Question about Microsoft Computers & Internet
My computer is stuck in the lowest possible resolution, and I have no idea why. One second its fine, the next it just goes down. I tried raising the resolution through display settings in control panel but nothing happens after I apply it. I tried doing that and then restarting it...still doesn't work, I have tried almost everything including looking for driver updates for my monitor and video card but there have been none. Why isn't it letting me raise the resolution?
  • 132 Answers
Reinstall video driver
Posted on Nov 07, 2010
  • Microsoft Master
  • 2,386 Answers
The driver update doesn't work, you need to un-install and re-install the driver...
good day
How can I freeze my screen resolution
http://www.microsoft.com/enable/training/windowsvista/webtext.aspx
Feb 05, 2012 | Toshiba Computers & Internet
I have a Samsung SuncMaster 940BW 19'' LCD Monitor. It's a geat Monitor in my humble opinion in everything, except that since i got it i have one problem with it, and it wasnt possible for me...
This is a common problem with monitors when changing resolution. What probably happened is you may have tried to change the resolution, or an application changed the resolution, to an incompatible resolution.
For example, if you have a tiny little screen it can't display that huge resolution that a 32 inch monitor has. So, your monitor is stuck in that wrong resolution.
To fix this problem, you need to boot into Safe Mode. Restart your computer, and as it is booting up tap F8 a bunch of times, and then select Boot into Safe Mode.
When it boots up, right click on the desktop, click Properties (Windows XP) or Screen Resolution (Windows 7). When the window pops up, click Settings (if on Windows XP, if on Windows 7 skip to next step). From this window, change the resolution back to the basic 800 x 600 screen resolution.
Now, reboot your computer normally. You should be able to see the desktop. Now, you can do the same thing that you did in safe mode and turn up your resolution. BUT, when you change it, if the screen goes BLANK again, DO NOT press anything. After 15 seconds it should go back, and you can try a lower resolution.
Hope this helps! Thanks for using FixYa.
Aug 27, 2011 | Samsung Syncmaster 940BW LCD Monitor
My Windows XP is connected to my Epson Powerlite S3, but the screen is blue with the words Source: Computer (Auto) No Signal on it. When I click "Help" on the projector, it takes me to a screen...
'No signal' and 'unsupported signal' messages mean 1 of 2 things, either the VGA output is off(laptop) or the display resolution is set too high(laptop and desktop). Assuming the VGA cable you are using is good, try this:
Desktop: hook the computer back up too your computer monitor & set the computer to the basic VGA resolution. For windows XP, right click a blank area on the desktop, click 'properties' on the dropdown menu, click settings. Write down the numbers in the 'screen resolution' and 'color quality' boxes!
Drag the 'screen resolution' all the way down to then 'less' side. Then change the 'color quality' to the lowest setting. Click apply, then answer yes (the display will look UGLY - don't worry!!) Now connect your computer back to your projector. If it works, then the resolution you use on your desktop monitor is not supported on your projector. Experiment with different resolutions to see which one looks best on your projector. You will need to change the settings each time you switch monitor to projector.
Laptop: by default the VGA connector on your laptop is off. To turn it on, look for a blue symbol on one of your function (F1, F2, F3...) keys. It looks like an old TV with a line on both sides 'O' (F4 on HP) Press & hold the blue button (on the lower left of the keyboard, usually to the left of control ) and tap the bleu button you just found. Let go & give you're a computer a few seconds to change over. If the laptop screen goes blank, you found the correct button! The display image should now be visible. Repeat this 1 to 2 times to change it back to laptop display.
If you did not see the display on the projector, 2 other issues are possible. First, verify that the VGA output on the laptop is working - connect the laptop to a regular computer monitor & change the display resolution to the lowest settings (see desktop above), then try it again on the projector. If you cannot get an image on a computer monitor, your laptop settings may need to be adjusted in the same dialogue box as the settings. Monitor #1 is the laptop display, Monitor #2 is the external output.
