Question about Toshiba 250GB TOSHIBA USB 2.0 PORTABLE EXTERNAL 25 250 GB Hard Drive
Dear all, My toshiba external hard disc (640GB) is not working properly. the problem is that the disc is detected by the computer and i can see the data for first 5 minutes and after that light in the HD is glowing but the device is not recognized by the computer. The motor sound is coming in the begining and later the disc is very silent, no sound confirm the disc is working... Please give a solution for this problem
    Brigadier General:
  • 10,406 Answers
The device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, to "check warranty status" -- if it is still under warranty, you can get a replacement, at minimal cost to you.
Posted on Nov 07, 2010
The hard drive fell and i hearing it still spinning and stuff but it not being recognised on the computer
The hard drive is easily damaged when it takes a fall, there is no way it can be repaired because it is integrated into one unit, the only option is to replace the hardware.
Jun 07, 2011 | Toshiba 640GB USB 20 Rocket Red Portable...
Toshiba external hard drive 640Gb appears on my laptop the USB connects perfectly ,it opens but doesn't take in any file .
hello, i would advice you to format your external hard drive by write clicking on it and click on format and click on start to begin, if this does not allow you to still put files on your external hard drive,then insert it on a friend laptop and see whether you can move files to it. I hope this helps. Regards
Feb 08, 2011 | Toshiba 640GB USB 20 Portable External...
I attached my 640GB SATA hard disk drive on my asus p4v8x-x motherboard but my motherboard cannot detect my hard drive.and it gives me that message cant initiate the new hard drive , bios does not...
Your problem same as me, so to solve the problem I attached my 250 GB SATA hard disk drive by external connection via USB pug, hard disk can work properly, ok please try
Sep 17, 2010 | ASUS P4V8X-X Motherboard
Every since I have upgraded from XP to Win 7 I cannot get my toshiba 640gb external hard drive to work. It registers an icon and it does pop up under the list of hard ware and devices but, I am unable to...
Did you check the Microsoft Hardware list before you did this upgrade?
If not, please check it now ... at ... http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
If your device is listed ... great .. you have a solvable problem. If not listed, you will have to upgrace your hardware.
Sep 16, 2010 | Toshiba 640GB USB 20 Portable External...
No detection at all..
may be problem with external usb device. check on other systems. If it shows the same problem then contact service provider of your seagate
Jun 22, 2010 | Seagate FreeAgent Go 640GB External USB 20...
WD 640Gb My Book Essential: HD on main computer
files must be "imported" into your new mail program.
the new computer may have a newer or different version.
Apr 08, 2010 | Western Digital My Book Essential Edition...
Computer stopped being able to read external Maxtor hard drive. 640GB PN:9NZ2DG-500 SN:2HBADBDS. How do I retrieve data
Check the USB port and/or the cable, check if windows can detect your device. If windows can detect but can't read data perform a format or delete the partition and then use any file or partition recovery software you want to use. They will automatically rebuild partition table and MBR according to your need. If windows can't detect, unplug your device, uninstall the driver from the device manager, restart your pc, plug your device again and see windows will automatically install the device.
Dec 31, 2009 | Computers & Internet
When i turn it on it has a disk read error occurred message
The Toshiba cannot find a boot disk, this problem could be caused by the BIOS could not detect the hard drive because has lost the configuration or the hard drive is faulty or the disk controller is faulty.
Check the BIOS configuration to see if it has detected the hard disk and some BIOS have a utility to test the hard disk, if this is available then run the hard disk test.
Another way to test the hard disk, remove the hard disk from the laptop and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer see it as and external hard drive and you can open the folders and files the the hard drive is OK and the fault is most likely the laptop's motherboard.
If the computer cannot detect or open the files on the external USB adapter then the hard drive is faulty. The hard drive needs to be replaced in the Toshiba and Windows installed to get the laptop working again.
Aug 02, 2009 | Toshiba Computers & Internet
Toshiba 250GB TOSHIBA USB 2.0 PORTABLE EXTERNAL 25 250 GB Hard Drive Logo
461 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
