Question about TruTech KLV3112 10 in. LCD TV/DVD Combo
Trutech klv3112 How do you change the time? - TruTech KLV3112 10 in. LCD TV/DVD Combo
    President:
  • 2,777 Answers
On the remote there should be a MENU / SETUP button which allows you to go into an on screen menu that includes the TIME setup.
I used to own this exact device and have set the time before this way... I am trying to find the actual manual for the unit so I can give you step by step instructions but I remember it wasn't all that difficult. Just go into the setup menu and look around, you will definitely find it.
Thanks, let me know, just reply to my answer here and I can help more
Tim
Posted on Nov 07, 2010
Trutech TV/DVD klv3110 spacesaving kitchen manual download
Hiya Rosa,
you can try the manuallslib site they have most of all manuals from old mixing gear through to modern tv/DVD players,
Hope this helps
Kevin.
May 23, 2015 | TruTech KLV3112 10 in. LCD TV/DVD Combo
I have a TruTech KLV3112 10in LCD TV/DVD combo and the DVD door will not open. What do I do?
I would try unplugging it for 5 minutes and then power it back up.
There may be a reset/eject button that you can depress with a pin or paperclip near the door much like an old Macintosh had.
I have long since abandoned this unit and have a Skyview 13" in my Westfalia. You might have to do the same if you need to run DVD's.
Mar 02, 2015 | TruTech KLV3112 10 in. LCD TV/DVD Combo
It's not a problem ... I just want to know what the power requirement is for the Trutech 10" Undercabinet LCD TV/DVD Combo - KLV3112
Hi, it will be in the 9 to 12 volt range probably with about a 2 amp rating. Buying the kind of " universal " power supply with interchangable plugs should do the trick. The actual " adapter " you buy will more than likely be marked as follows 100-240v~ 0-12v dc ( or a solid vertical line over dashes) 2.5a followed by a polarity indicator. Always be careful too when inserting new plug-it should fit snugly but not so that you need to push with much force. thanks for letting me try to help, I hope this was of some assistance. Good luck, Prodzilla
Apr 13, 2011 | TruTech KLV3112 10 in. LCD TV/DVD Combo
Do i need a converter box or attena for this tv??
U require a good antenna no need for a converter box,because this tv is digital tv.
Nov 08, 2010 | TruTech KLV3112 10 in. LCD TV/DVD Combo
I have a spacesaving kitchen 10
I have the same problem as the above question. The picture goes off and there is only sound
Feb 17, 2010 | TruTech KLV3112 10 in. LCD TV/DVD Combo
Comcast dta remote codes for trutech klv3112
I have a Trutech 10 inch under cabinet DVD/TV and needed the codes for the new Digital Adapter that Comcast is forcing everyone to move to. The short answer is that there isn't a single code that will work for what we all need. After much research I have an answer. It's largely unsatisfactory, but its somewhat of a work around. If you use code 10451 you can get the channel up, channel down, the number pad and the "last" button to work. To get volume functional, change the volume lock on the comcast box. To do this:
1. With the TV on, manually set the volume to a medium high setting
2. With the comcast remote, press and hold SET until the red light blinks twice.
3. Enter 9-9-3 (red light blinks twice)
4. Press and release the digit 1 (red light will blink 4 times)
Now, in addition to channel control, you have volume control. I can't do anything about the power button or other functions. However, this at least makes the remote functional.
Good luck to all!
Jan 10, 2010 | TruTech KLV3112 10 in. LCD TV/DVD Combo
Black box in the middle of screen
some one has turned on your closed captions
use your remote and turn it off
Sep 19, 2009 | TruTech KLV3112 10 in. LCD TV/DVD Combo
Transformer has failed in my Trutech M#KLV3112
The transformer should have the input and output rating labeled on the unit itself. Such as input 110vac, output ...... dc.
Jan 14, 2009 | Televison & Video
TruTech KLV3112 10 in. LCD TV/DVD Combo Logo
119 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
