Question about Microwave Ovens
Hi I have just bought a Whirlpool microwave VT 265 it works fine but when it complete the cycle on any of the program you select the END comes up on display, but the turntable and fan continue to work until you press the stop button , I phoned the agent and they said its normal, i have had many Microwave and not one them didn't stop at the end so i am not sure if it has a problem, I checked the instruction and nothing is mentioned about this function. Could you please confirm this thanking you in advance. Regards Martin Xerxen
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave Buzzing, Still Heats, but Turntable And Fan Not Working
This is not safe. If the fan is not running, the magnetron will quickly overheat and be destroyed. We answered this in more depth in the other place you asked it.
Posted on Feb 25, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Fan stopped working in JVM1533BD microwave
I assume you're talking about the hood fan which ventilates the cook top and blows air through the grille across the top. If so, it's okay to use the microwave with that not working, but if you boil something on the stove, an external fan is definitely needed to keep mositure from going up into the microwave controls. If the cooling fan INSIDE the microwave (behind the keypad) is not working, then you do NOT want to run it unit it is fixed. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Posted on Apr 10, 2007
  • 38 Answers
SOURCE: Nothing happens when you press "Start"
PLEASE CHECK IF DOOR IS CLOSED PROPERLY THOSE HOOKS ON THE DOOR ACTIVATE SWITCHES ON THE INSIDE OF MWAVE OPEN COVER AND CHECK IF HOOKS ARE MAKING CONTACT WITH SWITCHES .COULD ALSO BE TOUCHPAD FAULT YOU WILNEED A TECH
Posted on May 09, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp R-1450 microwave
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
On these, it's usually a broken tab on the upper switch holder.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
That sounds like what's happening when you hold the Start pad - maybe you're moving the frame and chassis enough to help it work.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 19, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp Microwave died after Power Surge
We have the R530ES service manual for this model and have uploaded it to our site here to help you. It's close enough to the R530EK and EW models, in case that's what yours is.
You will need the free Acrobat Reader to view or print it.
Actually you have two separate problems, and both are easily solved..
(1) The reason that only the inside light comes on when you try to cook is that your secondary (bottom) door interlock switch is bad, or its mount is misaligned or broken.
If you only need a switch, you can order one from us for $5 postpaid or local appliance parts stores, hardware stores, or places like Wal-Mart, Lowe's or Builder's Square.
(2) The display problem is something we regularly repair these for customers nationwide with our guaranteed $39.95 service in about a week.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
Posted on Oct 07, 2008
Hi. I just bought a whirlpool over the stove microwave #UVM6011CB at Lowes. All works fine except fan doesn't work. We vant out the back and did turn the fan to do so. Help?
If this is an overhead builtin unit and you want the unit to vent outdoors and not back into the kitchen, then the fan motor must be reorientated inside the cabinet See your installation instructions.
Nov 11, 2017 | Whirlpool Microwave Ovens
Should the fan continue to run on my new whirlpool micro oveev
yes the FAN will continuosly until the cycle is END.
God bless you
Nov 27, 2013 | Whirlpool Microwave Ovens
I recently bought a Whirlpool microwave. I would like to know if there is a manual telling how to use the buttons on the keypad? When the button says "popcorn" I have no idea if I just push...
Here is a link to a the product page for one standard Whirlpool microwave model currently available:
http://www.whirlpool.com/-[MT4155SPQ]-1001410/MT4155SPQ/
And here is a direct link to the User's Manual for that microwave oven (model # MT4155):
http://www.whirlpool.com/digitalassets/MT4155SPS/Use%20and%20Care_EN.pdf
To view the Product Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 10 of the manual for detailed instructions on how to use the POPCORN feature in that microwave. Here is an excerp from that section of the manual:
To Use POPCORN:
1. Place popcorn bag on the turntable and close the door.
2. Touch POPCORN once for Regular, or twice for Snack.
Touch START, or wait for the microwave oven to start the
popping cycle automatically.
When the cycle ends, "END" will appear in the display, and
the end-of-cycle tones will sound, followed by reminder
tones.
3. Touch OFF or open the door to clear the display and/or stop
reminder tones.
I hope that was helpful to you, good luck and take care.
Joe.
Oct 03, 2011 | Microwave Ovens
Microwave inoperative on rv generator power
Replaced with different microwave. Amanna microwave works fine on both circuits. Would not recommend Whirlpool for RV use.
Thanks
Dec 27, 2008 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Microwave does not heat/cook
hi
power spikes are very damaging to a microwaves internal parts, it sounds like your transformer and/or magnetron are blown. if the unit is out of warranty I would recommend calling a repairman or getting a new microwave (the transformer & magnetron are expensive and dangerous to work on) also get a small single plug surge protector for the new one.
Mar 21, 2008 | Microwave Ovens
Whirlpool Micrwave, model #mh6150xls-1
Since you tested the door switches (my number one suspect) I would think you have a bad relay or a bad connection on the control panel circuit board. We repair these nationwide for $32.50, which is usually economical for most models. Just to make sure you have checked the door switches thoroughly, you can find my helpful text file called "doorsw.txt" via a Google search. It has important safety information and tips.
Oct 24, 2006 | Whirlpool MH6150XLS Microwave Oven
Microwave Ovens Logo
37 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
