Hello there From what you have said it sounds like you have the DISK DRIVE READ ERROR The main causes are Hardware failure, overheating or wear & tear. You may need to perform simple maintenance, clean or in some cases adjust settings. To get the best advice on where to start I recommend a GOOD REPAIR GUIDE, From this you can fix the problem at home and avoid any large repair bills. Its easier than it sounds when you have help from the guide. I used Gamer Fix to get the best guides The other solution would be to send the console off to its manufacturer, This is free if your still in warranty. If your console is out of warranty then the usual price of repair is $150 I am Glad I could help and You can help others by rating this Post or leaving a comment. Peter Fix
Many thanks
