Question about Toys
How to install 2 controllers - Toys
  • 1,498 Answers
Hi David,
Where to begin? I guess the best place to start would be posting the question again with the make, model, and as much detail as possible.
Don't worry. This happens a lot. A problem that takes a significant portion of your attention for any period of time can embed the details in your mind so completely they are filed under 'common knowledge', something everyone is privy to.
We are good, just not clairvoyant.
Again, don't worry about it
Best regards
Mike
Posted on Nov 08, 2010
Frustrated??... Cannot Restore Audio/Sound?
Please check in c: drive if there is SWSETUP if so install drivers from there else use this link and install Driver Acer TravelMate 4100 Windows XP Acer Driver Support Centre
Feb 17, 2014 | Acer TravelMate 4100 Notebook
I have been playing the sims 2 for a long time and have to re-install the double deluxe onto my new laptop. However, the process always stops at 2% with a support controller error and tells me that th
If You are installing it from disc then the disc is not written exactly what it should be. You can download it from torrent for free. Just search for the sims 2 pc full game torrent.
Dec 19, 2013 | Maxis Sims 2 Double Deluxe for Windows
How to install rear struts on a 1999 llexus
Lexus Car ES, IS, LS 1998-06
Coil Spring Rear Suspension
Print
Hub & Bearings
Adjustment
Check the backlash in bearing shaft direction and the axle hub deviation. Maximum for backlash should be 0.0020 in. (0.05mm) and for axle hub deviation 0.020 in. (0.05mm).
Fig. Checking wheel bearings for excessive play
NOTE The rear wheel bearings are non-adjustable. If the wheel bearing is out of specifications, replace the wheel bearing.
Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Raise and safely support the vehicle.
  3. Remove or disconnect the following:
    Rear tire and wheel assembly Rear stabilizer link Rear axle shaft nut Rear disc brake caliper and disc Speed sensor Parking brake assembly at the wheel hub No. 1 and 2 upper control arm assembly No. 1 and 2 rear suspension arm assembly Toe control link Rear axle from hub assembly using a plastic hammer No. 2 rear wheel bearing dust deflector using a screwdriver 4 bolts and rear axle hub and bearing assembly from the axle carrier assembly
To install:
  1. Install or connect the following:
    Hub on the carrier and tighten the bolts to 52 ft. lbs. (70 Nm) No. 2 rear wheel bearing dust deflector using a screwdriver Rear axle into hub assembly No. 1 and 2 upper control arm assembly. Torque the new nut to the No. 2 rear upper control arm to 52 ft. lbs. (70 Nm). Temporarily tighten the No. 1 arm bolt. No. 1 and 2 rear suspension arm assembly. Temporarily tighten. Toe control link. Torque new nut to 52 ft. lbs. (70 Nm). Rear stabilizer link. Torque to 20 ft. lbs. (27 Nm). Parking brake assembly at the wheel hub Rear speed sensor Rear axle shaft nut. Torque to 214 ft. Lbs. (290 Nm) and stake the nut with a chisel and hammer. Rear brake disc and disc brake caliper
  2. Adjust the parking brake.
  3. Stabilize the suspension as follows :
    1. Install the wheel(s).
    2. Lower the vehicle and bounce it up and down several times to stabilize the rear suspension.
    3. Raise the vehicle.
    4. Remove the wheel.
    5. Jack up the rear lower suspension armplacing a wood block in between. Apply a load to the suspension so that the lower suspension arm is plkaced in a horizontal position.
  4. Fully tighten the No. 1 rear upper control arm assembly to 119 ft. lbs. (161 Nm).
  5. Fully tighten the No. 1 rear suspension arm assembly to 70 ft. lbs. (95 Nm).
  6. Fully tighten the No. 2 rear suspension arm assembly to 119 ft. lbs. (161 Nm).
    NOTE If it is necessary to replace the hub or bearing, replace the components as an assembly.
