Question about Car Audio & Video
Radio cassete need wiring diagram for model number 39100-sqo e010 mi to install in car serial no 219402 ref cq -sh676a
2 Suggested Answers
SOURCE: missing code honda accord 2002
You lucky lucky person! I am an automotive diagnostic tech,and have delt with this problem literally hundreds of times.you need to remove the head unit and changer from the vehicle this is easier said than done. the front of the dash has to also be removed and those attention-paying-down-to-the-last-detail engeneers and designers were thing job security on this one look in and remove the vent grills for most of the retaining screws holding the front together after its apart and the units are out look on the bottoms and call your local honda dealers sefvice. tell them the number then they will tell you your codes.enjoy you will hate your car after this, caution, your dash will squeek like theres no tomorrow if ALL of the screws are not reinstalled.
Posted on Oct 03, 2008
  • 4737 Answers
SOURCE: radio Code for unlock 1999 honda CRV car
HONDA codes are not readily available from anywhere on the Internet apart from here
https://radio-navicode.honda.com
You will have to quote the car`s VIN number + other details.
If they cannot provide your code then you will have to try your HONDA Main Dealer or a Decode Service who will plug it into a laptop and electronically read/recode the memory chip (EEPROM)
Posted on Sep 30, 2009
Hi, i need a code to my factory acura integra radio. its a factory radio and the Serial Number is 96F504420 / Model number 39100-ST7-A500 / Ref number CQ-JH9610A / Manufactured Janurary 1999. I changed the...
Call an Acura dealership with that serial number and they should be able to provide you the code. Or you can take it directly to the dealer but you will be charged labor.
Jul 14, 2010 | 1994 Acura Integra
I don't know my matsushita radio code; serial;96D313901 Ref.No.CQ-jh2610A Model; 39100-S30- A100
If this is the Matsushita fitted into a Honda, then try here
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} HONDA codes may be available here
You will require the car VIN number and Radio serial Number
If they cannot provide your code then you will have to try your HONDA Main Dealer .....or a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM)
May 18, 2010 | Car Audio & Video
Honda cd player code need?? model no.39100-s02-a100 ref.no.cq-jh5812z serial no.m98f205826 need code??
hi if its the orignal make a note of your vin number take it to any honda dealer they can get it for u
Nov 16, 2009 | 1997 Honda CR-V
Pin out diagram for Matsushita Car Stereo model 39100-s9A-A2000
You've got to get that info from a dealer or audio installation specialist.
Jul 26, 2009 | Car Audio & Video
Security code lock
go on the back of the face or on the radio it self it and reset it that should clear the code
Nov 21, 2008 | Panasonic Car radio CD CQ-C1110GN CD...
Missing code
i have a 2002 honda accord stereo and i have the serial no,ref.no,and model no but i dont know to reset
Sep 30, 2008 | 2002 Honda Accord
MMITSUBISHI CAR RADIO/MR472955 REF#CQJB3910A
Hola, hacen unos meces tengo un problema con el radio de mi carro me pide un codigo y no e podido encontrar una solucion a eso. Si alguna persona puedira ayudarme se lo agradeseria. el Modelo es MR472955 y la Serial 99A250735
REF no. CQ-JB3910A
Mar 17, 2008 | Car Audio & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
