Question about Nextar Q4-04 Car GPS Receiver
What to do when error screen "cannot start the main navigation engine! please try again" is displayed
I had this same navigator and had nothing but problems with it , so I pitched it in the trash, In my opinion it was junk.
Posted on Nov 07, 2010
Can I set the TomTom to "go to" a longitude/latitude location?
Yes.
First you'll want to set your unit to accept coordinates. From the main menu, tap Change Preference, then select "Set Units" and select a Latitude and Longitude format in the "Coordinate display" screen, and then tap Done.
To navigate to a location using latitude and longitude coordinates, follow the steps below:
  1. From the Main menu, tap Navigate to...
  2. Tap Latitude Longitude.
  3. Enter the coordinates and tap OK.
Feb 08, 2012 | Tomtom GO GPS
Tip
How to Fix a Polaroid LCD TV Screen
<p>A Polaroid LCD TV delivers its picture via DVD player or cable connection to your home or office. After setting up your device and using it, you might experience technical difficulties with power loss and picture quality. Navigating through a few steps of self-maintenance will have your Polaroid TV running smoothly again in little time. You can examine your TV's power cord for damage, rewire a DVD player connection, and adjust your Polaroid's backlight.<br /> Difficulty:Moderate <span>Instructions</span> <ol> <li> <ul> <li> <span></span> Turn your Polaroid around so that the back is facing you, as a first step in correcting a power loss issue. Examine the length of the power cord from the back panel of the Polaroid to the wall outlet for damage, such as tears or rips. Replace the cord, if you see damage. Unplug the TV from the wall outlet and inspect the metal receptors (prongs) for dirt. If the prongs are dirty, clean them with a dry cleaning cloth. Plug a separate electrical device into the outlet and turn it on to confirm that the outlet is performing correctly. Plug the Polaroid TV back into the outlet, and try again.<br /> </li> <li> <span></span> Twist the Polaroid TV's back panel towards you so that the connected cables and jacks are easily accessible to you. If you're experiencing problems getting a picture from your DVD player, inspect the connection of the audio/video cables to your "Composite In" jacks. There are three cables in a standard audio/video setup: a yellow cable, a red cable, and a white cable. Unplug all three cables from their jacks to reset the connection. Insert the yellow-tipped cable into the "Video" port, which is yellow-colored to make matching the cables easier. Insert the white-tipped cable into the "L" (left audio) port and the red-tipped cable into the "r" (right audio) port. Perform the same steps on the audio/video cable out ports of the DVD player, and try again.<br /> </li> <li> <span></span> Raise the TV's backlight level, if you're having trouble seeing the picture. Push the "Menu" button (located on your remote control), and the TV setup menu will appear. Use the navigation buttons located on your remote control to scroll to "Image," and push "Ok" -- located within the navigational buttons on your remote control. A list of options will be displayed, such as "Contrast," "Hue," and "Saturation." Choose "Brightness" from the options. Use the four-way navigation buttons to raise the brightness (make your screen brighter and more illuminated) or lower the brightness (make your screen darker).<br /> </li></ul> </li></ol>
on Dec 27, 2010 | Televison & Video
What's your problem?
It's a bit complicated. Either the internal memory got corrupted or there is another issue. Can't really tell you which is which until i have it in my hand. But i assume is the first.
Nov 27, 2011 | Nextar Q4-06 Car GPS Receiver
Not working always show "turn thepower off and on
I'm sorry that the Camera is displaying the error message. "TURN THE POWER OFF AND ON AGAIN" displays on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset. Please follow the below steps to perform a power reset.
·Turn off the camera.
·Remove the battery pack.
·Press and hold the power button for 30 seconds.
·Allow the camera to remain without power for 60 seconds.
·Reinsert the battery pack.
·Turn on the camera.
Also try initializing the Camera if you're able to access the Menu items on the Camera. The Initialize option will be available underSetup or Main settings Sub Menus.
If the issue persists again, service is required. Pleaseclick hearto locate the service center near your area.
Thanks for understanding. Please let me know if your require any clarifications.