    Rear tire and wheel assembly If equipped with rear disc brakes, the caliper mounting bolts. Leave the brake line connected and suspend the assembly out of the way. Brake rotor or drum 4 bolts and pull off the rear axle hub O-ring
To install:
    Hub on the carrier and tighten the bolts to 59 ft. lbs. (80 Nm) Rotor or drum Caliper, f equipped with rear disc brakes and tighten the bolts to 34 ft. lbs. (64 Nm) Wheel
  2. If equipped with air suspension, move the height control switch in the trunk area to the OFF position.
    Negative battery cable Rear wheel(s) Height control sensor link from the lower control arm Anti-lock Brake System (ABS) speed sensor and wiring harness Brake caliper bracket from the rear axle carrier by removing the 2 bolts. Support the caliper with a piece of wire. Brake rotor Parking brake shoes and cable Cotter pin, lock cap and the nut holding the halfshaft to the rear axle Suspension member brace by removing the 2 bolts Halfshaft bolts and washers Halfshaft from the vehicle Strut rod
  4. Place matchmarks on the adjusting cam and body for the No. 1 control arm.
  5. Remove or disconnect the following:
    Nut and adjusting cam Nut on the axle carrier side of the No. 1 lower control arm Separate the control arm from the axle carrier No. 1 lower control arm Stabilizer bar link from the No. 2 lower control arm.
  6. Place matchmarks on the adjusting cam and body.
  7. Remove or disconnect the following:
    Nut and adjusting cam from the No. 2 lower control arm Nut and bolt holding the No. 2 lower control arm to the axle carrier No. 2 control arm from the vehicle Nut and bolt on the lower side of the strut assembly 2 upper control arm set nuts and bolts Axle carrier with the upper control arm
  8. Secure the axle carrier in a vise.
  9. Remove or disconnect the following:
    Nut holding the upper control arm to the axle carrier and remove the control arm Dust deflector. Use a suitable prytool. Oil seal
    Fig. Removing the oil seal (inner)-LS 430
  10. Remove the 2 bolts and nuts and shift the backing the plate towards the hub side (outside).
  11. Remove or disconnect the following:
    Axle hub
    Fig. Removing the axle hub from the axle carrier-LS 430
    Backing plate. Inner race (outside) from the axle hub
    Fig. Removing the inner race (outside) from the axle hub-LS 430
    Oil seal (outer) from the axle
    Fig. Removing the oil seal (outer)-LS 430
    Snapring from inside the axle housing Bearing from the axle housing
To install:
    New bearing to the axle housing Snapring to the axle carrier, using snapring pliers New outer oil seal. Coat the oil seal lip with multipurpose grease.
    Fig. Installing the oil seal (outer)-LS 430
    Backing plate to the axle housing. Do NOT install the bolts or nuts at this time. Inner race (inside) to the axle housing Axle hub to the axle housing Backing plate in position. Tighten the bolts and nuts to 43 ft. lbs. (59 Nm). New oil seal (inner) to the axle housing. Coat the oil seal lip with multipurpose grease.
    Fig. Installing the oil seal (inner)-LS 430
    New dust deflector. Be sure to align the hose for the ABS speed sensor in the dust deflector and axle carrier. Upper control arm to the axle carrier by installing the nut. Tighten the nut to 80 ft. lbs. (108 Nm). Axle carrier and upper control arm to the vehicle as an assembly 2 upper control arm set bolts and tighten the bolts to 121 ft. lbs. (164 Nm) Bolt and nut holding the strut to the axle carrier. Tighten to 101 ft. lbs. (137 Nm). Bolt and nut connecting the No. 2 lower control arm to the axle carrier. Tighten the bolt to 60 ft. lbs. (81 Nm). Nut and adjusting cam to hold the No. 2 lower control arm to the body. Align the adjusting cam marks and tighten the nut to 57 ft. lbs. (78 Nm). Stabilizer bar link to the No. 2 lower control arm and tighten the nut to 48 ft. lbs. (65 Nm) No. 1 lower control arm to the axle carrier and body. Install the nut to hold the No. 1 lower control arm to the axle carrier. Tighten the nut to 43 ft. lbs. (59 Nm). Nut and adjusting cam to hold the No. 1 lower control arm to the body. Align the matchmarks and tighten the nut to 57 ft. lbs. (78 Nm). Strut rod to the axle carrier and body. Install the bolt and nut to hold the strut rod to the body. Tighten to 57 ft. lbs. (78 Nm). Bolt and nut to hold the strut rod to the axle carrier. Tighten to 136 ft. lbs. (184 Nm) Parking brake shoes and cable Outboard joint side of the halfshaft and align the matchmarks on the side gear shaft and the halfshaft. Coat the threads with clean oil and install the hexagon bolts. Tighten bolts to 61 ft. lbs. (83 Nm). Suspension member brace with the 2 bolts. Tighten the 2 bolts to 37 ft. lbs. (50 Nm). Nut to hold the halfshaft to the rear axle. Tighten the nut to 213 ft. lbs. (289 Nm). Lock cap and cotter pin Brake disc to the axle hub with the matchmarks aligned. Install the 2 screws and tighten the screws to 48 inch lbs. (5 Nm). Brake caliper to the vehicle and install the 2 bolts. Tighten the bolts to 77 ft. lbs. (104 Nm). ABS speed sensor and wiring harness Height control sensor link with the matchmarks aligned. Tighten the nut to 48 inch lbs. (5 Nm). Rear wheel(s) Negative battery cable
