I have a Yamaha Audiogram 6. This came with Cubase AI 4. After I downloaded all the drivers I spent an afternoon recording and everything was good. I tried to record yesterday and Cubase wouldn't allow me to get on. Now when I try to open Cubase it directs me to a website that says current name, password , or host was not accepted when connection to the database was attempted to be established. Does anyone have an answer for this?
SOURCE: Recording problem
As the built-in mic is probably the weak link I would suggest getting a external one with a built-in preamp and output control. Or a separate preamp with microphone. If you want to make good quality recordings using the highest sampling rates you should go for a better microphone.
Posted on Jan 12, 2008
SOURCE: tascam us 144 sync problems with cubase le
Hey lea,
i have a similar setup (Cubase LE & Tascam 144) and each time i start up Cubase i have to make sure there is no digital input going to the tascam. once cubase is started up but no project loaded i plug in my spdif from my DAT machine and then open my project and all is fine. does that answer part of your question?
i have a different problem though, i'm trying to record my DAT tapes which are recorded at 32khz and cubase doesn't recognize that sample rate properly. it'll record no problem, and play them back fine, but exporting always creates mismatched sample rates in the exported file. sucks big time and i have got no idea on how to fix it either.
Posted on May 03, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: My stiletto records for about 18 minutes then stops
Daylight savings time change a few months ago messed up the timer recording schedule - you must now fix it. Daylight savings time changes will always mess up this recorder. You must reset your recording schedule.
For more info on fixing, go to:
http://shop.sirius.com/edealinv/servlet/ExecMacro?nurl=control/StoreItem.vm&ctl_nbr=2640&siId=1745656&catParentID=7874&scId=7874&oldParentID=&cid=SL100PK1
2 other remote possibilities:
If no signal is present at the time the recording is scheduled to start, the recording will be skipped.
Make sure you have followed all instructions on pp. 55-58
-Tha Mp3 Doctor
Posted on Jun 10, 2008
SOURCE: lexicon omega driver
Yes having the same problem with new driver that Lexicon put on their site 2.5 driver has screwed up everything and the soundcard is nolonger working because of this new driver even their website is down very poor avoid Lexicon Omega
Posted on Aug 09, 2008
SOURCE: my recorder says "full" when i try to record, but i have deleted everything!!??!!
Solution for this problem is to Format the recorder. Step 1 is to turn on unit. Step 2 Press Erase " Delete will flash on the display. Step 3 Press and hold Rec for 3 seconds "Format" will flash on the display. Step 4 Press and hold Erase, the completed percentage will show on the display (formatting is now in progress). Step 5 After formatting is completed the remaining time will show on the display. You should now be able to record. Make sure that you hold the ERASE button in step 4 until Formatting shows 100% complete.
Posted on Aug 19, 2008
Further clarification is that alyhough i can download the drivers and get playback I can't find anywhere that will download the cubase software to allow recording and sequencing etc on my lexicon lambda as...
It looks like you are trying to download Cubase from Lexicon site . .
You can use any software . .
Here is a link for free Audio Recording Software.
http://audacity.sourceforge.net/download/
Or you can buy a new license for Cubase . .
All the best . .
Sep 13, 2013 | Steinberg Cubase Studio 4 Full Version for...
How do i record drums from drum kit
Hello nastyneph320:
Computer connectivity (via USB, Ethernet or the FW16E FireWire option) and DAW integration features like 8 zone Master mode, DAW remote control and cross platform editors let you seamlessly integrate the Motif with any DAW software, including the bundled Cubase AI software.
Translated it means that you can use USB, Ethernet, or FireWire connection to your PC and use DAW or Cubase AI software for recording. But I'm pretty sure you could use some other type of software for recording as long as it accepts your Keyboard.
Don't forget to vote with a thumbs up if this helped.
Feb 26, 2011 | Yamaha MOTIF XF8 88 Note Workstation...
My Yamaha audiogram 6 has mysteriously stopped working i can't record or hear the sound through it. Can you help?
First thing is to make sure the audio system in the PC is assigned to this device. Go into the control panel and click on the "Sounds and Devices". Then click on the "Voice" tab and make sure both the in and out are pointing to this device rather than the internal sound hardware in the PC.
Nov 30, 2010 | Yamaha AUDIOGRAM6 6-Channel USB Audio...
I am using this with Cubase AI 4 and my output is too low and if i try and turn it up, i get too much background noise. What am I doing wrong? Also when i listen while recording it sounds low but find, but...
if you have leopard or snow leopard, it is probably osx. i know for a fact that leopard has issues with usb recording devices, i dont know about snow leopard, tho.
Nov 23, 2010 | Yamaha MW10C 10-Channel USB Mixer
Will this work with cubase le4?
cubase le is a learning series. you can try in cubase sx or nuendo for good result.
Apr 06, 2010 | Steinberg Cubase System 4 USB Audio...
How can i play BUP 06PK61 frm yamaha I425 on PC
how can i play .bup file in computer?
ok here is the solution!!!!!!!!
    • we should have a mic pin and audio cable as shown in this pic
    connect these cables,and connect big pin to the piano and small pin to the computer (mic or input jack)
    now take windows movie maker (start-all programs-windows movie maker). click on narrate timeline (as a mic icon below windows movie maker).
    now click start narration on the pc and play your song on the piano. you can see input level highlights. now your song is recording. when your song completes click stop narration and save to the pc. walah if you can't understand this say to me. i can add video. sry for my worst english
Jan 13, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
Recording with cubase problem
Need to set it to stereo. There may be a switch on your mixer, and you will also need to change the settings in Cubase to record in stereo, not mono.
Jul 30, 2009 | Lexicon Omega Desktop Recording Studio...
Bought an MXL V88 Mic and i hear no sound ,not working
go to control panel> hardware and sound> sound; click recording tab, select USB Audio Codec, select Properties, click Advanced tab, select 2 Channel 16 bit 44100Hz and then hit apply. You have to make sure you have the 2 channel option selected. otherwise the computer just recognizes one channel and assigns it for playback. HTH
Apr 09, 2009 | Audio Players & Recorders
Firebox and cubase se not workin
https://www.steinberg.net/1069+M52087573ab0.html, If u have purchased the software,just go to this this link,register ur product. U will get the steinberg cubase customer care, just try contacting them and rectifying the problem, because this is too specific and technical.BEST OF LUCK!!!! THANK U!!!!
Jun 21, 2008 | Steinberg Cubase SE
Tascam us 144 sync problems with cubase le
Hey lea,
Mar 04, 2008 | Tascam US-144 Sound Card
42 people viewed this question
 Grubhead
Grubhead
