MSN Messenger interference
I have tried all pc settings for webcam and headset and come to the conclusion the only thing the interference can be attributed to is my internet connection.
How can I test the VOIP capabilities of my service ?
  • 4,472 Answers
Try this site.
http://testyourvoip.com/
Good luck,
Lee
Posted on Jun 15, 2008
Cant connect webcam to msn
check you MSN setting. Make sure that your installed webcam is selected for MSN Chats
Sep 16, 2009 | Dell Studio 1537 Laptop
Dell webcam manager working with msn messenger?
if you have the webcam center opened along with with msn then it wont work on either one of them.
you can try these steps tp check if it works for you or not.
1)look for the web cam center system tray icon and right click on it if its there and select exit
and as u said u cant see you self in web cam console --- in webcam console you can only see your self under the doodling tab and only of your webcam is working at that i.e
either you have the webcam center opened or any other messenger or software which turns on your cam then only ull be able to view your cam in webcam console alongside.
Apr 28, 2009 | Dell XPS M1530 Laptop
Webcam working ok with yahoo test but when i go to messanger then viue webcam it comes up not connected i have done some thing wrong can you help please
If you are trying to run both at the same time, you cannot do that for some reason. The connection of your webcam to one blocks the connection with the other.
If you are just trying to run it on messenger, which i am assuming is msn or live messenger, you have to run the connection set up for the messenger itself. I believe that it can be found in the settings menu.
Apr 26, 2009 | Acer Aspire 5610-4648 Notebook
Interferance with sound
Normal 0 If the people you are talking to have speakers they hear you and you will get feed back of your voice. Have them turn down the speaker level or better yet use a headset and this will no longer be a problem.
Hope this helps. Bud
Mar 18, 2009 | Microsoft LifeCam VX-1000 Webcam
Acer crystaleye webcam wont work with msn
I know a lot of people are having problems with the acer cam
if you updated msn try going back to your old version
or if you have'nt updated it you can try that.
The only other thing is to uninstall cam and reinstall
I've had to that so many times on my acer crystal eye cam
Jan 14, 2009 | Computers & Internet
HP WEBCAM DOESN'T WORK WITH INSTANT MESSENGER
Are you using Flash Player on MSN? This sounds like you need to turn on access from the flash player setting menu. This sounds like another issue with the latest update of flash player. Also, you might try 'unchecking' the box for 'use hardware acceleration' in the flash player settings.
Apr 26, 2008 | HP Pavilion dv6000z Notebook
Logitec web cam
You will be required to run an audio setup wizard through the messenger application in order for MSN or Windows Live Messenger to recognize sound using a microphone and produce sound through speakers, headphones, or headsets.
The information in this article will describe the correct procedure to setup audio and video within the MSN or Windows Live Messenger application to achieve proper audio functionality.
trnsp.gif Answer The information in this article applies to the following 3rd party software
MSN Messenger 6.x
MSN Messenger 7.x
Window Live Messenger 8.5
The information in this article applies the following platforms
Windows 98
Windows ME
Windows 2000
Windows XP
Windows Vista
Note: The information in this article is not product specific. For details regarding camera driver and operating system support please see article 3428
Step 1: Getting Started
Before we begin setting up the sound in MSN or Windows Live Messenger, ensure the following is complete:
  • Connect your camera and verify that it is working properly
  • If using headphones, verify that your device is connected and functioning
  • If using speakers, verify that they are functioning properly
  • If using a headset, verify that both the headphone and microphone are connected and working properly.
Step 2: Executing the audio and video setup procedure within the messenger application
This procedure will allow you to assign an audio input and audio output device, as well as assigning the video device of your choice to work with the messenger application. The following example uses Windows Live Messenger 8.5 however, the same procedure can be used for earlier versions of MSN Messenger 6.x and above. MSN Messenger users please skip directly to step 4 below.
Note to Windows Live Messenger users: There are multiple ways to execute the following steps depending on being signed in vs signed out of the messenger application, and which version of Windows Live Messenger is being used. To avoid confusion, please execute the following steps while signed out. We also recommend updating to the latest version of Windows Live Messenger.
1. Sign out of your account.
2. Launch the messenger application (make sure you are not signed in to your account).
3. Locate and click the "Help" drop down button towards the top right corner and select "Show the menu bar"
16480.gif 4. Now click the "Tools" option in the menu bar and select the “Audio and Video Setup” option.
5. Click “Next to begin the setup process.
6. In the “Speaker Setup” window, select the output device you would like to use with the messenger application. This step is specific to speakers or headphones. If your speakers or headphones are USB devices and connected to your computer, select the device by using the drop down menu provided. If your speakers or headphones are connected to your soundcard, the device listed will be the make or model of your soundcard device.
You can also set the desired volume level and click “Play Sound” for an audio sample. Click "Next" once you are comfortable with the your selected options.
7. In the “Microphone Setup” window, select your desired input device from the drop down menu provided.
3172_msnad04.jpg This selection will be specific to a microphone connected to your computer. If your Logitech video camera has a built-in microphone, this option will be presented as “Logitech Mic” with your camera model name in parentheses as shown above.
If you have an external USB microphone or headset device connected to your computer that hosts a microphone, select the devices name or model number in the drop down menu. If your external microphone or headset is connected to your soundcard, the device listed will be the make or model of your soundcard device. Once your device is selected, adjust the microphone volume level to your preference and click next.
Note: The microphone volume level may need to be tested in order to find a comfortable volume level. As a starting point, try setting the level midway and adjust when necessary by re-executing this procedure.
8. In the “Webcam Setup” window, select the video device you would like to use with messenger application. Once selected, you should see a display sample in the window provided. You can also click the “Options” button to make camera specific adjustments. Once completed, click the “Finish” button to apply your changes.
Once you have completed this process, the messenger application should now be configured to the correct audio input (microphone), audio output (speakers or headphones), and video device (webcam) to use when engaging in an audio and or video conversation.
Jan 24, 2008 | Logitech Webcam
Logitech mircrophone
It may be that this person is "messing around" with you, or their speakers are rigged, from my experince, it sounds like your headset is perfectly fine, or your headset microphone switch was toggled on "Off" Msn is just a instant messaging chat, shouldn't have anything to do with your headset.
Nov 29, 2007 | Logitech QuickCam Express Web Camera
 Grubhead
Grubhead