  2. Lower the vehicle and turn ON the air suspension switch.
Fig. Exploded view rear carrier assembly, hub and bearing-
  2. Remove or disconnect the following:
    WARNING Be careful not to damage the boot and ABS sensor
    Rear wheel(s) Height control sensor link from the lower control arm Anti-lock Brake System (ABS) speed sensor and wiring harness Brake caliper bracket from the rear axle carrier by removing the 2 bolts. Support the caliper with a piece of wire. Brake rotor Parking brake shoes and cable Toe control link Separate upper control arm assembly Shock absorber from axle carrier Suspension arms No 1 and 2 from axle carrier Rear axle from carrier
    Wheel bearing dust deflector 4 bolts and axle & bearing hub assembly
To install:
    4 bolts and axle & bearing assembly. Tighten to 48 ft. lbs (65 Nm) Rear wheel bearing dust deflector Rear drive axle Upper control arm. Temporarily tighten No 2 and No 1 suspension arms. Tighten to 52 ft. lbs. (70 Nm) Shock absorber. Temporarily tighten Toe control link. Tighten to 37 ft. lbs. (50 Nm) Fully tighten upper control arm. Tighten to 52 ft. lbs. (70 Nm) Height control sensor Parking brake shoes and cable Speed sensor Rear disc brake caliper Fully tighten shock with new nut to 52 ft. lbs. (70 Nm) Rear tire
  2. Inspect and adjust rear wheel alignment
  3. Check ABS speed sensor signal
    Rear wheel Wheel speed sensor Axle halfshaft Brake caliper and rotor Parking brake shoes Parking brake cable No. 1 lower suspension arm bolt No. 2 lower suspension arm bolt Toe control link Upper ball joint Axle carrier from the vehicle
  3. Press the hub out of the wheel bearing, then remove the backing plate.
  4. Remove the snapring, then press the wheel bearing out of the axle carrier.
To install:
NOTE Use a new toe control link nut for assembly.
  1. Installation is the reverse of the removal procedure, while using the following torque values:
    Backing plate bolts: 43 ft. lbs. (59 Nm) No. 1 lower suspension arm bolt: 55 ft. lbs. (75 Nm) No. 2 lower suspension arm bolt: 81 ft. lbs. (110 Nm) Toe control link nut: 36 ft. lbs. (49 Nm) Upper ball joint nut: 80 ft. lbs. (108 Nm) Brake caliper support bolts: 77 ft. lbs. (104 Nm) Rear wheel lug nuts: 76 ft. lbs. (103 Nm)
Fig. Exploded view rear Axle carrier and hub assembly-ES 330
    Rear tire and wheel assembly Brake caliper support bracket Brake rotor Skid control sensor wire 4 bolts and rear hub and bearing assembly Skid control sensor
To install:
    NOTE Inspect bearing back lash and hub deviation
    Skid control sensor Rear axle hub and bearing assembly with 4 bolts. Tighten to 59 ft. lbs. (80 Nm) Skid control sensor wire
    Rear disc Rear disc brake caliper assembly. Tighten to 46 ft. lbs (62 Nm) Flexible brake hose Rear tire and wheel
  2. inspect and adjust rear wheel alignment
Stabilizer Bar
  1. Remove the rear wheels.
  2. Remove the 2 nuts and left stabilizer bar link. If the ball joint turns together with the nut, use a hexagon wrench (5 mm) to hold the stud. Repeat for the right side.
