Question about Xerox Phaser 6130 Laser Printer
I've run out of yellow ink, error message says replace yellow only printing in B & W. the sheet i want printing has no yellow on it so how can i print with just colours available and overide this error message
  • 132 Answers
Get yellow catridge, sh?k? it and put into printer.
Posted on Nov 07, 2010
Epson Stylus Photo R800 not printing certain color
You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Aug 15, 2012 | Epson Stylus Photo R800 InkJet Printer
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Service error 5200 Keep getting this message Have
Your printer might be running out of ink, if you've seen that the ink button blinks, youy need to replace your cartrudge or refill your ink.
Jul 03, 2011 | Canon PIXMA MP240 All-In-One InkJet...
I've encountered an Incorrect Yellow message upon turning on the printer HP2820
The printer would only display messages of functions commonly as ink shortages. For example, color printers with encountering ink shortge would display a message. However, continuing to print would produce least impressive cooration where for multicolored characters tend to appear in yellow. Also, printers with ink malfunctions require inspection of cartridges, ribbons, and compartments for mal alllignments. Readjusting the ink compartments would request performing test print sheets as reallignment check. At which situation, a continued malfunction would be detected as diagnosable by computer popup messages. Refer to the printer user guide. Good luck
Jan 11, 2011 | HP Office Equipment & Supplies
My mfc240c says to replace the yellow ink cartridge but I don't want to spend money on that if the 'light bulb' is ruined. When I turn on the machine, I don't see any light for scanning or copying. ...
By the "light bulb," do you mean the scanner lamp? That lamp should only turn on when you are actually scanning, faxing, or copying a document. You should be able to still use the machine to scan and fax, even with the yellow ink empty. Try scanning a document to see if the scanner lamp comes on.
As far as printing or copying goes, you won't be able to print or copy anything until you replace the yellow ink, even if you try printing in black and white only.
Apr 19, 2010 | Brother Multi-Function Center MFC-240C...
Canon MP510 wont print. Error message B300 or
May I know the exact error messages in the printer screen. If it's green and yellow lights that are flashing you need to push more the two cartridges that you replace....also try to clean it using the printer program installed in your computer....good luck and hope it will help....
Mar 31, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Error message imaging unit is out
Hi rmcday: Here your problem. The imaging unit creates the image using an electro-photo process. The imaging unit consists of the following: ■ An OPC Drum ■ Waste Toner Assembly ■ Charge Roller Assembly 9.0 Consumables, Routine Maintenance Items and Options Item Life based on 5% coverage Part No. Replaceable by Black Standard Toner Cartridge Black High capacity 3,000 7,000 106R00679 106R00684 User replaceable Cyan Standard Toner Cartridge Cyan High capacity 2,000 5,000 106R00676 106R00680 User replaceable Yellow Standard Toner Cartridge Yellow High capacity 2,000 5,000 106R00678 106R00682 User replaceable Magenta Standard Toner Cartridge Magenta High capacity 2,000 5,000 106R00677 106R00681 User replaceable Imaging Unit 50,000 images 108R00593 User replaceable Transfer Belt 50,000 images 108R00594 User replaceable 500-Sheet Feeder N/A 119650600 Waste Toner Cartridge 3,000 to 5,000 pages (color 5%) 106R00683 User replaceable. Your imaging unit may have exeeded it life of 50,000 pages and will need to be replaced. Hope this helps
Jun 10, 2009 | Xerox Phaser 6120/YN Laser Printer
HP will not recognise new cartridge
The problem you are describing with the yellow cartridge sounds like ink starvation possibly due to a clogged print head or an air bubble in the print head. Since the machine is so new I would contact HP to get the print head replaced. As for the magenta cartridge, exchanging it for a new one at the store you bought it from should fix the problem. It sounds like the chip on the one you have is either damaged or wasn't set to read full ink levels.
May 29, 2009 | HP Officejet Pro L7680 All-In-One Printer
Ink problem
cleaned off the computer chip and it works fine now. . ..
THANKS
Mar 29, 2008 | Canon Pixma MP800 All-In-One InkJet...
Cyan & magenta ink will not flow + yellow ink full but error message says almost empty
(Use new carts for this procedure because it consumes some ink!)
press menu then start mono (blue copy button) then fourtimes arrow up. machine will be in maintenance mode. press 7 then 6 then 4 then start mono (blue). machine will refresh ink within tubes and print head and do some cleaning. when in mantenance mode again press 7 then 6 then 3 then start mono. machine will do a power cleaning. afterwards leave the mode by pressing 9 then 9. Run a quality test print by pressing ink etc.
If you cant see any mag and/or cyan the ph is clogged or dryed out. It has to be replaced then.
If you can see some of the blocks do the power cleaning (7/6/3)again.
BTW: Do use only DYE ink for all brother printers! The pigment ink will clogg the micro filter infront of the nozzels. When running machine with generic ink print a quality test sheet once a week!
Dec 03, 2007 | Brother MFC 420CN All-In-One InkJet...
Xerox Phaser 6130 Laser Printer Logo
177 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
