Question about Toro Lawn Mower With Toro Power Tools
How do you change the belt on the self propelled toro 22inch recycler mower?
5 Suggested Answers
  • 147 Answers
SOURCE: toro self propelled mower will not move
This is a very simple solution, When you pull the lever it simply pushes a pulley into the belt to make it tight. Most of the time the belt has come off or maybe the cable broke. Turn the mower over and you will see the belt. My money is on the belt off.
Posted on Nov 06, 2008
SOURCE: Toro Lawn Mower Won't Start
this is a very common problem with these toro mowers. the needle valve in the bowl of the carb. is plugged up with dirt or varnish from the fuel. just under the primer bulb there is the carb bowl. it has a nut under it that holds it on remove the bowl and make sure fuel flows constantly while the bowl is off. push up on the float to stop the gas flow. this could be messy and dangerous. careful with the gas. its flammable. best solution is to remove the carb and soak it overnight in a parts cleaner like gunk. caution small parts inside. this happins every year on mine no matter what i do. seems like the orifice is so small it clogs easily. good luck
Posted on Nov 15, 2008
  • 744 Answers
SOURCE: toro 20073 self propeled, walk behind mower-how to replace belt ?
Wait until the mower cools off
1. Remove the drive belt cover from the top of the mower
2. Tip the mower up, being careful to not go too far or the oil and fuels may spill out
3. Remove the mower blade - as I recall the bolt is 5/8" (could be 9/16") You will have to hold the blade from turning (if you have impact tools, this will be much easier)
4. Remove the blade
5. Pull the pulley out or off and remove the belt - be careful to not lose the crankshaft "woodruff" key - it's the little piece of half/moon shaped metal that keeps the pulley from spinning on the crankshaft.
6. Reverse the steps to reinstall
You MUST make sure the blade is tight when you reinstall it. Also, the blade usually fits over a couple of pins - make sure they are lined up properly and the blade is installed right-side up.
Posted on Mar 19, 2009
SOURCE: toro self propelled 22 inch recycler lawn mower start pull cord is "stuck"
Casey,
My son just bought a new Toro self propelled 22" recycler and has had problems on two different occasions. The mower just bogs down to a stop and when he tried to pull the starter cord, it was very VERY difficult to pull. At first I thought the engine had seized up for some reason (no oil?), but we found the problem.
First, disconnect the spark plug wire from the spark plug (to avoid the engine starting); tip the mower on its side and check very carefully the pulley and transmission belt. In his case, a piece of wood had gotten stuck between the belt and the pulley. Removing it fixed the problem (now he mows a little higher so as not to get so close to any debris). (We did have one further problem after that - the engine would not start - not even fire. After pulling and pulling, checking for gas, and checking that the air filter was cleean, we decided to check if the cylinder was flooded - we removed the spark plug, wiped and dried if off, and replaced it. It started right away.)
This belt 'n pulley arrangement isn't the best idea, if you ask me.
Good luck.
Posted on Jun 08, 2009
I have a toro self propelled rear wheel drive mower, I changed the belt and now it won't let me pull the mower backwards. The self propelled works great.
If the new belt is not the same length as the old one it will cause it the not release properly. Even one eighth of an inch too short.
Oct 31, 2016 | Toro Garden
How to replace drive belt on toro recycler
First thing you need to do remove spark plug wire.. Then I would go to the website for Toro have the serial number ready there you will see the full picture of the way it is then go from there that's the best way with out seeing it. Good luck
Sep 15, 2012 | Toro Lawn Mower With Toro Power Tools
Need to know where to look on my mower to find out what info I need to find a new belt for my Toro SR4 Super Recycler.
I believe you will need belt Toro part # 91-2258 Try Partstree.com or call 1-877-798-7278 they are great to work with and can guide you to id your mower and get you the right part.
Jul 05, 2012 | Toro Power Lawn Mower
How do you change the self propelled cable on Toro Model 20005 22 " recycler. Can't figure out how to remove the plastic black cover the cable goes under.
how do you change the self propelled cable on Toro Model 20005 22 " recycler. Can't figure out how to remove the plastic black cover the cable goes under
Aug 27, 2010 | Toro Lawn Mower With Toro Power Tools
I have a 22 in Recycler Lawn Mower. I haven't had it 1 year yet. It is supposed to be self propelled but that quit being self propelled today. thank you in advance donna
turn it over and check the drive belt. it's probably too loose or broken. don't ask me how to fix it, i'm here trying to find out why mine keeps dying.
May 19, 2010 | Toro Lawn Mower With Toro Power Tools
Lawn Mower With Toro Power Tools: I have a toro recycler self propelled and it is ge...
look up answers.com on your magneto.thats what makes your spark.
Apr 28, 2010 | Pool & Spa
Self propel toro mower will not "self propel", nor will it pull backwards
that dont make sense self propel is forward only release handel pull it back could have broke a belt on the pull or wheels are full of grass
Aug 29, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Personal Pace self propel problem.
Your self-propel is probably belt driven. Belts can make an awfully lot of noise when unhappy. Possible it has rolled over and is running on the wrong side of the belt or is worn and just needs replaced. Hope this helps.,
Jun 19, 2009 | Toro Lawn Mower With Toro Power Tools
Toro self propelled 22 inch recycler lawn mower start pull cord is "stuck"
Casey,
Good luck.
May 31, 2009 | Toro Lawn Mower With Toro Power Tools
Self propell toro mower will not "self propell."
Self propell toro mower will not "self propell", nor can i pull it backwards
Oct 03, 2008 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
102 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