Aug 01, 2011 | Sony Cybershot DSCW310 Digital Camera
My camera displays "turn the
Also try initializing the Cameraif you're able to access the Menu items on the Camera. The Initialize option will be available underSetup or Main settings Sub Menus.
Jun 10, 2011 | Sony Cyber-shot DSC-W70 Digital Camera
My naxtar gps wont load into the maps. it loads through the first screen then i hit navigator and it takes a bit loading then comes up with "error, cannot start the main navigation engine!...
Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In either case, please return the unit for exchange or repair to the retail location from which you purchased it, or contact us for further assistance.
The link below has the operating manuals and software available and contact numbers.
Thanks for using Fixya, please accept my solution.
http://www.nextar.com/frontend/gps_navigation_systems.asp?MODEL=43NT&subpr=&categ=
Jun 01, 2011 | Nextar 43NT GPS Receiver
When I turn the power on, the screen shows "turn
This type of problem can be caused by either a lens issue, or power problem. The following web blogs delineates things you can try to get the camera working again. They say about 50% of the time they can be fixed trying their suggestions:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
If none of those things helps, try these steps:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
If the camera still doesn't work, you can take it in to a local repair shop, but get an estimate first. Repair can be high, and justify just going ahead and buying a new one.
Good luck, and hope this helps.
May 27, 2011 | Sony Cyber-shot DSC-N1 Digital Camera
My sony Camera (DSC -W110) is showing "Turn the power off and on again" while switch on the camera,it appers again & again after switching the camera on and off
· Turn off the camera.
· Remove the battery pack.
· Press and hold the power button for 30 seconds.
· Allow the camera to remain without power for 60 seconds.
· Reinsert the battery pack.
· Turn on the camera.
Also tryinitializing the Cameraif you're able to access the Menu items on the Camera. The Initialize option will be available under Setup or Main settingsSub Menus.
If the issue persists again, service is required. Please click hear to locate the service center near your area.
Mar 21, 2011 | Sony Cyber-shot DSC-W110 Digital Camera
NEED CANON IC 2300 EOOO RESET CODE
Hello PRAL,
I will gladly try to help you, but please understand that E000 is a fuser error code and can either be an anomaly or if it is genuine the code will return almost immediately because of safety reasons( high temperature control ). Please forgive me if I over - explain things but I don't want to take it for granted that you are familiar with how to enter and navigate service mode, since that is indeed what you will have to do. To reset the code you wil have to enter service mode. To do that you will need to press the "ADDITIONAL FUNCTIONS " button and then the numbers 2 and 8 at the same time, then press the "ADDITIONAL FUNCTIONS" BUTTON again. A three step continuous flow procedure. Additional functions, 2&8 together,additional functions. This should bring you to a new screen that will have several new tabs not normally seen. One will say "COPIER". Press it. New screen again.The main screen will have several options but we will be using the "TABS" you can see across the top of the display. One of those tabs says "FUNCTION". Press it. New display again. Look in the main display and you will see an item that says "CLEAR". Press clear. New display again with a list of items that you can "clear". Press "ERR". Once you have done that, locate the "OK" tab at the lower right hand corner of the display and press it. You just reset the code. Now turn the copier off using the MAIN POWER SWITCH. If you are in doubt as to where it is located (not the button you see on the operator control panel) then unplug the machine for about 5 seconds. Then plug it back up. The copier will begin its warm up and self diagnostic check as it attempts to become"READY" again. Somewhere between the start up and making your 1st copy, the copier should display a similiar error code if the problem is genuine. If it was just a burp before then you may be ok. Fuser codes can be generated for several reasons other than a true problem. But if you do have a big problem, the copier will rather quickly display the error code again. At that point you will need service. I know for sure that I have provided you with exactly the information you requested, which was to reset the error code and I hope the reset is all you need to return to copier bliss. I hope you have no additional problems. If you don't mind would you please return to the "FIXYA" website and provide positite feedback to them as I have helped you. Thanx and good luck to you and yours.............SPINAL..........
May 01, 2008 | Canon ImageRUNNER 330s Copier
Nextar Q4-04 Car GPS Receiver Logo
569 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
