Question about Uwatec Aladin Tec 2G 2 Gauge Dive Computer Console SCUBA Equipment
Is the battery for the Uwatec Aladin Tec 2G 2 Gauge Dive Computer Console - owner changeable?
  • 60 Answers
Unfortunately no it is not. Although it may be possible to do this yourself what the service centre will do is pressure test the unit after battery change to ensure that the computer is still accurate at depth and water tight of course. Hope that helps
Posted on Nov 08, 2010
Problem E 6 comes up on my uwatec smart com
I have a smartcom very nice dive computer this issue can ONLY be repaired by scubapro themselves the smartcom is obsolete they will give you trade dollars toward a galleo or luna which are better dive computers
Feb 05, 2013 | Scubapro UWATEC Smart Com Console Dive...
Atom 2.0 keeps switching off. Please help.
Has the battery become low in power? Most dive computers when low on power will shut down to preserve any previous dive data stored on them. Unfortunately there is no user changeable parts and it will need to go to an authorised repair shop. Try Googling your local scuba shop for service advice. Hope this helps.
Oct 30, 2010 | Oceanic ATOM 2.0 COMPUTER WATCH Scuba Gear
Extremely short battery life. How to fix?
Battery life is completely dependant on how often you use the computer to dive with. Batteries should generally be changed every two years regardless of use. An authorised dealer will also use the best recommended battery for the unit and not use cheap imported batteries. Hope that helps
Sep 19, 2010 | Uwatec Aladin Tec 2G Wrist Computer SCUBA...
I am looking for a wristband for a uwatec aladin prime dive computer, can't find it!!!!thank you for your time and wish you a good day.
Hello replacement wrist bands are available from any Uwatec stockist (They may have to order it for you) Try speaking to your nearest Scuba store. Hope that helps.
Sep 03, 2010 | Uwatec Aladin Tec 2G Wrist Computer SCUBA...
User manual needed
Bit confused by your question as you cant download a computer!! If your after the software for your Aladin try ebay or order it from any Scuba store that stocks aladin pro computers. Hope that helps.
Feb 20, 2010 | Scuba Diving & Snorkeling
Old consol computer 1996. I would like to get the battery status
It really depends on the model number, if you can pop it out of the console you will be able to look up the model number. Hope that helps
Apr 16, 2009 | Scuba Diving & Snorkeling
Jtrak software hangs during IR download
I'm afraid I can't solve our problem, but maybe you can solve mine, I'm in need of the drivers for the USB IrDA listed above, any chance of some help? Thanks.
Mar 20, 2009 | Uwatec Aladin Prime 3 Gauge Computer...
How and why scuba gauges give a diver critical information while scuba diving?
Scuba gauges give a diver three very important pieces of information: 1. Time 2. Depth 3. Air Consumption This information enables a diver to stay within safe time and depth limits and avoid running out of air. There are many different devices on the market to help with this, from simple gauges to complex digital consoles. Time If a diver is not using a dive computer to monitor their nitrogen, they dive according to approved dive tables. To use dive tables properly, a diver needs to track their downtime. This can be done with a good dive watch. Two things make a good dive watch: water resistance and a rotating bezel. 1. Water Resistance. Good dive watches are rated to a depth in meters or feet (e.g. 200 feet) or a pressure rating in atmospheres (e.g. 4atm). Even though most divers probably won’t dive below 130 feet (the recreational dive limit), a good dive watch should be rated to 200 feet. Note: There is a difference between “water resistance” and “waterproof”. A “waterproof” watch is what you would wear in the shower, but would probably start leaking at 15-20 feet. 2. Rotating Bezel. A bezel is an adjustable ring on the face of the dive watch with a pointer indicator. At the beginning of a dive, the pointer on the bezel is aligned with the minute hand where it stays though out the dive. At the end of the dive, you compare the difference between the bezel and the minute hand to find out the length of the dive. The bezel should only move “counterclockwise”. It is possible to accidently move the bezel during a dive. Because of this, watchmakers make sure any accidental movement will turn the time in a conservative direction, making the dive longer rather than shorter. Depth Another important part of scuba gauges is a depth gauge. A depth gauge enables a diver to keep track of their depth even if they cannot see the water’s surface. Gauges can be either an analog (needle-and-dial) device or a digital device. Both work in the same way. They measure the surrounding water pressure and convert this into an accurate reading of your depth. Another feature of a good depth gauge is a maximum depth indicator. This tells a diver their maximum during a dive and must be reset after each dive. Air Consumption Another equally important part of scuba gauges is a submersible pressure gauge (SPG). This is connected to the first stage with a high-pressure hose and measures the pressure of the air in the tank. The SPG is much like the gas gauge on a car. At the beginning of a dive, a diver starts with a full tank. This should be about 3000 psi or 200 bars. As the diver breathes during the dive, the gauge will move slowly downwards. This allows the diver to have enough air left in the tank to: 1. Make a slow, safe ascent 2. Make any necessary decompression stops 3. Inflate their BCD once at the surface 4. Breath from the regulator if the surface conditions are rough A submersible pressure gauge also allows a diver to stop diving with air still in the tank. This keeps contaminants from entering the tank due to no air pressure. Wrist Depth Gauge Scuba gauges come in two basic styles. Stand alone gauges or gauge consoles. Stand alone gauges such as a wrist mounted depth gauge or a submersible pressure gauge attached to the first stage of a regulator are great backups when using digital gauges. Gauge consoles allow divers to have all their gauges in one place. Although less easy to read, analog gauges sometimes give slightly more accurate readings than digital gauges, particularly at shallow depth. Submersible Pressure Gauge Choosing Scuba Gauges When choosing scuba gauges, remember to look for: 1. Easy-to-read numbers 2. Luminescent dial or back lighting options 3. Rotating/swivel mounting 4. Easy disassembly for cleaning or replacing parts 5. Good warranty
Dec 01, 2008 | Aeris Max Depth Analog 2 Gauge Console
Uwatec Aladin Tec 2G 2 Gauge Dive Computer Console SCUBA Equipment Logo
433 people viewed this question
Top Uwatec Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you an Uwatec Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
