Question about Kyocera Office Equipment & Supplies
How do you replace replace toner waste unit - Kyocera Office Equipment & Supplies
  • lalaplus2 Nov 07, 2010
    thank you we figured it out ourselves
  • 132 Answers
Which model?
Posted on Nov 07, 2010
Tip
Drum needs to be replaced message,Remove waste toner,Waste toner full
Save money by removing your drum units waste toner yourself.By removing waste toner the drum life will be increased.Remove the waste toner every 3 to 5 thousand prints.
The main cause of drum failure in this model is caused by waste toner build up at the back of the drum,this cause the drum cleaning blade to put more pressure on the drum and.
Slide the platte-ned cover Assembly to the left open the left cover,remove the drum and developing Assembly like you do when you have to remove a paper jam.The drum and developer assy is attached by 2 blue clips,unlock the clips and separate the def and drum.On top of the drum unit the is a plastic plug that you can remove and trough out the toner in a dustbin with plastic bag coverd.Do not use this toner again in the machine.
Reinstall the plug and connect the drum and developer unit with the two clips.Reinstall the unit.
By removing the waste toner regally you will save on service cost as well.
on Dec 05, 2009 | Canon ImageRUNNER 1670F Copier
WHAT DOES CODE C7990 MEAN ON A COPYSTAR CS-1820
Waste toner reservoir overflow
problem (when the total number of
copies is 100 thousand sheets or
more)
• After E31 is displayed, 1,000 sheets
are copied. Or waste toner exceeds
5 g.
Defective waste
toner sensor or
engine PWB.
Shake the process unit from side to side
and turn the power switch off and then on.
If the problem cannot be solved, replace
the process unit.
After replacing the process unit, turn the
power switch off and then on. If the problem
cannot be solved, replace the waste
toner sensor or the engine PWB.
Mar 30, 2011 | Copystar CS-2030 Copier
Erroro19
E019 0000 Waste toner full detection The waste toner full state was detected.Replace the drum unit.
0001Waster toner full detection sensor is faulty. . The waste toner full state was detected continuously for five or more seconds while the main motor was turning.
- Check the connector of the waster toner full sensor. - Replace the waste toner full sensor. - Replace the DC controller PCB.
Mar 10, 2011 | Canon iR 2016i Black and White Copier
KM-1820 machine reports "waste toner
You need to replace the procces unit. The waste toner can not be emptyed the unit needs to be replaced, Some times if you remove the proccess unit and gentally shake it left to right several times and place the unit back in the copier the error will clear, if not you will need to replace the process unit which is a PU-102.
Jan 07, 2011 | Kyocera Office Equipment & Supplies
KYOCERA 1016MFPo ERROR call 7980
Contents: Waste toner reservoir overflow
copies is less than 100 thousand
sheets)
5 g.
Causes: Defective waste
toner sensor or
engine PWB.
Check procedures/corrective measures: Shake the process unit from side to side
the process unit.
Nov 23, 2010 | Kyocera FS-1118MFP Laser Printer
Replace waste toner tank Does it mean that the toner is already used
Open your user manual.
Or get one - go to google or samsung.
The life of the waste toner container unit is approximately 1,250 pages for full color 5% image printing or 5,000 pages for black printing. When the life span of the waste toner container has expired, Replace/Install Waste Toner Tank appears on the display of the control panel,
indicating the waste toner container needs to be replaced. Otherwise your printer stops printing.
To replace the waste toner container:
1 Turn the machine off, then wait a few minutes for the machine to cool.
2 Open the front cover.
3 Pull the waste toner container out of the machine using its handle.
--- above from manual, following is my paraphrasing due to lack of pictures ---
4. remove the container cap from the back side and cap the opening
5. take the new waste container out of its package
6. install the new waste toner container.
___________
You may wish to TRY EMPTYING the waste toner, but you will find toner is the messiest and possibly dangerous (inhallation, etc) stuff you've worked with. it is an extremely find powder and can cause an awful mess and is best disposed of by capping and replacing the container with a new one (shop around to find them).
DO NOT attempt to vacuum up toner - just my personal opinion - I suspect many vacuums may not have fine enough "bags" to capture this intentionally very fine dust. BUT Toner vacuums do exist and some "may" work.
Jul 17, 2009 | Samsung CLX 3160fn All-In-One Printer
Displayed error
sol:
1:you have to replace the drum unit.
or
2:open the drum unit & open waste toner cap &remove the waste toner & close the cap&insret the drum unit into m/c .problem solve.
Jan 13, 2009 | Canon imageRUNNER 400S Copier
Waste motor error
The wate motor transfers (you guess it) waste toner to the waste toner bottle. If the bottle fills up, the motor cannot transfer more waste to it. This is rare, for the printer should ask for a new waste toner bottle when the previous one fills. However,it happens frequently when users try to empty and clean the bottle instead of replacing it.
If a new waste toner bottle is in place, then the printer needs a new motor, which can only be purchased through an Authorized Service Center.
Oct 24, 2007 | Samsung CLP-510 Laser Printer
Ricoh CL3000 Laser Replace Waste toner
Ricoh CL3000 Laser, replace waste toner displar unit will not print, waste toner cartrige is empty.printer will not print? How do I reset unit?
Feb 17, 2007 | Ricoh CL3000E Laser Printer
23 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
