Question about Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1
Only a trickle of hot water is coming out of my faucet. I tried to flush the tank, but only a trickle continues to come out of the hose....am I not doing something right?
Http://www.waterheaterrescue.com/pages/WHRpages/English/Troubleshooting/Tanklets/backflushing.html
The link above gives a list of reasons for the decreased water pressure at your faucet.
As for draining the tank, it sounds like it's clogged with sediment.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
To open a clogged water heater:
Connect a washing-machine-hose to water heater drain valve.
Connect garden-hose to outdoor spigot, and to washing-machine-hose.
Turn on outdoor spigot for 10 seconds and it will open the clogged valve.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Posted on Nov 08, 2010
Drain hot water heater
turn off gas
turn off cold water to heater
connect hose to spickot
place hose end outside
turn on spickot
open hot water faucets in house
wait.
when water stops, turn on cold water for 30-60 sec or so to try to stir up any sentiment in tank
turn off cold water and let drain.
close spickot
turn on cold water
let fill till water start coming out hot water faucets then turn off hot water faucets.
turn on gas and relight pilot.
finish bleeding air from hot water faucets.
set water heater thermostat
Jun 14, 2014 | Rheem 43VP50E2 50 Gallon FVR Natural Gas...
Rust in water heater tank
the tank needs flushed out ! heres how. Water heater manufacturers recommend flushing sediment from your storage type water heater periodically.
If your water heater is gas, set the gas valve to "Pilot" to prevent the burners from coming on while you are flushing it. If your heater is electric be sure to turn off the circuit breakers. With an electric water heater, if the water level drops below the heating elements and the thermostat turns the elements on, the heating elements will probably burn out quite rapidly. Connect a garden hose to the drain valve at the bottom of the tank, Close the shut off valve on the cold inlet to the water heater. open the temperature/pressure relief valve at the top of the tank by lifting the lever. Leave the valve open. Open the drain valve at the bottom of the heater allowing the water to flow out through the garden hose. when the water is clear your finished. close pressure relief valve on top of tank and turn water back on.
Open a hot water faucet in your house, and let it run until no air bubbles come out.
Turn the heater back on, and with gas units re-light the pilot light if necessary. good-day !
Apr 24, 2012 | Water Heaters
Our hot water will last for about 5- 10 minutes then turn luke warm. I have replaced both elements but problem remains . Do you hink it is the thermostat ? thanks chazz
If you have not done so already then turn thermostats up to 140 degrees. You may also try to drain and flush tank to clean out any mineral deposits that could be hurting your effiency. To do this shut off electrical power to heater then connect garden hose to drain valve on the bottom of tank. Run hose to floor drain or other safe area and open drain valve. If it drains good with the water on then let it flush for a couple of mins. then shut incoming water supply off. Let tank drain as far as it will. You may need to open a faucet on the hot side of nearby fixture to break vacumn.
Drain it completly then close drain valve and hot side of faucet.Turn water supply back on and let tank refill. Do this 2-3 times to get inside of tank as clean as possible. Hope this helps you and thanks. P.S. You may need to replace thermostat also.
Mar 28, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Popping noise in water heater. What is it and how do I fix it?
What is probably happening is that you have a build up of minerals on inner tank lining and when unit is heat it expands the tank and the deoosits at a different rate which is what is causing the popping noise.
I would turn power off to your heater and hook a garden hose on to drain valve.Route hose to safe area as the water being drained will be hot. Open drain valve and see if you can get it draining good.If it is then shut off water supply to heater and open hot side of faucet nearby to prevent vacumn from slowing down draining. I would drain as much as I could then close drain valve and faucet and refill tank. I would do this several times to try to get all sediment flushed out.Hopefully this will help with your noise and make your heater last longer and work more effceiently. Good luck and thank you.
Feb 13, 2011 | RELIANCE ELECTRIC WATER HEATER
Black flakes come out when the hot water side of the faucet is used
These black flakes must be in your line or your expansion tank. Remove the filter from your faucet, temporarily, and let just the hot water side run until the water comes out clean. You must flush these black flakes out.
