Question about Cozy Enclosed Front Console Heater 20,000 btuh Propane
Thermocoupling replacement Hello; I purchases and installed a cozy vented heater in 2005 and have had the thermocoupling and "blue bird fitting replaced ten times now costing more than the heater itself. I am ready to tear out. Sam at Louisville tin said it is likely the plastic version of the blue bird and can't be over tightened. I relayed that to the plumbing and heating contractor who has told me it is a defect with this model and he has already removed several new units for customers with the same problem and thrown them away. can you help
    Genius:
  • 1,036 Answers
Hi there!
10 times ? Wow - I would have given up after three!
Contact the heating engineer who replaced them, and print a complaint letter to the manufacturer stating their product is defective. Get the engineer to sign it, then ask for a refund of the repair costs to their faulty goods.
If nobody complains - they will continue to manufacture and sell rubbish. Money talks - so threaten to go to the courts over selling goods which are not of merchantable quality.
I hope you at least get the extra repair costs paid for.
This may be a case of being a nusience to the manufacturer, and they will pay out to shut you up. Go to THEIR local paper and get names of anyone else who's had a rough deal from them. Hopefully they will read it in their local paper - and offer a recall notice to similar units that are failing.
Not only will you benefit your own pocket, you will save many others suffering the same fate.
Hope this works for you.
Posted on Jun 15, 2008
I have a cozy model cdv255 direct vent wall furnace and the pilot light keeps going out. What causes this
dirty fuel line.have see where spider web is enough blockage to cause this. but aslo have found that the thermocouple needed replaced.
Jan 08, 2015 | Cozy Heating & Cooling
Have A Cocy Model VCR50IAR serial number 97063856 purchased November 20, 1997. We have to replace the thermocouple every 3 to 4 months. The last one was placed in February 2011. And this morning April...
Don, it's very, very unusual to have to replace that many thermocouples in that short a period of time. Which makes me believe, that there's something else causing the problem and replacing the thermocouple at best, is a band-aid fix. You didn't mention whether your fuel supply is Natural Gas or Propane. so I'm kind of leaning to a pilot flame problem. rather than the thermocouple.
If the pilot flame is curling upward and lifting of the thermocouple, that's and indication that the pilot is dirty and needs cleaning. And it would also mimic a failed thermocouple. Did the technician every clean the pilot? Also, some of the later model Cozy heaters were also equipped with a Thermopile/Pilot Generator. Low gas pressure can also cause a pilot outage, as well.
One of the things that I have found over the years is a loose thermocouple connection to the gas control valve. Either due to improper installation or vibration of the heater when firing up. Likewise, the connection to the control valve can be over tightened, which in time will lockup the gas valve.
The proper method of installing a thermocouple is to finger tighten the nut and with an appropriately sized open end wrench, tighten is only a quarter of a turn more.
In case you have misplaced your Owners Manual, I have included a link to it, that you can download and print for future reference.
http://www.cozyheaters.com/pdfs/products/Vented-Console-Room-Heater.pdf
Hope this helped you further troubleshoot and solve the problem. Please let me know.
Apr 18, 2011 | Cozy (VCR502A-BM) Heater
Need to replace a pilot *** on a cozy heater model dvcf653b
there are 3 phillips head screws on the bottom of heat exchanger and wre the burner assy. meet and 3 wing nuts on the bottom back remove and disconnect the gas line and the wires to valve and remove the assy. easy to remove thermocouple from this point install in reverse order, may need to adjust the pilot flame down on the gas valve if the pressure is causing the thermocouples are burning out.
Dec 09, 2010 | Cozy (W352E) Heater
I have had problems with my Cozy gas wall furnace since it was new (its about 6 yrs old now) I won't stay on. It seems that every year I have to call out service people to get it to work. It always...
if the switch at the top of unit is tripping there is something wrong with the vent , the switch is set at 350 degrees it detects back draft do to a improper vent or blockage of vent, if the installer use the old vent system that is more than likley the problem, have the installer call Cozy tech line at 502-589-5380 so they can go over how the unit is installed.
Dec 07, 2010 | Cozy (W352E) Heater
Repeated burnout of thermocoupling on a VC351A-R Replaced 5 times. Cozy heater
try a honeywell thermocouple , is the flame to the pilot too big causing them to burn out
Sep 17, 2010 | Cozy (W352E) Heater
The heater pilot goes out when the wind blows outside of the wall where the heater is installed. The heater is only six months old, so the thermo-couple is OK.
You mention that the thermocouple is OK, has it been changed or tested? This $4 part is usually the first thing to fail and I have found bad parts right out of the package. If I were you and I would contact the installing contractor to have them check out the following: Is the vent termination located as per manufacturing instructions (away from interior adjoining walls), Are the vent parts installed correctly, replace the thermocouple under the warranty, and check to make sure the pilot is both good and strong and it is hitting the thermocouple where it should. I have these heater installed on the top of Mount Washington where the wind blows at over 60 miles an hour and do not experience a pilot outage due to wind. The interior design of the venting system combats the wind effects. Good luck to you.
May 06, 2010 | Cozy (W352E) Heater
Cozy gravity one sided wall heater...pilot won't
how by extending the duct work will it make the gas valve work ?
if the pilotkeeps going out clean pilot jet , or if the power unit has gone in the gas valve then you would have to change the valve , don't get the flue bit ?
Feb 20, 2009 | Cozy (W352E) Heater
Cozy heater 35000 btu pilot light goes out every 4 days
The thermocouple needs to get red hot. If the pilot flame is too low or too high or if it is not pointed on the thermocouple well, it won't stay hot enough. If the pilot flame is too low, a draft caused by opening a door could blow it out. If correcting this doesn't fix it, it could be a bad thermocouple or control. The factory assembly on these heaters is not the best.
Feb 02, 2009 | Cozy Enclosed Front Console Heater 70,000...
Heating & Cooling Logo
107 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