  3. Remove the 8 bolts, 2 No. 1 brackets and 2 bushings. Two types of bolts are used, so make sure the correct bolts are installed.
  4. Remove the stabilizer bar.
To install:
  1. Install the stabilizer bar.
  2. Install the bushing and bracket with the 2 bolts and tighten to 14 ft. lbs. (19 Nm). Install the bushing to the inner side of the bushing stopper on the stabilizer bar.
  3. Connect the stabilizer bar links and tighten the nuts to 29 ft. lbs. (39 Nm). Repeat for the right side.
  4. Install the rear wheels.
  5. Inspect and adjust rear wheel alignment.
Strut & Coil Spring
    CAUTION Do NOT remove the center nut to the strut at this time. The spring on the strut is under high pressure and can cause serious injury.
    No. 2 luggage compartment trim cover Left and right deck side trim box Rear luggage compartment trim cover Front luggage compartment trim cover Left and right side luggage compartment trim covers Rear wheel Rear wheel fender liner No. 2 differential support protector Rear suspension member brace Rear No. 2 lower control arm Mounting bolts and strut assembly
  3. Secure the strut in a vise.
  4. Compress the coil spring
    Upper strut retaining nut Suspension support Upper insulator Bumper Coil spring Insulator
Dec 26, 2011 | 1999 Lexus ES 300
How do i replce ball joints on a 99 pontiac sufire
Lower Control Arm Ball Joint Replacement Removal Procedure Tools Required J 43828 Ball Joint Separator
  1. Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
  2. Remove the tire and wheel assemblies. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
  3. Remove the stabilizer shaft link. Refer to Stabilizer Shaft Link Replacement .
  4. Remove the wiring harness from the lower control arm.
  6. Remove the cotter pin (1) from the ball joint (3).
  7. Remove the nut (4) from the ball joint (3).
    Notice: Use only the recommended tools for separating the ball joint from the knuckle. Failure to use the recommended tools may cause damage to the ball joint and seal.
  9. Remove the ball joint from the steering knuckle using the J 43828 .
  11. Remove the lower control arm front (1) and rear (4) mounting bolts.
  12. Remove the lower control arm (1) from the vehicle and place in a vice.
  13. Drill out the 3 rivets (3) retaining the ball joint to the lower control arm (2).
  14. Use a 3 mm (1/8 in) drill bit in order to make a pilot hole through the rivets.
    Finish drilling the rivets with a 13 mm (½ in) drill bit.
  15. Remove the ball joint (4) from the control arm (2).
Installation Procedure
  1. Install the ball joint (4) into the control arm (2).
  2. Install the 3 ball joint bolts (3) and the nuts (1). Follow the instructions in the ball joint kit. Tighten the ball joint bolts (3) according to the specifications in the instructions.
  4. Install the lower control arm (2) to the front suspension support (1)
  5. Notice: Refer to Fastener Notice in the Preface section.
  6. Install the lower control arm front (5) and rear (4) mounting bolts.
  7. Tighten • Tighten the front bolt to 107 N·m (79 lb ft). • Tighten the rear bolt to 110 N·m (81 lb ft).
  8. Install the lower ball joint stud (3) to the steering knuckle (2).
  9. Install the ball joint stud (3) through the steering knuckle (2).
  10. Install the ball joint nut (4).
  11. Tighten
    Tighten the ball joint nut to 55 N·m (41 lb ft) plus 180 degree rotation minimum-65 N·m (50 lb ft) plus 180 degree rotation maximum to install the cotter pin.
