Question about Canon i80 InkJet Printer
Ink cartridges will not move automatically also how do I download the drivers to another computer as I can't find the disk
  • 132 Answers
Http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/i_series/i80#DriversAndSoftware
Posted on Nov 07, 2010
Keep getting paper jam fault 3618
Hi!
If the error comes up during the initial setup of the printer:
  • Select All-in-One Printers.
  • Double-click the Setup Guide for your printer.
  1. Open the printer access door.
  2. Remove all:
    • orange shipping tape
    • foam pieces
  3. Follow the steps in the Setup Guide to insure that you have properly installed the printhead and ink cartridges.
  4. Close the printer access door.
  5. Press OK to clear the error.
  6. Make a print.
OR
Check the printhead carriage area:
Debris and Obstructions:
  1. Remove any paper, tape or other obstructions from the printhead carriage area.
  2. Gently move the printhead carriage from side to side to see that it moves freely and there are no obstructions.
Ink Cartridges:
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
    NOTE: If the printhead does not move to the center position, press Home, then Maintenance on your printer. Check if the Install Ink Cartridge option is available. If so, select Install Ink Cartridges, press OK, and follow the instructions. Otherwise do the following:
    1. If an error is displayed on your printer control panel or the status monitor on your computer, press Cancel to clear the error.
    2. Go to KODAK All-in-One Printer Downloads and Drivers, select your printer from the All-in-One Printers pull-down list, and download and install the latest firmware version for your printer. Follow the on-screen instructions.
    3. After you upgrade the firmware, press Home on the printer control panel.
    4. Select Maintenance, then press OK.
    5. Select Install Ink Cartridges, then press OK.
    6. Follow the instructions on the control panel LCD.
    7. Go to the next step.
  2. Verify that the labels on the ink cartridges are intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the black ink cartridge into the printhead, then press down firmly until you hear it click into position.
  5. Insert the color ink cartridge into the printhead, then press down firmly until you hear it click into position.
  6. Close the printer access door.
  7. Press OK to clear the error.
  8. Make a print.
Hope this helps.
Apr 19, 2011 | Kodak ESP5250 All-In-One InkJet Printer
Epson Stylus TX400. Refuses to accept either compatable or refilled cartridges?
Epson TX400 is so sensitive in terms of ink cartridges, you can only replace a refilled ink cartridge in this type of printer if the cartridge has an automatic ink reseter chip. When you replace a cartridge in your printer, it will automatically register the ink level in the chip. So you need an ink reseter chip to replace a new refilled cartridge.
Feb 17, 2011 | Epson Stylus TX400 Series
"set ink cartridge" won't go away
Hello. Your ink cartridges need to be set. and if it is not communicating with your computer you need to reload the drivers. ok to reload your drivers, on your computer, click start then right click on computer, then another box will open up. when it does, then left click on properties. then another box will open up. click on device manager. Another box will open up. Look for your printer. You should see it in the list. then what you do is, put the software that came with your printer in your cd/dvd rom drive. then disconnect the cable between the printer and the computer. (NOTE) If you do not have your drivers, then go to www.canon.com, then support, then type in your model number, then go to driver downloads and download your drivers there. If you installed a new operating system on your computer, you will have to download the new compatible drivers for the operating system you have installed. after installing them, then once you locate your printer in that list right click on it. then another box will open up. then click on uninstall. it should uninstall the printer drivers. after that is done, then restart your computer and when your computer restarts, the software for your printer should come up. Then just reinstall the software. after the software is installed, then plug the usb printer cable. your computer should then pop up with a box that says "found new device" It will ask you where to look for the new drivers. if you have the disk that came with the printer, click on that drive that contains the disk with your software. after it installs the new drivers, that should take care of the communication problem. If it does not, then try changing your usb cable. it might be or have gone bad. As far as the message of set ink cartridges, look in the manual on how to set the cartridges. If you do not have the manual, then go to canon support, type in the model number, then download the manual for your printer. That will explain how to set your cartridges. If you set them then you will probably have to realign the heads then you should be all SET. No pun intended. lol Hope this helps. Ron
Sep 08, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Reinstalling printer without disk
http://downloads.lexmark.com/perl/downloads/downloads.cgi
download from here and install drivers again.
also refix your ink cartridge after clean dust and ink powder from it.
Apr 17, 2009 | Office Equipment & Supplies
Shows black ink empty after new cartridge inserted
Replacing the cartridge should resolve this problem: Follow these steps to replace the cartridge:
Installing / Replacing the BJ Cartridge Follow this procedure to replace the BJ cartridge:
1. Make sure the MultiPASS is plugged in.
2. Open the document tray.
3. Lift the document guides to open the ADF (Automatic Document Feeder).
If the ADF (Automatic Document Feeder) does not open easily, slide the document guides outward and then open the ADF (Automatic Document Feeder).
