Question about LG Televison & Video
What are the best tv settings for lg ld 950 3 d tv
2 Suggested Answers
gopakumarg43
  • 74211 Answers
SOURCE: tv set up code for LG 42 ld 3000
Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
There is code list posts. Pull up older posts there. Sky setup codes and setup proceedings are described in detail.
Posted on May 19, 2012
My lg Le 1415m1 has limited flow pressure have replaced wash pump motor still did not fix
LG LD-1415M1 Support: Find Manuals & Warranty Info ' LG ...
www.lg.com/au/support-product/lg-LD-1415M1
LG ElectronicsProduct Support. Home Appliances; Dishwashers; LD-1415M1. LD-1415M1 ... What should I do Low Rinse Aid indicator lightens up? Why is water not supplied ...
LG ElectronicsHome Appliances; Dishwashers; LD-1415M1. LD-1415M1. Search For ... What should I do when dishes are kept in a dishwasher after a cycle? Are plastic or ...
Nov 19, 2015 | LG Dishwashers
Vertical IC of LG TV model 21FD1RB-LD
It's preset @ Factory in Chipset, Follow You're Warrante Procedure's
Jan 21, 2014 | Televison & Video
WESTINGHOUSE LD-4655VX CODE FOR XFINITY REMOTE
The Westinghouse LD-4655VX TV has code compatibility with Sony TVs (http://westinghouseelectronics.com/wp-content/uploads/2012/06/Remote_Codes_2012.pdf). I accidentally discovered that the Sony TV remote RM-YD040 works with my he Westinghouse LD-4655VX (because I have both TV sets).
Feb 02, 2012 | Televison & Video
Hi i'v bought a LG LD 310 lcd tv and i want to
I tried this.. and it works perfect for the video.. but there is no audio.
Is there any specific setting to be made in TV or my laptop?
I have Dell laptop with Win7, because I dont see any option to enable audio..
Aug 01, 2011 | LG Televison & Video
Hi I have an LG LD - 14AW23 dishwasher. It shows an IE error (no water) but it fills, stops and then gives the error message. What's thye problem? Many thanks, John
Hi
Error code IE on LG dishwasher means Inlet error. This error comes up when the Water Supply Tap is closed or Water Supply is shut off. If water supply is turned on then make sure that the Inlet Hose is not kinked and water Pressure is not low (should be above 10 psi). Next thing to check for is Water Inlet Valve, measure the electric resistance of Inlet Valve. (950-1300 ohms) Make sure the filter of Inlet Valve is not clogged.
Hope this helps... Please post back for further assistance.
Daniel
Mar 26, 2011 | LG 24 in. LDF 7811 Built-in Dishwasher
How do i disable the locked key, LG TV is LG-21FC1RB-LD
Hello
In most LG sets, this trick works and unlocks the TV. Just try and see whether it works with your TV or not. Ok
When you asked for the code, enter 7,7,7,and then 7.
Wish you good luck.
Feb 21, 2011 | LG DU-27FB32C TV
I have an LG dongle for an LD 790 TV. The set incorporates BBC Iplayer hence the need for the dongle. However when I use iplayer the screen freezes after a minute or two and the buffering icon kicks in. My...
LG 42 LD 790
When watching tv if the programme goes to an outside interview a brocken white line appears at the top of the screen. when the programme returns to the studio the screen is fine. what is the problem please.
Jan 04, 2011 | Televison & Video
Stopped Working Mid-Cycle
blockage in outlet pipe
Chris
Lg durban
031-7165444
Jan 29, 2009 | LG 24 in. LD-12BW5 Free-standing...
LG ld-14aw2 dishwasher
IE is inlet error, displayed when "Not reached to the normal water level in spite of 10 min. water supply"
Possible cause:
  • The Water Supply Tap is closed.
  • The Water Supply is shut off.
  • The Inlet Hose is kinked.
  • The Water Pressure is very low.(below 10 psi)
  • Inlet Valve is OK?
  • The filter of Inlet Valve is clogged by impure water.
  • The Hall sensor is OK?
  • The Impeller of Air Guide is bound.
Remedy:
  • Take action on Water Supply device.
  • Measure the electric resistance of Inlet Valve. (950-1300 )
  • Clean the filter of Inlet Valve.
  • Check the frequency of Inlet Water by the Test Mode.
  • Replace the Air Braker.
Aug 26, 2008 | LG 24 in. LDF 7811 Built-in Dishwasher
Televison & Video Logo
69 people viewed this question
Computer Repairing
Computer Repairing
