Question about Linksys BEFW11S4 802.11b Wireless Router/Switch + WMP11 PCI Card (BEFW11S4 + WMP11)
I have tried the 30/30/30 routine on my wrt3110 router but it doesn't work. Any other possibilities?
Unbrick router e2500
If you installed dd-wrt for your new router firmware it's possible you installed the wrong firmware. In most cases, it's permanently bricked. If not, you can try the 30/30/30 method to reset the router to its original factory settings. That is
1. Unplug the router and press the reset button for 30 secs
2 plug in the router and press the reset button for 30 secs
3 unplug the router again and press the reset button for 30 secs
During the entire process keep the reset button depressed. It takes some good hand coordination. 20/20/20 always worked for me for all the linksys routers I've owned over the years.
Jul 06, 2014 | Linksys Computers & Internet
How do i unlock my pattern lock on my galaxy s2
1. try entering null as password.2. try entering your username without @gmail.com3. Combine 1 and 24. Call yourself from another phone, answer, without hanging up press the home button, then menu button, settings, try to disable pattern-lock5. Call yourself from another phone, answer, hang-up, directly after hanging up start pressing your buttons like a madman for <30-60 seconds ending with your home button (might take a while to get the timing right). Go into settings and disable pattern-lock.6. Try the normal recover password routine from GMail.com
7. Perform a factory reset. YOU WILL LOOSE all not-synced DATA (SD card will be left untouched).
1-6 are possible workarounds, these doesn't work for everyone but can be worth a try to avoid factory reset. 6. is what should work but hardly never does. 7 - The factory reset always work
Added reference with some additional info, how to factory reset can be found there.Good luck!
Oct 14, 2011 | Samsung Galaxy S GTI9000 Smartphone
I'm unable no connect to the Internet using a WAG354Gv2 router. It has been two days until I'm having this trouble, all seems OK, the configuration of all parameters is still the same but the DSL...
checked your signal. click troubleshoot problems, then fix.Or you may disable enable your wireless adapter for awhile then check again.
Try to Reset your router by pressing and holding the reset button for 30 seconds.Unplug power cable from router then power up again.
If that still doesn't work then Press and hold the reset button for 30 seconds...Release the reset button...Unplug the power cable from your router, wait for 30 seconds and re-connect the power cable
Sep 09, 2011 | Computers & Internet
I cant connect to internet
There are lots of possibilities here since you didn't give us much info to go on. Some helpful information would be:
1. DSL, Cable Modem, Sat Modem, other ISP
2. Is the problem with the router, or the network connection
3. What are the model numbers on your router, and if that doesn't connect directly to the wall, what does it connect to.
4. are you connecting from a desktop or laptop
5. are you connected to the router over wireless, or Ethernet cable
6. are there any other devices in your house/apartment that can connect to the internet (is 1 device down, or are all the devices down)
With the little information we have, I would suggest unplugging your router for about 30 seconds, then plug it back in. It will take anywhere from 30 seconds to several minutes to reset and reconnect.
If this doesn't fix the issue, give some more details and I will give the next step.
Thanks,
John Vickers
Aug 12, 2011 | Computers & Internet
My belkin router is not giving off a wifi signal and i reset it already and still does not work it work last week and all the light are on
It is possible that your belkin router stopped working.
Try the router on another network and if is doesn't work, you will need to replace it!
Hope it helps.
God Bless You
Remember to rate to keep fixya.com working for you
Jul 30, 2011 | Belkin (F5D5231-4) Router
Why abs and advance trac warning light stay lited on 2004 ford expedition ?
Because you have an ABS System Malfunction
A repair shop will check for codes,diagnose &
repair it for you
Doesn't matter what check lights you get on your dash
You should be familiar with them all & the routine,
they have been there for 30 years now
Possibly a bad Wheel Speed Sensor
Jun 07, 2011 | 2004 Ford Expedition
I have 2windows laptops and they both stopped gettin an online connects could you possibly help me get a connection that will work? I would appreciate it so very much.
First off I would reset the router and modem. Do this by unplugging it and waiting 20-30 secs and plugging it back in. If that doesn't work, shoot me a line and I will see what else I can do.
May 17, 2011 | Computers & Internet
192.168.0.1 is not going to router settings on my web browser when typed into address bar like it usually does.. Any known issues or problem solving knowledge?
Try 192.168.1.1. If that doesn't work then try connecting to the router hard wired using IE as your browser. Sometimes with some routers they can only be connected via an RJ 45 cable. Some routers like Linksys only like IE as the browser for accessing the router settings.
If you continue to have problems then reset your router. There is a tiny button recessed on the router back. Using a pen point hol the button in for 30 seconds and then try accessing the router.
Good luck.
May 15, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
Cant get configuration to complete on befsr41 router
Press the reset button on the router for at least 30 seconds. release it. Unplug the power to the router . wait for 10 seconds and plug it back in. Wait for 1 minute and try to set up your router.
If you are having trouble setting up your router with the CD, then you can set up your router without CD also. You can do it manually.
First make sure that your computer is online directly through the modem without the router.
If that is working then you can connect the computer and the modem to the router. Open the set up page of the router and change the settings of the router according to the settings of the Internet service provider
Click here for more information about router set up
Feb 16, 2010 | Linksys EtherFast Cable/DSL Router
My tew431brp status led is permanently red, it won´t work, it´s not possible to go to the config menu again, the old configuration previously stored doesn´t work either
When in doubt flash it! Though you must reset it to default protocols first. There should be a reset button somewhere on the unit, press and hold for at least 15-30 sec. If this does'nt work you may have been zapped by some stray volts and in this instance is not cheaper to keep her.
Jul 02, 2009 | Trendware TRENDnet TEW-431BRP Wireless...
Linksys BEFW11S4 802.11b Wireless Router/Switch + WMP11 PCI Card (BEFW11S4 + WMP11) Logo
50 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
