The unit goes on and heats well. It doesn't stay on, however. I have cleaned the filter, but after awhile, the unit turns itself off. The red light blinks indicating the unit needs to be reset.
    Problem Solver:
  • 12 Answers
Reset handset first then service the whole ac
Posted on Nov 09, 2010
Is the heat pump cooling itself down? It is a combination heat pump/air conditioner wall unit.
If a unit is in heating mode the outdoor unit is in cooling mode (outside always does opposite of indoor) after a while if there is a build up of ice on outdoor coil unit stops and puts hot gas through outdoor coil to clear it. The indoor fan stops to avoid and heat loss in area served buy unit once this has been done and indoor unit coil is hot again fan will start. This is the correct operation of the unit to save against bust could and reduced efficiency
Dec 31, 2015 | Heating & Cooling
My labtop come and go off can tyou help me sove this problem it not off but when you switch it come in about 30 mint and it goes off
If your laptop stays on for awhile and turns off after about 30 minutes or so, then I'd say that it's likely overheating and shutting itself down to prevent the heat from causing damage. What you can try is using a can of compressed air and blowing it into the vents on your laptop to try and flush out dust that might be clogging the ventilation system. If that doesn't work, then your fan might not be spinning and likely needs to be replaced.
Nov 07, 2011 | Toshiba Satellite P105-S6197 Laptop
The red alert light indicates that the filter needs to be cleaned. I have cleaned it but the light remains on. I have turned the unit of and on again but it doesn't change the light. The unit is...
Tunr the unit OFF & unplug it for 15 minutes. Then plug it back in and turn it on. The electronics should have reset and reverted back to the original factory settings & the red light should no longer illuminate, as long as the filter was reinstalled properly.
Hope this helped you and thanks for choosing FixYa.
Aug 08, 2011 | Heating & Cooling
Furnace goes on red light stays on exhaust fan for heat chamber goes on gas igniter comes on but soon as gas comes on furnace kicks off have to shut off power for furnace for it to reycyckle but same...
Check your filter to make sure it is not plugged. If it is plugged - replace with filter recommended for your furnace. Every manufacture recommends you have your furnace checked and cleaned on an anual basis to keep itrunning safely and at it's top efficiency. If the filter is plugged or the blower wheel plugged, the furnace will shut itself off. Make sure all registers are uncovered - suppply and return registers.
Jan 03, 2011 | Heating & Cooling
We have a Fujitsu Halcyon wall mounted ductless unit (indoor Unit ASU15RLQ). It was installed in December 2007 and we've done regular cleaning of the washable filters etc. Now it is not cooling. There is...
Hi, first of all, you can get a replacement filter by contacting Fujitsu on (973) 575-0381, (866) 952-8324 toll free and you will be told the nearest Place around you where you can get it from.
Secondly, your AC not cooling might be as a result of a clogged filter, which is not pulling good air flow. If that is not the problem, it could be that the refrigerant is low, coils could be dirty, or a thermostat problem.
But i think the red light signifies that you need a new filter..
Take care
Apr 30, 2010 | Fujitsu Heating & Cooling
Starts to power on,then shuts down
Have you checked the filters? I have a Sanyo PLV-75 and had a similar problem.  The normal fan would come on when the unit was first started, then after a few seconds the secondary fan came on and then the unit would shut down.  Called tech support and they asked if I had cleaned the filters. I did it, and it worked great.  Check the manual for where the filters are and hit them first before getting a new bulb.  Hope it helps!
May 24, 2009 | Sanyo PLC XF10NZ Multimedia Projector
Lasko heater shut down
The 5840 has a problem with dust getting on the heater element and turning itself off after 2 minutes running. HERE IS THE FIX. Unplug the unit from the AC outlet, Then using a can of dusting air ( the kind you use to clean a computer key board) aim the compressed air INTO the middle louver of the upper adjustable heater vent and blow out the dust that has gotten on the heater element. ( You are actually blowing into the unit, clearing off the lint/dust that has gotten on the backside of the heater element that you can not see without openning the entire case).You can see the front of the heater element inside the louvers, It's the shinny metal part that looks like a small radiator.It sits behind the middle louver. After blowing out the dust, shake the entire unit to allow the dust to settle to the bottom of the case. Using a vacum cleaner try to vacum out any dust from the LOWER FRONT intake. Once the dust has been blown OFF the heater element, the unit will work just as new and not shut itself down!
Feb 15, 2009 | Lasko Ceramic Heater
Shutdown
Try cleaning the air filter and see if that solves the problem.
May 26, 2008 | Televison & Video
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
