thank you for choosing "fixya". Please rate the solution favorably if indeed it was helpful, if not please let me know. Good luck. macmarkus :)
Jul 13, 2010 | Bosch 24 in. SHV4303 Built-in Dishwasher
Rinse agent cycle
Visit Bosch web site and get a user manual. Or tray the authorized service center
May 02, 2010 | Bosch 24 in. SHU66C05 Stainless Steel...
Bosch shu4006uc dishwasher timer problem
REPLACE YOUR MODULE. IM A OLD BOSCH TECH. POST 4 THUMBS FOR THE INFO THANKS
Feb 08, 2010 | Bosch SHU4006 Dishwasher
How long is wash cycel in dishwasher. dishwasher does not seem to advance beyond the wash cycle
Normal wash cycle is as follows..
Wash1 8 min
Rinse1 10 min
Wash2 21 min
Rinse 10 min
Rinse 12.5 min
Dry(hot or cool) 23.5 min
Total of 85 min
thats just a normal cycle. Pots and pan cycle is of course longer
Nov 13, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
I have a brand new Bosch SHX45M built-in dishwasher. I have run it on a short cycle and a full cycle. The dishes are dripping wet! I have checked the rinse agent dispenser and it is full. Any...
consult your manual for starters, common problem especcailly with new machines, you may be selecting an energy saving cycle with a no heat dry option. just give a quick look
Mar 13, 2008 | Dishwashers
Dishwasher not drying
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
Nov 12, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Bosch SHE4AP06UC Dishwasher Logo
110 people viewed this question
Top Bosch Dishwashers Experts
jimorris77
Carmen Mikulic
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
