Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Color splotch when TV is powered on, then TV powers down automatically
When powering on the TV, there is a color splotch that is in the lower middle and goes to middle of screen. After a few seconds the screen turns pinkish and a second later there is a flash of color in the middle of the screen then the TV automatically powers off.
  • 927 Answers
Good Day;
It is very common for this model from what you spoke. If you handy return to me, Big Irish, and I will continue to help you.
99.9 % of the time of what you stated it sounds like a shorted CRT, picture tube. I have seen hundreds.
First, call the manufacture and complain about your concern and ask them for a CONCESSION because your tube has gone out.
2.If that does not work ; call a factory authorized service dealer to confirm problem and get an estimate, then return ti #1.
Good Luck, Day, Big Irish. I hope I helped.
Posted on Jun 18, 2008
What the voltage value of zener diodes? (D825, D826 red,red,gray) and D823 (red,yellow).
This table is the information used by MOST diode manufacturers that use color banding on diodes. Most manufacturers stamp the ID right on the diode but some do use color banding as the method of identification. For purposes of alignment, the side with any color band closest to either side of the diode is the equivalent of the left side of this table. The three examples in the table when associated with the values in the lower table, are identified as 1N64E for the top diode, 1N452G for the middle diode and 1N4762 for the bottom diode.
See the color coding
25789975-o5icj23xic0ud0c1fg3qznri-3-0.jpg http://electronicshelponline.blogspot.com/
Jul 20, 2015 | Panasonic Televison & Video
My Samsung HLP-4667W DLP TV has no picture when I turn it on.
The color wheel can be ruled out by looking at it---it faces the lamp and can be seen---look to see if any segments of the wheel are missing or if the wheel is totally shattered.
Other than the wheel I am concerned by "blue splotches etc" as it might be a DMD gone bad. Look at the attached photo and the color wheel first.
May 03, 2012 | Samsung Televison & Video
According to the description, the color wheel went out. Loud humming noise, color distortion. I got a color wheel and first, by mistake opened the back of the screen, tilted it out a little way and...
did you install the correct color wheel? Most of the samsungs had retooled bearings in some color wheels and often a jumper has to be installed for the color wheel to work properly. Your wheel should be a BP96-01103A another thing that can happen is the thin brown ribbon cable can get plugged in backwards and will prevent the color wheel from working also. That ribbon only has contacts on one side of the ribbon. I would double check that if the correct color wheel was received for your model.
Aug 08, 2011 | Samsung HL-R5668W 56" HDTV
In the middle of watching tv, the screen just turned blue. We went to change the channel and as soon as we did, it turned blue. It doesn't have sound either.
Blue color production circuit is fine. Red and green color circuit not getting power, the same power also goes to sound unit. if that is rectified, issue would be resolved.
Dec 17, 2010 | Maxent Televison & Video
No power
Check the color wheel, take out lamp and look at color wheel with flashlight see if moving, make sure you tape down or up lamp door switch. If color wheel turns or not? Have same tv my probelm was the color wheel. cost around $70 easy to install>>>>
May 31, 2010 | Samsung HL-S5686W 56" HDTV
Blue/Yellow Splotches on screen
It will be 12 appliance years old in October. Not much justification for trying to repair it.
Mar 23, 2017 | Sony KDF-E50A10 50 in. LCD HDTV
HLN5065W picture turns black and white and shuts down
Sounds like your color wheel may be at fault. Do you ever hear any unusual noises coming from the rear of the TV? Color Wheels usually make a humming sound as they go bad. This is because the tiny bearings in the color wheel motor have begun to misshape from use and heat. This is a known issue in this TV! Expect to spend $300-500 to have this serviced by a service company. If you have the right stuff, you can do it yourself. If you search the web, you'll find a color wheel for this TV for under $100, but installation can be tricky.
michtech
Feb 16, 2009 | Samsung HLN5065W 50" Rear Projection...
Power
Unfortunately it sounds like your problem is down to failure on the DTV main board, this is a common problem.
http://forum.ecoustics.com/bbs/messages/2/429280.html there's more information here and the forum operator can also sort out repair for you.
May 15, 2008 | Vizio L37 Television
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
74 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
