Question about Mitsubishi Office Equipment & Supplies
Mitsubishi hc3000 wont start
I have a mittsubishi hc 3000. It worked great but when I turned it on today it started as usual but the fan sounded funny and made a clicking noise, The status light and the power lites were both green. The fan slowed down and then speeded up again several times. then the power lite turned red and the status lite flashed on and off and then stopped and unit shut down. The bulb never lit. I have less than 1000 hrs on this unit and bulb. Whats the problem? Thanks Gary
  • 758 Answers
When the power button flashes red and shut down that means the system is getting hot... Follow the procedures below to solve the problems..
  1. Press LAMP POWER ON/OFF button to OFF.
  2. Check the air filter for dust accumulation.
  3. Remove dust with vacuum cleaner (see Air Filter Care and Cleaning.)
  4. Press LAMP POWER ON/OFF button to ON.
If the TEMPERATURE WARNING INDICATOR still continues to flash, call your manufacturer
I hope that helps
Please rate accordingly
Thank you
Computerrep
Posted on Jun 29, 2008
    Guru:
  • 1,894 Answers
This is a problem in your power board.
thi unit is getting OFF due to heating problem
I have a Fedders Window Air conditioner, model A2008F2BG. It was working great until today. Now it comes on but the fan wont blow much air. Any ideas?
I believe that is an older window unit. I don't know how difficult it is to get to the fan, but I would check to see if it can be cleaned, then see if there is any insulation or anything that is blocking air flow. I am assuming the filter is clean?
Aug 01, 2016 | Fedders Heating & Cooling
Mitsu hc3000 problem "red-green status light blinking and no input"
Heres what the manual says about REd / green lights
Unplug the power cord from the wall outlet and contact your dealer
And also this:
Check that the lens cap is removed.
It may take about one minute for the lamp to light up.
The lamp fails to light up on rare occasions. In such a case, wait for a few minutes
and then try again.
If the projector was turned off before the lamp was cooled down suf? ciently last time,
the fan may start rotating and the POWER button may not work after the power cord
is plugged. After the fan stops rotating, press the POWER button to turn back on the
POWER indicator.
Check that the intake vent is clean.
Set SCART INPUT in the FEATURE menu to OFF. (See page 25.)
Check that the lamp cover is closed. (See page 33.)
Check that the cables connected to the external devices are not broken.
When an extension cable is being used, replace it with the supplied cable for check. When
images are displayed correctly, add an RGB signal ampli? er to the extension cable.
Check the operation manual of the video device for its connection.
Mar 14, 2008 | Mitsubishi HC3000U Multimedia Projector
Fan noise
HELLO!!
BASICALLY WE CLEAN THE CPU FANS REMOVING THE CPU FOR MINIMIZING NOISE ... CAN U TRY THIS ???
Jan 03, 2008 | Mitsubishi HC3000U Multimedia Projector
Denon avr-1312 receiver and mitsubishi hc3000 projector - Video keeps dropping out
Hi, it could be a number of things, go to your browser type in the model followed by support, look at there info, is there enough life in the bulb? if it were mine i would clean the shutter and go on from there but try that what i have said example >>.denon avr-1312 support << hope this helps :)
Nov 30, 2013 | Mitsubishi HC3000U Multimedia Projector
My daughter was driving her 08 Eclipse, it just stopped running on the highway. It wouldn't start back. The starter wont engage now. Starter motor just turns. She said it made a funny noise before it quit...
start looking at the starter, verify its either working or not and go from there. is the engine turning over? is the cam turning? if not then the timing belt is broken and possible engine damage.
Oct 03, 2009 | 2008 Mitsubishi Eclipse
My 1989 chevy camero, automatic, v8 305 engine, is acting funny. Brand new battery, water pump, brakes, tires, and trani mount. Has some wiring problems. Aparrently is wired backwards. It over heats alot....
CHECK YOUR CLUTCH COOLANT FAN IT SHOULD HAVE RESISTANCE WHEN YOU TURN IT WITH YOUR HAND.IF ITS LOOSE AND WOBBLEY.NEED REPLACING.THAT CAN CAUSE CAR TO OVERHEAT.ALSO IF YOU LIVE IN HOT CLIMATE.YOU NEED 50/50 ANTIFREEZE AND WATER.TOO MUCH WATER CAUSE ENGINE TO OVERHEAT.YOU NEED ANTIFREEZE MIXTURE TO RAISE BOILING POINT.TO HELP ENGINE COOL BETTER.NOW THE STARTING PROBLEMS.CLEAN BATTERY CABLES IF CORRODED.IF THEY ARE OLD BEEN ON CAR A WHILE REPLACE THEM.IF BATTERY CABLES IS GOOD. HAVE STARTER CHECKED REMOVE IT TAKE IT TO AUTO ZONE OR ADVANCE AUTO PARTS.SOUND LIKE A BAD STARTER HIT IT WITH HAMMER AND IT CRANK.
Sep 29, 2009 | 1989 Chevrolet Camaro
I have a LVP-HC3000 DLP projector. I bought it new, I use it for sports and movies. It is 2.5 years old but it has <1500 hours on it. I do run it in "brightest" mode as do not have great...
the bulbs arent hard to change but run about 100.00 have you checked the filter on it to see if it needs cleaned> its either on the back ot the side of the machine.i have one here too that i use and never an issue with it
Oct 15, 2008 | Mitsubishi Televison & Video
650 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
