Question about ASUS P7P55DE Pro Motherboard
SixEngine.exe and TurboVHelp.exe are blinking under win7 user in the bottom task bar. No problem under administrator. I can get rid of the blinking by clicking on the twobuttons and adding the admin password. Is there a better way? Many thanks.
SixEngine needed permission too though not TurboV. So, though I found out how to run it as admin, it's useless so I just uninstalled it.
1) http://www.sevenforums.com/tutorials/11949-elevated-program-shortcut-without-uac-prompt-create.html
2) http://www.sevenforums.com/tutorials/11841-run-administrator.html
I wouldn't want turboV to run without prompt: so anyone could adjust system voltages. If this is what turboV does, no way, and mine sadly doesn't need permission to run. Fortunately, I am the only user.
Posted on Dec 20, 2010
How to setup scanner konika c450 in win7
you need to type in the IP address of the machine into the search bar and log onto the user interface, then you need to log on as the administrator and add the settings under network.
Oct 06, 2013 | Konica Minolta bizhub C250 All-In-One...
No start task bar in safe mode
It sounds like explorer.exe is being turned off. When you log in to Safe Mode hit Ctl+Alt+Del to bring the Task Manager and see if explorer.exe is running under Processes. If not, you can go to the Applications tab in Task Manager and click the New Task button and simply type in explorer.exe.
If this does not give you your Start Menu and Task Bar then you need to take your computer back to the repair service and have them fix it properly this time. Otherwise, you'll have to reinstall the operating system.
Jul 06, 2012 | Dell OptiPlex GX260 PC Desktop
MENU BAR IS GONE...PUFF, GONE
Press ctrl+esc to see if the start menu pops up, if it does not then proceed by trying the following steps below.
Make sure explorer.exe is still running:
Press ctrl+alt+delete to get into Task Manager and do File -> New Task -> explorer.exe -> OK
Otherwise check to see if your task bar is auto hiding:
Move the cursor to all four edges of the screen in an attempt to locate the hiding task bar. If the task bar does pop up, right click on it and press properties. Proceed by unchecking Auto-hide the taskbar under the Taskbar tab and pressing Apply and OK.
If all else fails, try rebooting the PC.
Jul 19, 2011 | Computers & Internet
I cannot format my 4gb kingstone flash memory,it says it is being used by anoter program!!
plug your 4gb kingston usb drive in
scroll to bottom of screen (task bar)right click select task manager applications you will see whats running if you see anything you dont need running select end now also under processes and users you will see who is using your computer then try to format your drive
click start click on my computer you should see your drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your drive select format
hope this helps
Jun 27, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have a problem with my hpdv5 1205tx my current windows is vista i repormat in windows 7 now my problem is my digital personel fingerprint was not connected i already down digital personel 4.11 help me...
If you have installed either 64 bit or 32 bit, then you have to run the installation as administrator.
To do this, just right click on the installation file and choose run as administrator.
If this did not help, refer the below steps:
  • Download version 2.01 of DigitalPersona software
  • Install on existing system
  • Export data
  • Boot into Win7
  • Install 2.01
  • Reboot
  • Reset properties for each of 7 EXE files
  • Reboot
  • Register a finger print
  • Import data saved in step 3
  • Download from here:
    http://download.cnet.com/DigitalPersona-Password-Manager/3000-18501_4-201746.html
    Step 3:
    Export is available as an icon choice in the system tray. Save to a file for use in Step 10.
    Step 7:
    The run properties for each of the 7 EXE files in the DigitalPersona install need to be adjusted. The files are:
    DPAgnt.exe
    DPConsol.exe
    DPExpImp.exe
    DpFpLogonManager.exe
    DpHost.exe
    DPRunDll.exe
    DPWinLct.exe
    Select each and set as follows:
    • Compatibility tab
    • Press ã¢â‚¬å“Change settings for all usersã¢â‚¬â
    • Select run in Vista mode
    • Select run at admin near bottom
    Repeat for each of the 7 EXE files.
    Nnags.
