Question about Miele S548 Bagged Canister Vacuum
Miele canister keeps shutting off when i press + it starts again for short while and off again whats problem i have changed bar but still no good
Was it hot when you pressed "+" button? Did you check the filters(Hepa) or bag if clogged or suction path was blocked? Does it happen after it was cool down? From what you said, it seems none of the above. Only thing I can think of is circuit board. The mortor runs in variable speed. "+" increase the average voltage to the motor thus higher suction. PWM circuit in main pcb may not working correctly.
High priced vacuum cleaner like this shouldn't fail like this but it does. JMO.
Posted on Nov 12, 2010
Tip
How To Maintain a Miele Canister Vacuum
Here's a short Video Presentation that we've put together showing how to replace the vacuum bag, motor filter, and HEPA filter on the Miele Series canister vacuum, as well as how to perform basic maintenance.
How To Maintain a Miele Canister Vacuum Cleaner
on Mar 22, 2010 | Miele Aquarius S5580 Bagged Canister...
Tip
Miele vacuum cleaner suddenly stops
So this is a problem I identified in Miele's mid size ranged canister cleaners. Not only the S318...
If you go about cleaning on the highest power setting the engine will overheat after 5-10 minutes. It then will need around 20-30 minutes to cool down before you can use it again.
Tip: Don't run the machine on 100% power, instead turn the setting to around 80-90% and then you can enjoy good suction un-interrupted.
on Jan 28, 2010 | Miele S318 Bagged Canister Vacuum
Power intermmitently fades down. I have to keep pressing the plys button to keep it running
Hi joant58,
We had the same problem with our miele. We bought a new hose and that solved the problem. Unfortunately, it was not cheap. Over $100, but I don't remember a more exact amount.
Sep 10, 2011 | Miele Blue Moon Bagged Canister Vacuum
Canister vacuum keeps turning off, can push buttons on wand handle to restart but shuts off again as soon as you start to move handle
its sounds like the problem is either the power head wire which when your using it and twisting it left and right, turns it off.. Or it could be in the hose where the connect meets with the unit.
Here's a number to call to further assist you. 1-800-322-2965
Aug 14, 2009 | Miele S548 Bagged Canister Vacuum
Our vacuum bag was full and we keep on vacuuming. I believe some lent and hair got sucked into the vacuum motor. We've changed the bag and filters. Now the motor makes a loud noise especially when shutting...
Get a professional repairer to examine it. Even with an over-full bag, dirt will not have got in to the motor if the pre-motor filter was correctly positioned and in good condition. However, the motor may have been damaged through lack of air flow and consequent over-heating. Your machine may well need a new motor, and that's a job you won't be able to do for yourself.
Sorry to be the bearer of bad news. I value your feedback, so please remember to rate this response. Good luck!
Jul 18, 2009 | Miele S251i Plus Bagged Canister Vacuum
Miele Solarus Canister Vacuum stopped working
I am an amateur and novice.
Tracked My Miele problem to a bad connection at the outlet plug.
i think the constant slapping of the plug against the housing during rewind prob disconnected the wires inside the plug? Replaced plug
Apr 14, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Miele S 312i canister vacuum
It could be the switch, reel cord assm., speed control or motor. Most likely not the motor, but possible. It will have to trouble shoot to find out what is bad.
Nov 24, 2007 | Miele S300 Bagged Canister Vacuum
Miele S548 Bagged Canister Vacuum Logo
742 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
