Question about Car Audio & Video
How do i wire my car stereo tha keeps draining my battery in a 1998 cavalier....
  • 87 Answers
You must use the proper gauge of wire depending on the wattage that you have but the thicker the better. 4 gauge is good for about 500 watts and 2 gauge for 1000 watts but you also have to account for the distance from the battery to the amp the longer the distance the thicker you have to go. Also you need to make sure that the accessory wire are connected right so that your radio is turning off when the car is off. The remote wire from the radio should be run to the amp so turn it on only when the radio is on. Check the acid in your battery and top it off by adding water into the cells if the levels are low. This will help with the charging of your battery and if you thing you have a weak or bad alternator you can go to an auto zone for a free testing.
-david
Posted on Nov 07, 2010
It starts, but why doesn't it keep on running?
Your best bet is to take your vehicle to a ASE certified repair shop .
Feb 01, 2016 | 2004 Chevrolet Cavalier
1998 chevy cavalier replaced ignition cylinder instrument panel stereo car wont start when its cold
You have a short to ground inside the steering column Measure voltage with ignition off.any wire that has less than 12 volts should be considered as problem if not black in color
Mar 19, 2014 | 1998 Chevrolet Cavalier
Car wont start after driving through high water
I would have to say its flooded. I would start by taking the head off and spark plugs out to alow air to the cylenders to dry, drain oil and check for milky residue in oil. put fresh oil back in. good luck..
Dec 07, 2013 | Metra 99-4544 1986-1998 Chevy Cavalier Z24...
Battery light is on a 1998 cavalier. alternator won't charge. has new battery and alternator
CHECK WIRING THIS UNIT WILL CONTORT THE FIELD IN THE COMPUTER. THE FIELD CONTROL IS WHAT MAKES IT CHARGE.
Jan 19, 2013 | 1998 Chevrolet Cavalier
My car will not keep a charge
Something is draining it when it is off. Check lights under hood, in trunk, glovebox, power door locks, amateur installed stereos, GPS, sound boosters, anything else which is or could be running when ignition is off.
Apr 22, 2010 | 1998 Ford Taurus
I need the factory audio color code diagram for a Chevrolet 2006 Colorado
2006 Chevrolet Colorado Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. The accessory turn-on is controlled by the lan serial network. Run a wire to the fuse box or ignition switch harness.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
pls rate
Apr 05, 2010 | 1998 Chevrolet Cavalier
I need the factory audio color codes diagram for 1996 z24 chevy cavalier
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger: Pink
Good luck and hope this helps
Apr 20, 2009 | 1998 Chevrolet Cavalier
1998 cavalier headlights will not work. low or
check wiring in the front bumper for corrosion big problem relating to cavalier and sunfire
Mar 14, 2009 | 1998 Chevrolet Cavalier
Car Audio & Video Logo
57 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
