Question about Kenmore Elite HE5t Washer
Washer is shredding clothes - Kenmore Elite HE5t Washer
WHIRLPOOL TOP LOAD WASHER LGR7646 SHREDS CLOTHES
Hi, mfels. My name is Emily and I am a representative of Whirlpool, we're very sorry to hear about the difficulty you've been experiencing with your washer. Below are links to our use and care guides, parts list, troubleshooting, and service. We hope this can help.
http://bit.ly/112Lu7q
http://bit.ly/zkfnZd
http://bit.ly/yLv4Z5
Sep 13, 2013 | Whirlpool LSR7333 Top Load Washer
Clothes are being shredded in washer
it sounds like you have a bent piece of metal round the drum you will have to make sure the drum is empty with your hand very slowly move it round the whole drum if you find it with a small hammer don't hit it heard OK just tap it till its not going to shred your cloths OK if you don't find any thing you will need to look at the paddle in the drum to make sure there not Brock or moving OK hope i can help
Oct 22, 2012 | Maytag Washing Machines
My Kenmore Elite HE3 Mod 11044832 202 started making LOUD knocking noises during final spin cycle, then started to smell like something burning. Whit placis shreds in the washer.
the plastic is the drum has dropped so its eating a way the plastic on the back of the drum so no not worth fixing the mould is an easy fix just soke a cloth with neat bleach and leave over night make sure you do a rines after woulds as you don't want bleach on your cloths ok
Oct 21, 2012 | Kenmore 44832 Front Load Washer
My Adora front load washer is shredding my clothes. It doesn't happen every load but some of my shirts are getting ripped/torn. There doesn't appear to be anything sharp in the tub. Anyone know what is...
Had that problem for a while with mine, It seemed to do it once in a while....then we stopped putting our jeans/pants in with the rest of the colors. and it stopped happening. we was our pants seperatly with them zipped and buttoned now, have not had anymore ripped or torn clothes since.
Hope it helps.
May 13, 2010 | GE Washing Machines
Shredding timing belt landrover discovery
U have a defective tensioner pulley or idler pulley due to a failed bearing
Aug 02, 2009 | 1996 Land Rover Discovery
Washer is ripping my clothes
yep, I have that problem too. My son's winter coat got wripped to shreds.
Apr 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE Adora Frontload Washer shredding clothes
We were having the same problems with ripped clothing and longer cycles. Our rubber seal by the door has ripped twice now causing massive amounts of water to run out. I learned through other threads that many people are having these problems and was told that zipping up zippers and turning jackets and clothing with big heavy stuff on them in side out to protect from ripping the clothing and the rubber seal. I removed the panel on the front bottom of the machince and there is a small gray cover that housed the coin trap. Mine was clogged and once I cleared that out, my cycle times got better. I hope this was somewhat helpful. We definitely won't be purchasing another GE front loader!!
Mar 29, 2009 | GE WSXH208A Front Load Washer
GE Front load washer clothes coming out with holes/torn/even shredded
Metal inside washer drum may be faulty and causing tearing of clothes (run your finger around the inside when empty and you will feel where it snags). Had same problem, only got worse and ruined many expensive t-shirts! Replacement of drum is required and is extremely costly if not under warranty!
Jun 05, 2008 | GE WSXH208A Front Load Washer
Torn clothes
I've had this probelm as well and I suspect it to be the gasket that goes around the opening of the washer in your case(s). Mine is torn nearly halfway around and I believe the clothes are getting caught there. I called in for service two weeks ago but they keep telling me that the part is on backorder. Not a great problem to have with two toddlers!
Nov 04, 2007 | GE WSXH208A Front Load Washer
Kenmore Elite HE5t Washer Logo
174 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
