Question about Casio Wave Ceptor WV57HA-1AV Wrist Watch
I want to set my watch to the correct time - Casio Wave Ceptor WV57HA-1AV Wrist Watch
How to set the day of the week
here is your manual (I think)
http://cdn.invictawatch.com/invictawatch/website2014/webroot//uploads/manuals/2-8040n-pdf
If not, their site is pretty good.
http://invictawatch.com/service/view-the-instruction-manuals
nice video but as good as a chocolate teapot!
https://youtu.be/iv0aXQNH4yY
anyway, here is your info
Invicta Watch Setting Instructions By Ashley Brown eHow Contributor Found This Helpful A watch is only useful if it displays the correct time. Over time, your watch may display the incorrect time as the battery wears down. After installing a new battery, you will also need to reset the time. All Invicta watches have similar instructions for setting the time. Setting the time does not require any tools or equipment.
Other People Are Reading
Watches with Time Only
  1. Pull out the crown. The hour and minute hands will stop.
  2. Turn the crown until the hour and minute hands are positioned on the correct time.
  3. Push in the crown to start the watch.
Watches with Time and Date
  1. Pull out the crown to the first position. The crown can be pulled out to two different positions. Pull gently once to reach the first position.
  2. Turn the crown until it reaches the correct numerical date.
  3. Pull out the crown to the second position.
  4. Turn the crown until the hour and minute hands correspond to the correct time.
  5. Push in the crown twice. It should now be resting firmly against the watch, in its original position.
Watches with Time, Day and Date
  2. Turn the crown to reach the correct day.
  3. Turn the crown clockwise to reach the correct date.
  4. Pull out the crown again to the second position.
  5. Turn the crown until the hour and minute hands display the correct time.
  6. Push in the crown twice so it rests against the watch. The crown should be back in its original position.
Read more : http://www.ehow.com/how_7352591_invicta-watch-setting-instructions.html
Sep 13, 2015 | Invicta Watches
How do I change the day, date etc on a GENEVA 7391 watch
read the instruction manual, Geneva Watches with Two or Three Hands
  1. Pull the crown out until you feel a click.
  2. Turn the crown counterclockwise until you have the correct time.
  3. Push the crown back in to set the time.
Geneva Watches with Two or Three Hands and a Date Window
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the time.
  2. Turn the crown counter clockwise until you have the correct time. Push the crown all the way in to set the time.
  3. Pull the crown out until you feel one click. This first click position allows you to set the date.
  4. Turn the crown counterclockwise until you have the correct date. Push the crown back in to set the date.
Multi-Function Geneva Watches
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the day.
  2. Rotate the crown counter clockwise until you have the correct day. Push the crown in to set the day.
  3. Pull the crown out until you feel a second click to set the time or the 24-hour hand.
  4. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  5. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
Geneva Chronograph Watches
  1. Pull the crown out two clicks. This second click position allows you to set the time.
  2. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  3. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
  4. Stop and start the chronograph by pressing the PA button, located above the crown.
  5. Reset the chronograph by pressing the PB button just below the crown. The PB button returns the chronograph second and minute hands to their original positions of zero.
Automatic Geneva Watches
  1. Wind the mainspring by turning the crown 15 to 20 times clockwise.
  2. Pull the crown out until it clicks.
  3. Turn the crown counterclockwise until you have the correct time, then push the crown in to set the time.
Tips & Warnings
  • Do not set the date or time between 8 p.m. and 3 a.m. to avoid damage to your Geneva watch. The gears sit too close together during these times.
  • If your Geneva watch becomes wet, wipe it dry as soon as possible. Keep your watch away from saunas and hot tubs, as the extreme heat diminishes the watch's water resistance.
Read more : http://www.ehow.com/how_6134550_set-date-time-geneva-watch.html
Jul 13, 2015 | Geneva Watches
How do I set my watch
It all depends on the type of watch you have.