    Mar 08, 2010 | HP Pavilion dv6000z Notebook
    I HAVE A WINDOW XP HOME EDITION AND WHEN I START MY COMPUTER THE ONLY THING THAT COMES UP IS THE BACKGROUND. THERE ARE NO ICONS OR A BAR AT BOTTOM OF SCREEN.
    the icons and the bar(task bar) at the bottom of the screen are enabled by the explorer.exe file
    it starts automatically but in your case it is not starting
    to start it when your computer starts and comes at the desktop, press alt+ctrl+delete button at the same time to bring up the task manager
    when you do this a task manager shows up in a window
    in task manager window click on file, it will be located on the top left portion on task manager
    now click on "new task(run)"
    this opens another window, in that window type
    "explorer"
    without the quotes "" and press enter
    this will bring you icons and task bar at the bottom of the screen
    Sep 29, 2009 | Computers & Internet
    Cec_main.exe. pls reinstall
    Are you using Kaspersky Antivirus? For updated KIS 2009 (e.g., v.8.0.0.506) users, click on KIS icon on toolbar, then "Applications under Control" at bottom of page. You will find that CEC_MAIN.EXE has been assigned to the "Untrusted" file at the bottom of the list. Highlight CEC_MAIN.EXE, then move it to the "Low Restricted" file above.
    Sep 25, 2009 | Gateway MT3705 Notebook
    I don't see icons on the desk top and the task bar at the bottom does not show up
    Looks as if the explorer is not starting up automatically. Try to start the explorer manually by Clicking Ctrl+Alt+Del keys together. This will turn on the Windows Task Manager. Then go to File in task manager> Click on New task(Run)> type explorer.exe This should start up the PC...
    Apr 20, 2009 | Acer Aspire 3000 Notebook
    Pc relocator program
    Dear Sir/Madam,
    CAUSE loadTOCNode(1, 'cause');This issue may occur if one of the following conditions is true: • The user account that you use to install the game does not have administrative rights. • You have programs running in the background that are interfering with the setup. • .NET Framework is not installed on the computer. • The Windows Installer program that helps you set up the game is not installed correctly.
    RESOLUTION loadTOCNode(1, 'resolution'); Locate and then close the files loadTOCNode(2, 'resolution');To resolve this issue, locate, and then close Idriver.exe and Msiexec.exe.
    To do this in Microsoft Windows XP, follow these steps: 1. Open the Task Manager. To do this, click Start, click Run, type taskmgr, and then click OK. 2. In the Processes tab, in the Image Name column, find idriver.exe and msiexec.exe. 3. Select each instance of both processes, and then click End Process. 4. Click Yes on each Task Manager Warning popup window that you receive. 5. Close the Task Manager.To do this in Windows Vista, follow these steps:
    Windows Vista loadTOCNode(3, 'resolution'); 1. Click Start and click Control Panel. 2. Click User Accounts and Family Safety. 3. Under User Accounts, click Add or remove user accounts. 4. Click Create a new account. 5. Type in the account name. 6. Select the account type: Standard or Administrator. 7. Click Create Account. Select the account you just created. 8. Click Create a password. 9. Type in a password for the user account and an option password hint. 10. Click Create password. 11. Log off your current account, log back in using your new account. 12. Start the installation. Perform a clean boot procedure
    Jun 04, 2008 | Eisenworld Alohabob PC Relocator Ultra...
    Windows cannot find scvhost.exe
    This is the Internet Virus , to overcome this , you may kindly be taken following steps .
    Step 1: Write click on the start button task bar .
    Step 2: Select Task manager by left click of you mouse.
    Step 3. Under the process option , select line
    svchost.exe system Administrator
    Step 4. Select End process .
    Step 5. Repeat Step 3 & 4 until the end of the bellow message.
    svchost.exe System Administrator
    Step 6. Close the Windows Task Manager by click X button .
    or
    Run the Original Quick Heal / AVG antivirus software in your system .
    The steps are the solution for your problem.
    OK
    nilamani
    nkjbbsr@yahoo.co.in , nkjbbsr@rediffmail.com
    Dec 21, 2007 | Microsoft Windows XP Professional for PC
    ASUS P7P55DE Pro Motherboard Logo
    637 people viewed this question
    Top ASUS Computers & Internet Experts
    David
    David
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