Jan 31, 2011 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
Empty boiler
Turn main water off to the water heater, it may be a valve on cold side coming in to shut off. Next turn power off to the heater and drain the tank the drain will be located near the bottom of the tank.
You will need a water hose to connect to the drain to run water outside. Open a faucet hot side to allow you to drain the tank.
Upon reinstall connect the tank up and fill tank and open up hot side on one faucet at a time to purge out air from system before turning power back on. Make sure you have water flowing from each faucet's hot side before turning power back on.
Jul 02, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Hot water does not last long. Model 82vh40-2 mnf. 05/2005
If the lower heating element burns out the upper element will heat the top part of the tank then shutoff. homw depot/lowes etc should carry elements. 1 turn off breaker, remove element access cover (the 2 panels on the front of the heater) test for electricity at the reset button ( uppermost device in upper panel) to make sure power is off. 2 turn off water (I usually turn off the cold water main to stop water cross feeding into hot supply line back into heater) 3 disconnect the 2 wires on the lower element, test with continuity tester. shhould be no continuity between terminals and tank, but around 10 ohms between the 2 terminals. Check the thermostat for continuity if tank is cold thermostat should be closed ie zero ohms across the 2 terminals.
If stat is bad replace stat; disconnect wires push it up out of the spring clip insert new stat reconnect. If element is bad: drain tank. connect garden hose to tank drain valve, open tank drain valve turn water main on to clear rust sediment and get water flowing. Next remove filter screen from a hot water faucet then turn on ( a hot faucet upstairs or higher than tank drain). Now turn water main off, air will now go in through hot faucet and tank will drain, takes about an hour. Use a water heater element wrench about$10 to remove element(s) make sure no bits of rubber gasket are left in element opening- dig em out with a screwdriver if needed. Insert new element with its gasket and tighten. reconnect wires DO NOT TURN ON ELECTRICITY! BE SURE TO FILL WATER HEATER WITH WATER ! Turn water main back on -air will come out of the hot faucet for several minutes. When water runs without any air sputtering, turn off faucet and replace the faucet filter screen. check element(s) for leaks. turn breaker back on.
Feb 17, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I am getting lots of brown flakes in valves
The brown flakes are most likely rust from either the tank or associated metal piping. They could also be from the anode used in hot water tanks to combat electrolysis. Does the water have a Sulphur" or "rotten egg" smell to it? Are you on a well? There shouldn't be so much, as to plug up the valves. Turn off your heat source to the hot water tank. At the bottom of the tank is a faucet. Hook a garden hose to it, run it out side where the hose lays lower than the faucet if possible and flush the tank untill you have clear water again. You may want to do this a couple of times to be sure you get rid of any sediment in the tank. When you are done flushing, make sure you have the air out of the tank by opening a hot water faucet until it runs clear with no "spurts" of air. Shut the faucet off and turn the gas back on, light the pilot light and see if the problem persists. Also have your water tested. Sears does this for free -just take a sample in and they will tell you what the hardness is.
Jan 15, 2010 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Water flow is reduced to a trickle after only 2 mos. of use with the quick&heat water heater. we are in San Diego and water is nit that hard. Lawrence
Lawrence; there are several potential points that can reduce your water flow. Try these items and let me know. Check hoses under sink for any kinks.......take the aerator off the faucet and run water if trickle is still there then aerator is fine......check the valve that the water comes from and make sure it is turned all the way on. If these do not solve your problem let me know. Thx
Aug 04, 2009 | RTO Waste King AH-780-UL Quick&Hot Instant...
Hot water taps and showers pressure very low cold taps ok
there is a little cap on the hot and cold side above the shut off valves, turn the water off at these valve and take the caps off there are filters in there clean them off and reinstall them that should take care of the problem, you might want to flush the tank while your at it hook a hose to the hot side connector and run it out side or to a sump pump then turn on the cold water and flush it out you can also reverse this procedure by doing it on the cold side
May 24, 2009 | Rheem Tankless water heater for 1-2...
Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1 Logo
199 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