Manually, the time (and date) are set by releasing the crown wheel and turning it so that the hands move clockwise to the correct time. If you have a date function, you may have to cycle the crown wheel quite a few times to reach the correct day and date.
On digital watches, the user guide will indicate which buttons should be pressed to set the time and date. Refer to the user guide that came with your watch, go onto the manufacturer's website or go back to the store where you bought the watch and ask them to show you how to do it.
On smart watches, the time should be set automatically when the watch synchronises with your smartphone or wifi signal.
May 24, 2015 | Watches
I have an OCW-M 800. I have downloaded the manual from mfg. website and cannot seem to get it to set the time for EST correctly. THis watch cost me over $500.00 and is so complicated that I fear I have...
I am not American, so I am not familiar with the definition of "EST" or which of the four "city" settings is correct for you.
Having read the instructions I see that for America you have to select "USA" first and then the appropriate city, have you done this?. The list of four options covers 4 time zones, so you should be able to get the correct time for your area.
When I bought an atomic watch recently, I had to leave it overnight to catch the timekeeping signals. I see that you posted your question only 14 hours ago. How long have you had it. GIve your watch a day or so for it to latch on to the correct time.
Check that the "autoreceive" is "on".
Check that the daylight saving time (DST) is correctly set. The manuals indicate that some areas may not be using it?
Keep trying - it is nice to have a watch that is always correct!
Oct 04, 2010 | Casio OC500 Oceanus watch
I have an aquatech watch and don't know how to set it.
Thank you for contactng FixYa.
Setting the Time and Date
  • To set the time and date on your Aquatech watch, begin by pressing the "Mode" button three times to access the time setting screen. Use the "Lap/Reset" button to set the hour on your watch. Use the "Start/Stop" button to advance the numbers to reach the correct hour. When you've set the hour, use the "Lap/Reset" button to set the minutes, using the "Start/Stop" button to advance to the correct minute. Repeat the procedure to set the seconds, month, date and day of the week on your Aquatech watch.
  • Setting an Alarm
  • To set an alarm on your Aquatech watch, begin by pressing the "Mode" button two times to access the alarm setting screen. Use the "Lap/Reset" button to set the hours place, using the "Start/Stop" button to reach the correct hour. Repeat the same procedure to set the minutes for your alarm. When you have finished setting the alarm, activate it by simultaneously holding the "Lap/Reset" and "Start/Stop" buttons until the alarm icon appears. When the alarm sounds, silence it by pressing the "Lap/Reset" button.
  • Deactivating the Hourly Chime
  • Many Aquatech watch models feature an automatic hourly chime. This can be inappropriate and inconvenient in many situations. To deactivate the hourly chime on an Aquatech watch, simply press and hold the "Lap/Reset" and "Mode" buttons simultaneously. After you have correctly deactivated the hourly chime, the hourly chime indicator icon will disappear from the watch's main screen.
  • Best regards. Jewel
    Sep 18, 2010 | Watches
    I have lost the instructions and cant set the time
    Try Googling (pod)(548)(manual) without parens.
    Aug 04, 2017 | Watches
    Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals.Rate me, please .
    Mar 27, 2010 | Watches
    I have an ESQ Aerodyne and the time set by the
    this watch needs to be taken in as this is not proper time telling. has the johnson rod been used yet. if not, do so. if so have it taken in and checked with a caver device.
    Jan 01, 2010 | ESQ 07301132 Aerodyne watch
    Casio Wave Captor Watch wont set to correct time.
    You need to manually adjust or set the hands to the home position as they are not where the watch thinks they should be. This can happen when you bring your watch close to a strong magnetic field. Look in the manual to do this. Afterwards your watch should set to the correct time.
    Apr 21, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    Tozai digital watch-setting correct time/date
    I need to correct the time/date setting on a tozai digital watch.
    Apr 05, 2009 | Watches
    Casio Wave Ceptor WV57HA-1AV Wrist Watch Logo
    41 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
