Question about Whirlpool Duet GHW9150P Front Load Washer
Its a Whirlpool Duet washer. The problem is that its Control Locked light is on but teh door could be opened. The cycle type light is flashing and all other light lights are on including remianing time but it would not start.
  • 1073 Answers
SOURCE: Whirlpool duet Front Loading Washer
go over to the end of cycle button and hold in for 3-4 seconds and you have it fixed
Posted on Apr 15, 2008
  • 4 Answers
SOURCE: Whirlpool Duet Washer 'Control Locked'
Press cancel or if that doesn't work unplug the washer from the main socket - this should clear all the settings so that you can reset the washer.
Bev K
Posted on Mar 24, 2009
  • 240 Answers
SOURCE: My Whirlpool duet washer lights flash/beep
probably your door then, look at the door itself, at the latch is it broken? should form a complete square hole with four sides. if broken some part is probably inside lock asm. if complete, look at lock and determine if its in the lock position with door open, a arm will be up preventing the latch from going in. replace as necessary. Old duets (red lights) use standard lock asm same as GE and samsung. New duets (green lights) use whirlpool/new maytag unique asm. New locks come in two interchageable models, German (made in china) and Mexican, Mexican model is more troublesome, get german.
If lights flash during a cycle or other time, its giving a code, note the F code displayed
Posted on Jul 19, 2009
SOURCE: On my Whirlpool Duet GHW9100LW1 front loader. The
hold in the control lock button for a few seconds- it should turn the control lock off.
Posted on Aug 20, 2009
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool duet washer GHW9300PW4 .... The control
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
Door locked with flashing red light on model W10578789
This might work try unplugging it for about 45 -60 seconds and see if it clears the problem. The red light is some type of warning and I would be safe in saying it is a safety device gone bad. Sorry I couldn't be of more help.
Col. Dana Gillespie
Aug 14, 2014 | Whirlpool Duet Steam WFW9550WL 27"...
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer, door locked light on door open no other lights on unable to set control
The control can be locked to keep the buttons from activating during external cleaning or to help from small children starting the machine.
To activate or deactivate press and hold the "end of cycle signal" button for 3 seconds.
Jun 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Duet ht washer control locked. How do I unlock it? Really need your help
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washers however, your whirlpool duet washer can be reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Apr 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Spin light is flashing 1min left in cycle door
Take the bottom panel off. The tech sheet is right there. While at it clean out the pump filter.
Interesting home videos
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Control locked light is on.Can not start the cycle.
Open and close the door. The door has to be opened between consecutive wash cycles.
2. Check the door switch 3. If Door is Locked, Drain the Unit. 4. Check the wire harness connections. 5. Check the touch-pad/LED assembly.
Feb 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Door won't open. door locked light stays on. I
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Thank you !!
Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a control locked alarm on a whirlpool duet washer??
Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off.
Jun 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer GHW9150PW1
Swich off the machine, try some WD40 on the door mechanism (on machine lock, not on the door) and open & shut for a minute or two. Then try the machine, spin only just to try.
Rate pl, if solved, or dont!
Mar 04, 2009 | Whirlpool GHW9150 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
104 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