  12. Install the wiring harness to the lower control arm.
  13. Install the cotter pin (1).
  14. Install the stabilizer link to the lower control arm. Refer to Stabilizer Shaft Link Replacement .
  15. Install the tire and wheel assemblies. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
  16. Inspect the front wheel alignment. Refer to Wheel Alignment Specifications in Wheel Alignment.
Sep 15, 2011 | 2003 Pontiac Sunfire
How do i change blower motor resistor on 99 jeep grand cherokee
Welcome to FIxYa.com
Blower Motor Resistor and Controller Replacement
Image Blower Motor Resistor Or Controller/Power Module Remove/Install
REMOVAL
1. Disconnect and isolate the batten' negative cable.
2. Depress locking tab and unplug the wire harness connector from the blower motor
resistor or controller (power module).
3. Depress locking tab and unplug the resistor or controller connector from the blower
motor.
4. Remove the 2 screws that secure the blower motor resistor or controller to the
heater-AC housing.
5. Remove the blower motor resistor or controller from the heater AC housing.
INSTALLATION
1. Install the blower motor resistor or controller to the heater AC housing. The
housing is indexed to allow (controller power module) mounting in only one
position. Tighten the mounting screws to 2.2 Nm(20 in. Lbs.).
2. Plug in the wire harness connector to the blower motor resistor or controller.
3. Plug in the connector from the blower motor resistor or controller to the blower
motor.
4. Connect the batten' negative cable.
Thank you for using FixYa.com
Regards, Lee Davidian
Nov 22, 2010 | 1999 Jeep Grand Cherokee
Failed Error During Installation. MSI.dot4wrp...Error Code 2753' Message Displays on the Computer in Windows XP and Vista
This is an internal installation error. There can be 2 solutions:---- Solution 1:-- Find all of the hpqwrg files and delete them before installing the software:
  1. Click Start .
  2. Click Search ( Find for Windows 98).
  3. Click Files and Folders .
  4. In the Named entry box, type hpqwrg .
  5. Set the Look In entry box to C: .
  6. Click Search Now ( Find Now for Windows 98).
  7. Click Edit , and scroll to Select All .
  8. Delete all files pertaining to hpqwrg . There will be approximately five to six files.
  9. Be sure to empty the recycle bin of these files also.Solution 2:---- Completely uninstall the higher version of software and reinstall the lower version first, follow the steps below in order:
    1. Uninstall all of the HP Photo and Imaging software (for both of the products). (The uninstall program can be found in theControl Panel in Add/Remove Programs ).
    2. Re-install the lower version of the software.
    3. Re-install the higher version of the software. Thank you Sir.
Sep 27, 2009 | HP OfficeJet J4580 All-In-One Laser...
Help me immediately, please
Actually, the "kit" is a DIMM that plugs into the controller on the right side of the copier (when looking at it from the back of copier) On this model, you need to add 64mb of RAM if you want to add functionality to print and scan, along with the DIMM. Yes, there are 2 different DIMM's for this,....one is Print and one is Print/Scan.
PS: there is a kit to install said items that includes buttons for the controll panel and DIMM, however, the memory is separate (laptop memory or SO DIMM)
Jun 29, 2009 | Ricoh Aficio 1035 Copier
There is no sound drivers are installed and all text is shaded
Hi
This is the software issue. Need to install the appropriate software to reslove this issue.
1.Ethernet controler - Need to install the chipset driver and the Lan driver
2.Pci bus device - Chipset driver
3. sm bus controller - After installation of the Chipset driver - Right click on the sm bus controller and update the driver - select install from specific location - i will chose the location- Select the model and hardware type as thermal sensor
next - follow the instruction.
4. video controller - Need to install the VGA or Display driver
5. video controller (vga compatiable) - Need to install the VGA or Display driver
With regards
anand_anj2005@hotmail.com
Apr 12, 2009 | Computers & Internet
No sound from soundBlaster Audigy 2 ZS PCI Internal sound card
1st Download Driver from this site Creative Sound Driver
Installation of Sound Card.
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Multimedia Controller or Audio Control the yellow Question Marks sign on it.
  • Right click on Multimedia Controller and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
Jun 28, 2008 | Creative Labs Soundcards: Sound Blaster...
Sony Dual DVD +/- RW
set the hard drive to master and the dvd to slave
Jan 24, 2008 | Computers & Internet
Toys Logo
48 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
