Question about Lasko 2152C Hassock Floor / Box Fan
Need to Open Older Lasko Hassock Fan.
Ribbon wrapped around axle of older Lasko hassock fan. How can I open the fan to untangle this mess? The screws at the bottom of the fan look as if they'd disengage the motor and fan assembly from the housing but I wouldn't be able to pull it out because the opening is too small.
Info from bottom of fan: E20739, Type HA-12F, Style G, Listed 154C.
Thanks!
  • nlsmall Jun 27, 2008
    How do you clean the E20739 model of Lasko Ionizing Tower
    Fan?
    Huge dust bunnies inside fan remain even when I tried to vacuum
    outer surface with a brush attachment unsuccessfully,  There are two screws at the top - four screws at the bottom
    on the back cover of the fan, but they cannot be moved with a screw driver.  Are they supposed to be removed to
    clean the fan?  I am experiencing
    very severe asthma and need to clean the product ASAP.   Please help.  Can't find a user manual on-line.
  • Anonymous Jan 03, 2009
    I have it down to one screw at the top that will not unscrew with a phiillips screwdriver or any type of screwdriver I have tried.
    The four screws at the lower back of my fan came out, but the one at the top does not accept any pattern of screwdriver I have tried. I am considering using a drill bit to destroy the screw but the risk is that the metal filings can get imside the circuits and damage them.
5 Suggested Answers
mrboo747
  • 24 Answers
SOURCE: Lasko E20739 Fan
Replace the motor
Posted on Aug 27, 2008
mrboo747
  • 24 Answers
I would love to tell you yes, but I ended up buying new fan.
The common wire was broken, buried in the windings and no way to repair without
damaging the windings.
Could not find anything on line.
Sorry,
mrboo747
aka Gary C
Posted on Nov 11, 2008
sawdust46694
  • 398 Answers
SOURCE: I ahve a hassock fan from 1952 that needs a new blade-
http://www.laskoproducts.com/fans/model_2152c.html
hope this helps you.
Sawdust
Posted on Aug 15, 2009
SOURCE: Cleaning
Model E20739: The entire back comes off to expose the fan blades after removing two screws. Just unplug the unit. On the back of the unit near the top is a recess that acts as a carrying handle. In that area you will see two large silver-colored screws. Remove these, grasp the back of the unit and push down on it as you pull it away from the body of the fan. You may have to wiggle it around a little to free it.
Posted on Sep 03, 2010
How to disassemble lasko hassock floor fan
I'm assuming you want to open the fan up to give it a thorough cleaning. This is how I got one open. First things first, make sure it's unplugged. No need to risk zapping yourself of accidentally turning it on when your fingers are in range of the fan blade...
Turn the fan upside down. There are four very long Phillips screws concealed by long plastic sleeves that cover the shafts of the screws, with the ***** heads covered by the rubber feet at the bottom of the unit. Pop out the rubber feet, then loosen the screws (there will likely be an alarming snap when they break loose). The two-piece top of the unit will come loose. You can then remove the screws and the plastic sleeves that hide the screws.
Turn the unit right side up and remove the fan blade. The nut holding the blade on is reverse thread, so "lefty loosy, righty tighty" will not apply--turn the nut clockwise to loosen. Remove the nut and lock washer, then pull the blade from underneath the hub (it'll take a bit of force to pop it off.
The wire from the motor to the speed control switch connects the base to the cylindrical center portion of the unit. To separate the center portion from the base, pull the knob off of the shaft of the switch and remove the ***** holding it in place. The switch can then be disconnected from the center piece. I'd put the ***** back into the switch to keep it from disappearing.
The motor can be removed from the base by removing the three screws holding it to the base from underneath, but unless you're looking to replace the motor, you shouldn't need to do this.
Put it back together by reversing the disassembly process.
Jun 16, 2014 | Lasko 2152C Hassock Floor / Box Fan
BROKEN BLADE
Replace Fan, order part from Lasko
Aug 03, 2008 | Lasko 2152C Hassock Floor / Box Fan
Looking for orginal gray replacement 18/2 16/2 cords for 1950's ge fans?
There's a couple on eBay up for parts. There unusable but the parts are still good. I'd look into that.
Jan 28, 2013 | Computers & Internet
How to open a lasko 3520
how to open lasko 3520 and change the fuse
Aug 31, 2012 | Lasko 3520 20-Inch Cyclone Fan
How do i open the fan it doesnt have any screws n it stop occulate
remove the screw on the sides, then CAREFULLY remove the top of the grill, remove the screw of the speed control, then you finally find two screws to remove the back of the fan...
Jul 25, 2011 | Lasko High Velocity Space-Saving Blower...
My lasko tower fan gets power n wont blow air
The bearings on the motor are dry and need oil. It's really not made to be oiled, but you may be able to take it apart and get some oil to the bearings if you want to mess with it.
Jul 22, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
Not blowing enough air
the back top of the fan pry open.
then you will see screws
Jul 01, 2009 | Lasko High Velocity Space-Saving Blower...
How To Clean
On the back of the fan there are 6 recessed phillips head screws around the circumfrence of the fan. You must use a longer screwdriver as the screws are set in a couple of inches.
The two screws on the bottom are a little harder to see.
There are also two clips on the sides front cover. Squeeze on the sides gently to release these.
Jun 28, 2008 | Lasko 3440 Wind Tunnel Floor / Box Fan
How to open the casing
Question does the base underside have any removable screws that you can remove? If so, start from there. The top part of the fan should pop off with a screw driver. Exposing the screws securing the shell of the fan.
May 09, 2007 | Lasko 2115 Wind Tower Fan
Lasko 2152C Hassock Floor / Box Fan Logo
361 people viewed this question
Top Lasko Dryers Experts
Craig Butler
Craig Butler
Shehu Pro
Shehu Pro
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
