My thermostat won't turn on - Heating & Cooling
    Genius:
  • 1,015 Answers
You need to see if you have power to thermostat. If you have a volt meter /multi-meter and know how to use it you can check it.Remove cover from thermostat and see if it has a mercury switch. This will be a small glass vial that is connected to temperature setting lever. if you move heat setting up or down the glassvial will move with it and you should see a small spark inside.I should back up here because I assumed that you have a older style manual thermostat. If you have a programmable t-stat disregard . Either way if you are sure you have your t-stat in the proper position to call for heat and it's not working. If you are mechanically inclined you can carefully remove cover from t-stat and remove 3 or 4 small screws that mount it to wall. Be careful as the control wires are very small and may break, carefully remove red and white wires . The terminals should be marked as R and W. If you jumper red and white wires together furnace should come on. If you have a multi-meter you can check for voltage across r and w withot removing from t-stat. You should have about 24 volts a.c. If you have proper voltage or if unit works when you jumper r and w then you need to replace thermostat.If you don't have proper voltage there you will need to check transformer,control board or wiring. Hope this helps. Thanks.
Posted on Nov 07, 2010
Won t turn
Is it a programmable thermostat or just a standard thermostat?
Aug 23, 2013 | Honeywell Heating & Cooling
FURNACE WON'T TURN ON: I have a 1999 Fleetwood, Prowler RV. The furnace won't turn on.
Check the exhaust port of the furnace. Wasps like to build nests in there and it will not allow the furnace to ignite if blocked. You have a gas detector and it is turned on I assume? I forgot this many times.
Apr 20, 2013 | Heating & Cooling
Attic fan won't turn off
faulty thermostat switch
Jul 15, 2017 | Broan-NuTone Dryers
Cadet ct402 won't shut off
thermostat needs replaced or logos wire
Oct 24, 2012 | Cadet Manufacturing CT402 Electric Heater
Honeywell ct3200 thermostat won't turn on
DON'T BUY A NEW ONE JUST YET! IF THE BATTERIES DIED & THERMOSTA LOST POWER, IT MAY HAVE LOST IT'S MEMORY. IT MOST LIKELY WENT BACK TO FACTORY DEFAULT SETTINGS, & NEEDS TO BE RE-PROGRAMMED THROUGH THE INSTALLER SET-UP MENU. HOPEFULLY YOU HAVE THE PAPERWORK FOR THE THERMOSTAT STILL & CAN POSSIBLY DO THE SET-UP YOURSELF. IT SHOULD HAVE STEP BY STEP INSTRUCTIONS FOR THIS IN THE INSTALLATION GUIDE (NOT THE OWNERS MANUAL)
Oct 13, 2012 | Honeywell Programmable Thermostat Heater
We have a kenmore ultra wave microwave and the fan has stopped working and now the microwave won't operate. Any suggestions?
see this causes and fix it .God bless you
Exhaust Fan Motor If the exhaust fan does not run the fan motor might be bad. Remove the fan motor from the microwave oven and see if the blades can be turned by hand. They should turn very freely, if they're stiff the fan motor will need to be replaced. The fan motor can also burn out. To test this use an Ohm meter. The motor should have continuity. If it does
Thermostat If the microwave exhaust fan is not working the thermostat might be defective. The thermostat senses the air temperature and turns on the fan as needed, if it's defective it won't turn on the fan. Watch our video on testing thermostats.
Main Control Board If the microwave exhaust fan is not working check the exhaust fan motor and wiring. If they are good the main control board might be defective.
Oct 02, 2012 | Microwave Ovens
Fan wont come on
You may have a faulty thermostat. If its stuck closed the fan won't run. Thermostat tells the car when to turn on/turn off the fan based on how hot the engine is getting.
Jul 29, 2012 | 1998 Honda CR-V
Heating won't go off
Honeywell manuals are online for all its thermostats.
Google search your model number.
Model number is on back of thermostat.
Copy following link for Honeywell resources:
http://yourhome.honeywell.com/home/Applications/FindYourModelNumber.aspx
Honeywell manuals are detailed, but each pdf file can be word-searched.
More resources:
http://www.ehow.com/how_6596826_troubleshoot-honeywell-thermostats.html
Jun 25, 2012 | Hardware & Accessories
Won't run when set to auto
This can either be a bad thermostat or faulty control board. If the unit kicks on after jumpimg the wires at thermostat then the thermostat is defective, if it does not turn on the control board is faulty and must be replaced.
Jun 06, 2012 | Goodman Heating & Cooling
Heating & Cooling Logo
948 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
