Question about GPX Televison & Video
DVD Player I just bought a new DVD player and the sound won't work but the picture is fine. There isn't any troubleshooting info in the instructions. What could be wrong?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 106 Answers
It depends what connection you are using. If you are using the S-Video or HDMI then you still need to connect the white and red composite cables to the inputs on your TV.
Posted on Jun 15, 2008
My vizio blu ray player will play discs that i burn but no store bought discs dvd or blu ray
Sounds like it may need a software update. Quite common for dvd players. ring or contact where you bought it from or manufacturer and ask for instructions and obtaining files to update your player
Feb 22, 2014 | Vizio VBR220 Blu-Ray Player
Pioneer dv320-k = no longer region free??
You maybe able to get a region free code for your player from these WEB sites.
REGION FREE CODES FOR DVD & BLU-RAY
www.dvdexploder.com/ www.videohelp.com/dvdhacks www.download-info.com/dvd/index_new.htm
Feb 24, 2013 | Pioneer DV320K Multiregion DVD Player PAL
I own an iview 2600hd dvd player and im trying to hook it up to my sony trinitron tv...however, no matter how i switch my cables, the dvd player just won't show any picture or audio on my tv...and when...
Try new cables. RCA cables have a tendency to have bad connections internally. Also, triple check that you're on the right input and the wires are properly connected to the DVD player. If all that fails, try the DVD player on a different T.V. and something that uses RCA cables on your T.V, such as a cable box to make sure the input jacks on the T.V. aren't bad, and the DVD player isn't bad.
Through out all of this troubleshooting, you should manage to get the DVD player hooked up.
Jun 20, 2011 | Televison & Video
I have an RCA L40HD33 model .... Tv has picture but no sound... the dvd player works fine both picture and sound.....Help??
i have lhd4033d rca tv dvd combo. was having sensor problems with my remote. bought a new one. still not working. took front screen off to find out that I had two wires broken. now the problem is solved. tv works fine.
Mar 13, 2011 | RCA L40HD33D 40 in. LCD HDTV
Compatibility with Samsung LCD Display
It sounds like the HDMI port on the back of your Marantz is damaged. if you know for sure that the HDMI port works on another tv still you might just use component connection because the visible difference between component and HDMI is not very recognizable.
Jan 13, 2009 | Marantz DV4001 DVD Player
Fuzzy connection on my samsung DLP HLN567W
Try the DVD player on another component connection on the TV. If the picture is still distorted try another DVD player or something with component output. If thre picture is normal with another input device then the issue is the DVD player,
Nov 28, 2008 | Samsung HLN567W 56" Rear Projection HDTV
Panasonic TX32LMD70: split and green picture from DVD
Cut feed lead to pin 16 (in the scart not the equipmend!)
Does not matter which end. It just stops the TV from switching to RGB- The DVD is sending non standard RGB - PanamanNE
Jul 04, 2008 | Televison & Video
Can't get picture on TV.
If you were using RCA cables, you may have had them hooked up wrong. I know this may sound like an easy fix, but I still hook them up wrong from time to time. Especially if there are more than one set of RCA hook-ups on the back of the unit. If you were using a S-video cable you shouldn't have to use RCA cables, if you had both hooked up that could cause your DVD/VCR unit to not work properly and only get a partial feed to the TV. I hope this helps a little. Good luck.
Jun 17, 2008 | Gateway AR-230 DVD Recorder
Picture of dvd wont play
just bought a new car with one of these dvd players. when i put a dvd in, the sound is working fine but the screen says it cant show the picture because the car is in motion
Mar 21, 2008 | Eclipse AVX5000 Car DVD Player
Televison & Video Logo
50 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
