Question about HP Pavilion a705w PC Desktop
My ethernet controller is not reading - HP Pavilion a705w PC Desktop
    Problem Solver:
  • 8 Answers
First, go to my computer press the right mouse button and choose Properties, and then chose the device manager and make sure of the definition of Ethernet or that it exists, and enable the work ..
If it does not work, you must define the Ethernet card on your computer
Posted on Nov 06, 2011
Need ethernet controller
Hi Ethernet controller is a hardware built in connected to your motherboard and NIC (network interface card ) is a device that you can use if the motherboard does not have a built in Ethernet controler.If the motherboard of your computer do not ahve a built ethernet controler you should go to your nearest store of computer parts where you can purchase it . Ethernet controller and NIC are devices that will provide your computer to have an access to connect from router,pc,modem etc. going to your computer using the Ethernet cable.
4_20_2012_11_44_48_pm.jpgABOVE IS A SAMPLE OF NETWORK INTERFACE CARD
ABOVE IS A SAMPLE OF ETHERNET CORD
Hope my solution will provide you an idea about what your looking for .
Apr 20, 2012 | Computers & Internet
Ethernet controller
IF YOU ARE ASKING FOR A DEVICE DRIVER FOR YOUR ETHERNET CONTROLLER
THEN FOLLOW THESE STEPS
S1 NEAR THE FRONT USB PORTS A BLACK SITCKER YOU WILL SEE
S2 READ IT MT-M 8177-75G THIS WOULD BE YOUR MODEL NUMBER 81777 USUALY UNDER THIS CONFIGRATION AS YOU HAVE TOLD THIS MODEL NUMBER IS ASSOCIATED IF NOT THEN READ WHATEVER IT IS
S3 http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Network+Connectivity&ProductLine=Intel%C2%AE+Desktop+Adapters&ProductProduct=Intel%C2%AE+PRO%2f100+VE+Desktop+Adapter
DOWNLOAD THE DRIVER NETWORK ADAPTER DRIVER FOR WIN XP
Feb 04, 2011 | IBM Netvista Intel Pentium 4 2.4GHz /...
Lan terminal not working
first check for all the drivers in the device manager.... if every thing is perfect in driver side, then check if the ethernet/ lan is enabled....
then check is the light in the ethernet adapter is lit, when you plug any ethenet cable in it... still if it is not working, then finally try to update the latest driver for the ethernet controller.... if nothing works, then buy an pci ethernet card and use it..... you can also buy external cards like usb to ethernet converter... even belkin manufactures usb to ethernet controller....
May 09, 2010 | ASUS P4P800 SE (890552603657) Motherboard
Im having ethernet problems with my inspiron E1505 dell laptop. after a reboot the computer no longer recognizes ethernet plugged into it. the cable has been tested and works fine. the drivers (Conexant...
Your ethernet card is not working and it seems to be damaged so if your laptop in under warranty so replace it free from the service center. Otherwise they will take charges for this replacement.
Regards
Ashish Kumar
Feb 02, 2010 | Dell Inspiron E1505 Notebook
Can't get on internet. Dont have Ethernet Controller Driver
Im guessing u have an Acer pc, do u know which model is it? we need it to look for the correct driver. Did u formated ur pc at any time? maybe thats why u dont have that program.
Oct 31, 2009 | Acer Aspire X1200 Desktop PC - Athlon X2...
Ethernet Controller is missing
You are unable to use the Ethernet, VGA etc. because you have not installed the drivers for the same.
You might have received a Drivers CD(it will read "Drivers and Utilities") which will be in blue color, when you got the computer from Dell.
In case if you haven't received it you can contact Dell on 1-800-624-9897 and request for a Driver CD. I guess this Dimension model is @ End of Life (I mean no more produced by dell) you might have to download the drivers from Dell's support site (www.support.dell.com) you will have to get it downloaded on a different computer and copy on a CD or a Flash drive.
Once you got all the drivers. First extract them in a separate folder
Go to Device manager
Right click on the Ethernet controller (where you see a yellow exclamation)
Click update drivers
Show the path where you have the driver files
Sep 20, 2009 | Dell Dimension 3000 PC Desktop
Need Ethernet controller drivers for FIC P4M-915pd1 motherboard
Download and install UnknownDeviceIdentifier.(its freeware)
http://www.zhangduo.com/udi.html
Once installed, run the program to identify exactly what ethernet card you have. Then you can either post back to get the driver or go to the manufacturer's site to get it. Best of luck.
Greg
Jul 09, 2009 | FIC P4M-915PD1 Motherboard
Motorola SBG900-SiS191 Ethernet Controller
Setup your IP addresses correctly by checking available IP addies in router.
You will have to know your router addie and your available wireless addies (in router). For this you need to enter router configuration (read manual).
Open network properties, tcp/ip properties, check "use following ip addie and enter something like 192.168.1.5 depending on what your router is setup as available.
Enter same subnet as your router.
Enter DNS server addies from you ISP.
Feb 02, 2009 | Arris SURFboard SBG900 Wireless Router...
Inspiron E1505 - Bad ethernet connection
right clik onmy network places chekc your lan card is enable?
if not enable it.
Nov 01, 2008 | Dell Inspiron E1505 Notebook
HP Pavilion a705w PC Desktop Logo
59 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