Or slide the Document Feed Lever to either the automatic or manual setting.
4. Pressthingtopress.gif. If installing the BJ Cartridge for the first time, skip to step 6.
Caution: Do not try to manually move or stop the cartridge holder since this may damage the unit. Do not touch the components shown or any metal parts since this may adversely affect operation of the unit and/or affect print quality.
The MultiPASS has an automatic protection feature that helps keep it from overheating. If the cartridge holder does not move, unplug the MultiPASS and let it cool for several minutes. Then plug it in again.
Press thingtopress.gifto move the cartridge holder.
5. Raise the blue cartridge lock lever on the cartridge holder and remove the BJ cartridge.
Caution: Discard the old BJ cartridge immediately according to the local laws and regulations for disposal of consumables.You may want to place it in a plastic bag to keep any residual ink from spilling. Spilled ink can stain any surface; protect yourself and your work area. If removing a BJ cartridge to use one of the optional BJ cartridges, be sure to store the BJ cartridge in the container provided with your MultiPASS. Otherwise the ink will dry and affect print quality.
container.gif 6. Remove the new BJ cartridge from its package, then remove the orange protective cap (1) and tape (2).
Caution: Discard the cap and tape. Never attempt to reattach them to the BJ cartridge print head. Install the BJ cartridge immediately after removing the cap and tape. Spilled ink can stain any surface; protect yourself and your work area.
7. With the label facing outward, insert the BJ cartridge into the cartridge holder. Lower the blue cartridge lock lever until it locks into position.
lockinpos.gif 8. Press thingtopress.gif.
The cartridge holder moves to its home position on the right side of the unit and begins cleaning the BJ cartridge print head. This process takes about 55 seconds.
9. Close the ADF (Automatic Document Feeder).
10. Close the document tray.
Note: If you need to unplug the MultiPASS, wait until the unit is in standby mode (date and receive mode displayed in the LCD). Otherwise the cartridge holder may not be in its home position causing the BJ cartridge to remain uncapped and dry out.
Apr 11, 2009 | Canon MultiPASS C530 InkJet Printer
Mp 145 errors E 5
ud semua cara sy coba g mau juga mas, tlng bantuanya mas.
Apr 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Magenta red will not print red, prints, yellow, I have tried 3 new ink cartridges for the PixmaIP6000D. Problem haappened when my Dell computer drive burned and had to install new drive. Running Windows...
Try unistalling the printer drivers and reinstall the drivers...here's a link in case you cannot locate your driver disk...
http://www.download.com/BJ-Printer-Driver-Canon-Pixma-iP6000D/3000-2116_4-10556279.html
If it still doesn't work, try cleaning the contacts between the color cartridge and the printer... Otherwise, your printer needs repair or replacement.
Nov 29, 2008 | Cannon Office Equipment & Supplies
RX500 and vista
Windows Vista printer and scanner drivers are available for your product. The printer software is available by using the Automatic Software Update service built into Windows Vista. The scanner software is available for download through Epson’s website.
PRINTER DRIVER DOWNLOAD
Please follow these steps to set up your Epson product and automatically download the Windows Vista printer driver for it from Microsoft:
1. Connect the USB cable to your computer and then to your Epson product.
2. When the FOUND NEW HARDWARE window appears, select Locate and Install Driver Software (Recommended).
3. Your Epson product drivers will install automatically. You may need to select this option more than once during installation.
4. Close any open windows on your screen.
5. Try printing.
*NOTE:
-Depending on your system the computer may ask for your Windows disk, if so insert your Windows CD into your CD-ROM drive and click OK.
-As the driver is part of Windows Vista, there is no Status Monitor available for your printer. Some printers may have an INK LEVELS options included as part of the resident driver. Otherwise, the printer does have its own indicators. The LCD will display which cartridge is either low or out of ink.
-If the ink levels do not appear, click GET INK LEVELS to refresh the driver. Ensure the printer is directly connected to the computer as the Ink Levels does rely on full bidirectional communication.
SCANNER DRIVER DOWNLOAD AND INSTALLATION
1. Go to the Epson Support website (www.epson.com/support).
Jul 11, 2008 | Epson RX595 Photo All-In-One Printer
Vista cannot regocnise my rx600
5. Try printing.
*NOTE:
2. Select your model, then select Drivers and Downloads.
3. Select and download the TWAIN Driver and EPSON Scan Utility for Windows Vista. Save the file to your desktop and make a note of the file name in order to easily retrieve it.
4. Double-click the downloaded file and follow the on-screen instructions to complete the installation.
If a message appears indicating “The scanner has not passed Windows Logo testing”, click Continue Anyway. Then click Finish.
5. Re-start your computer before testing the scanner software.
Jan 05, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Change ink cartridges
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
532
Oct 21, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Canon i80 InkJet Printer Logo
old marine
old marine
