I used InsydeFlash.exe to flash the BIOS on my Acer Aspire One - KAV10 from V1.13 to V0.3310 (as shown on the flasher control panel). It showed erasing and writing and then hung for over an hour. Couldn't get a reset using any keys or the power button so I unplugged the battery and tried restarting. NADA - total brick, no lights, nothing. What to do next Gary
  • 154 Answers
SOURCE: Hello! Recenty i bought a
If it has warranty period u can give it to company without taking risk..
Posted on Jul 06, 2011
SOURCE: Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Posted on Jul 18, 2007
techman
  • 3130 Answers
SOURCE: tv won't turn on
Your problem could be the Convergence board is loading down the power supplies and will not let the TV set come on, or the power/deflection board, part number AA94-08574A, or the STR type regulator IC, part number AA13-00105A. If you locate the convergence board, unplug the connectors, and see if the set will come on. if the set does come on, replace both of the STK convergence IC's at once. The part numbers for those IC's are STK392-40. You can get the original replacement IC's from MCM electronics for about 15 to 16 bucks a piece. Do not use the less expensive STK IC's as they are not the same. the replacement IC's should have the name of SANYO printed right on the face of the IC's. Good Luck
Posted on Jul 22, 2007
  • 24 Answers
SOURCE: rundll32.exe
check immediately for any virus (especially w32).your rundll32.exe files in the /windows/system32 is missing or affected.try replacing the same from some other computer.or repair the windows using the CD
Posted on May 24, 2008
compguy1018
  • 17 Answers
SOURCE: Acer Aspire One 6 Cell Battery Problem
you got a bad battery. If your old battery works fine, and the new one wont hold a charge, Take it back to the store and get another.
Posted on Dec 29, 2008
We have an Acer One Series KAV10. My wife has user rights while I have administrator rights. I added both accounts and passwords but now the administrator password that I entered does not let me acce
Try booting in safe mode ( restart the computer tap on the F8 key repeatedly until start menu comes up. Choose safe mode and when login screen appears choose " administrator" account instead of either the accounts you created, use the password to log on as administrator than go to control panel user accounts and check you settings
Feb 05, 2013 | Acer Aspire One Kav10 Netbook
Only a black screen, no indicator lights are nurning
I am using an Acer and it happened to me thrice. It is an easy fix.
Acer Aspire One BIOS Recovery The Acer Aspire One has a built-in BIOS recovery routine, which can boot into a minimal BIOS environment via a special boot block to re-flash the BIOS, even if the system does not pass POST and does otherwise not boot anymore. This procedure is also known as Crisis Disk.
First format an USB flash drive with FAT. It does not need to be bootable.
Download the latest BIOS, and extract all files. Put both FLASHIT.EXE and the BIOS file with FD suffix in the root directory of the flash drive. The files must not be in a folder. Rename the BIOS file to ZG5IA32.FD before proceeding. It only works with this exact filename.
Turn the AA1 off, and verify both battery and AC adapter are plugged in.
Press Fn and Esc simultaneously, keep them pressed and press the power button. Release Fn+Esc after a few seconds. The power button starts blinking at this point. Press it once. The AA1 will now access the files on the flash drive and initiate flashing the BIOS. After a while the power button stops blinking, and the AA1 reboots by itself. Wait patiently.
If it doesn't reboot, but keeps blinking, wait at least a few minutes before turning it off, and try again. Good Luck
Jan 24, 2011 | Acer Aspire One PC Notebook
Locked Laptop
This is from a factory repair and maintenance manual for Acer Aspire Laptops. It may work for you.
Forgotten Hard Disk Password
When the user keys in the wrong password three times, an error message appears. The user must now reset
the password.
1. Make a note of the error code that is displayed with the error message.
2. Run unlock6.exe from the DOS prompt in the following format:
unlock6 XXXXX 00
(XXXXX = HDD password error code, 00 = CRC base - default is 00)
3. Select Upper case ACSII Code from the screen that appears. The HDD master password is displayed.
Make a note of this password.
4. Reset your system. When the Enter Primary Master HDD User Password prompt appears, enter the
password you made a note of in step 3.
Resetting a BIOS Password
The user can reset a BIOS password using the clnpwd.exe utiility.
1. Copy clnpwd.exe to a DOS boot up disk (or flash drive).
2. Boot your system in DOS mode.
3. Execute clnpwd.exe from the boot up disk (or flash drive).
4. Press 1 or 2 to reset the required password as shown on screen.
5. A confirmation message appears when the process is successful.
May 24, 2010 | Acer Aspire 5315-2713 Notebook
My KAV10 acer is set into franch,how would I change it to english..also when I try an use internet exploir it just shout off the web not the whole laptop
Go to start, control panel, "Date, Time, Language, and Regional Options"
Select Regional and Language Options
Use the drop down to select your "English" type (US, UK, etc.). Click Ok
Feb 19, 2010 | Acer Aspire One D150-1587 Netbook
Forgot the password of bios of acer aspire 5584 wxmi model: zr1
1. Go and download the bios file - ftp://ftp.work.acer-euro.com/notebook/asp.../bios/v1.06.zip
2. There should be a file call AG1A-106.EXE inside Alviso folder, just extract this file to the location you like.
3. In windows, use cmd (Command Prompt) to run this application.
4. The syntax should be ---- AG1A-106.EXE /ldcmos /reb -----
5. It may take 1 minute to load up, when it appears, just flash it.
6. Computer will restart after flashing and password should be cleared.
7. Don't forget to set back the BIOS settings if required.
Hope this helps!
Please rate my response!!
Jan 29, 2010 | Acer Aspire 5500 5570-2609 Laptop
How to install the bios in acer aspire one?
u cannot install BIOS...it's part of the COMS chip in ur laptops motherboard....u can FLASH it but it can be done only using certain tool sets...u need a BIOS Flasher to do it
Jan 09, 2010 | Computers & Internet
I have Problems with Acer Aspire One AOA110-1113 Blue Intel Atom N270 8.9' 512MB Memory 8GB. it shows no signal on the screen. no light no cursor no nothing. only sound. and no physical damage. it just...
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a dikette won't work with a usb stick
May 17, 2009 | Acer Aspire One AOA110-1113 Netbook
Battery will not charge
Power reset the unit, unplug it pop out the battery and hold the power down for a minute, put the battery and ac adapter back in and start her up, the mobo was probably still holding power when the battery died causing a "hiccup"in the system, this should resolve or at least help a little
Jan 23, 2009 | Acer Aspire One PC Notebook
Computers & Internet Logo
958 people viewed this question
David Payne
David Payne
