How can i speed up my computer startup, how do i get into msdos sartup
  • 2,386 Answers
Un-install the un-necessary programs from your computer, and also clean the startup items from the computer.
Upgradation of RAM will also increase the system speed and fresh installation of operating system will also do the same job.
Posted on Nov 07, 2010
Computer is not booting on
can you hear hard drive? do you get anything in msdos startup screen? if not then check power i.e. plug, fuse and your power unit in pc case
Jan 12, 2013 | Microsoft Windows XP Professional for PC
How can we create a start up disk?
If you want a MSDOS start up disk. 1. Go to Explorer 2. Locate a:/b: drive (floppy disk drive) 3. Format it and check the option to create MSDOS start up disk. If you want CD/USB XP startup disk. 1. It is free downloadable online.
Mar 12, 2011 | Microsoft Windows XP Professional
When ever my computer shutsdown it goes to startup repair. sometimes it works itself out. but every morning i wake up to it with the startup repair screen on
Sartup repair is some thing that tries to fix the OS issues...
Normally its of no use.. Its better if you can reinstall the OS after getting windows and taking backup of all your important files..
It should be vista or win 7 that you have on the computer then tap F8 when the computer turns on and then you will be able to see the advanced boot options.. Select repair my computer.. In the repair my computer screen select the dell factory image restore...
Your computer will go through the installation and it will be up and running...
If you are not able to do this then try to reinstall the OS with the help of a OS CD..
Sep 28, 2010 | Dell Studio 17 Laptop
I can't get out put . My pc have ''system application error. An instant of tomcate5.5 is already running'' how i solve it?
GO TOSTART THEN CHOOSE RUN THEN TYPE MSCONFIG AND PRESS ENTER THEN GO SARTUP PROGRAMS BUTTON REMOVE THE CHECK BOX ON THE TOMCATE PROGRAM  AND RESTAET THE SYSTEM             STARTUP PROGRAMS F
Jun 09, 2010 | Computers & Internet
I rolled back my laptop to a later date, when it was completed it restarted with a blank screen. how can i fix the problem?
I am assuming you are using Windows Vista:
Turn the laptop on and press F4 at sartup. Choose safe mode. Iff it does not allow you to boot in safe mode then choose, fix computer in advanced options. Do not do a factory install unless you absolutely have to as this will delete all files in computer. Windows Vista has implemented some really good startup tools and this should help you get your computer back.
Anytime you rollback and a security pack is rolled back, you get these problems with Vista. It has something to do with the Antivirus clashing with Vista.
Also, try starting the computer and then shutting down a couple of times in a row and then let it sit there for 30 minutes to see if it comes back on. Patience is the key here....Hope this helps!
Sep 20, 2009 | HP Pavilion dv6000z Notebook
Computer will not boot or respond
Beeping upon startup is generally a problem with memory ..
Mar 13, 2009 | HP Compaq dx2000 PC Desktop
Motherboard problems
hi im josh in cebu phils. since that is all fan that works.there is no current that goes or pass on your hardware. all you have to do is check the powersupply connection to the motherboard.both 16 pins and the 4 pins 12 volts. if still change your motherboard. good luck
Oct 29, 2008 | Mach Speed (MSNV-939) Motherboard
Slow connect speed--
ya a idea would be to try and change your ip address might help connect a little faster
goto msdos promt
type in ipconfig hit enter
then type in ipconfig/renew hit enter
pls let me know ifthis helped if not let me know
Jul 14, 2008 | Actiontec (EX560LKA) Cable Modem
Gone into safe mode cant change mode?
1. Click Start, point to Find, and then click Files or Folders. 2. In the Named box, type msdos.sys. 3. In the Look In box, click the drive on which Windows is installed (usually drive C), and then click Find Now. 4. Right-click the Msdos.sys file, and then click Properties. 5. Click to clear the Read-Only and Hidden check boxes to remove these attributes from the Msdos.sys file, and then click OK. 6. Right-click the Msdos.sys file, and then click Open With. 7. In the Choose the program you want to use box, click WordPad, and then click OK. 8. Do one of the following: • Delete the BootSafe=1 line.
-or- • Change the value in the BootSafe=1 line to BootSafe=0. 9. On the File menu, click Save. 10. Right-click the Msdos.sys file, and then click Properties. 11. Click to select the Read-Only and Hidden check boxes to set the attributes for the file, and then click OK. 12. Restart your computer.
Apr 16, 2008 | Video Cameras
Computer startup problem
go to the recycle bin then right click with your mouse the file you deleted then click restore. the file will be restored.
Jan 19, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
41 people viewed this question
Alun Cox
k24674