Happy viewing :)
Jun 12, 2011 | Epson PowerLite S3 Multimedia Projector
Hello, well I hooked up my computer to my vizio with a vga cable. At first it worked just fine, then once I tried changing the resolution for a video game, the screen went blue and says "not...
The VGA cabel has vast signal capacity. However, the computer to has as much sigal cacity. The TV also has as much signal capacity as well. The computer in this situation is providing the signals to all devices connected to the insfrusture. However, the computer has a functionality requirements mode. For exaomple, the computer blankout whenever resolution is increased is n consideration of requirng so much power supply for all displays on several powerfun screens of much high defincition capapacity. The more high definition the computer, the possibility of powering signlas to TVs of much least intensity not vise verser.
Jan 11, 2011 | Computers & Internet
My NEC MultiSync LCD 1765 monitor boots up to the lowest resolution available. When I attempt to correct the resolution through the Display Options in my Control Panel Settings, I set it at the highest...
Try connecting the NEC to a different computer, to see if it correctly accepts 1280-by-1024.
If so, then there's nothing wrong with the monitor, and the fault lies with either the video-adapter in your computer, or something messed-up with your installed copy of Windows.
Try replacing the video-adapter.
Dec 29, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
Cant Get Game Resolution To Work With Hdmi
Dont use 1920x1080. Its probably being very heavy for your graphics card. You havent specified what graphics capacities your PC has so I cannot tell for sure. But I play COD MW using HDMI cable on a 1080p TV too and what has worked for me is,
Set the TV resolution to 1280x800 and the same for COD MW. This is the best and safest widecreen option. You can give 1400x900 a try but I am pretty sure 1280x800 will work fine.
Jan 11, 2010 | Video Game Consoles & Games
NO DISPLAY :(
the resolution setting may have been in inadvertently change to one that your monitor does not support you mentioned that you have another monitor that does work with your computer what i would do is to set the video resolution to the lowest possible setting and the turn off the computer and connect the questionable monitor to your computer and reboot if it does come up then you will be able to make changes and find an appropriate resolution for your monitor
Dec 27, 2008 | Samsung SyncMaster 710N 17 in. Flat Panel...
Hi iv pulged my pc in to my samsung ps42q97hd and well i start the pc up and its fine but when it goes to the login in bit the picture starts to go on then off and flickers all the time need help asap...
Check the video resolution.
firstly boot in the lowest resolution possible, then go one by one increaseing the resolution till you get the max possible without flickering.
My guess is that the pc video reloution is to high and/or wrong frecuency.
Jun 13, 2008 | Samsung Televison & Video
Annoying Nuisance on the monitor
Run your system in 'Safe Mode'. Go to Display settings and set lowest possible resolution. Then restart computer and run windows again in normal mode. Should have normal screen. If this will not work - then under safe mode uninstall graphic card. Then run windows with standard ones and in LOWEST possible resolution install drivers again. I have had it many times and it made swear first time.
Oct 28, 2007 | Acer AL1916W 19" LCD Monitor
Connecting to PC
Hi Sarah, You may want to try lowering the resolution of your computer down first before connecting the 42PX5D. Since everything seems to be working except when you get to the desktop then your PC might be set to a resultion that's too high for the LG (am not 100% sure, but I think that LG's max res is 1024 X 768). Try to adjust your PC's resolution while still connected to a regular monitor, right click on any free/clear part of your desktop and click properties. Display Properties window will pop-up, click on Settings tab, adjust Screen resolution towards the left,trym lowest posiible, color quality, again lowest possible. Then hook it up to the LG. If desktop now displays in LG, do the same again but this time going up. Do it by increment and stop when LG screen goes blank. Press escape to go to setting prior to blank. Adjust color quality best setting acceptable to the LG. Good luck and hopes this work out for you. Regards.
Apr 14, 2007 | LG 42PX5D 42 in. Plasma HDTV
Computers & Internet Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
