Question about HP Compaq WF1907 Monitor
My moniter goes to sleep as soon as its onhat does that mean
  • 348 Answers
Restart the computer press f8 f8 until the dos menu appears select enable vga mode your problem will be solved
Posted on Nov 07, 2010
Question about my HP desktop model p6-2003 computer blue light on and moniter going to sleep moniter going to sleep
in control panel, select the power Options,, Change the preffered plans to HIGH PERFORMANCE then click on change plan settings, change turn of diaplayto never and put computer to sleep never... Remember to turn on your screen saver and put the pc to sleep manually when not using it.
this is a common problem and caused by corrupted registry entries. The popper fix is to reformat or restore the system.
Dec 29, 2012 | Computers & Internet
Ok, I changed my video card ( hp: p6230f) I still have no signal in your opinion would you go with monitor failure or motherboard? I have also checked all connections. Soon as I turn it on it scans reads...
1.If your display come during start up windows then its problem with graphic settings.
2.check moniter with another pc if its work on that pc then its your card problem.
In the case of 1 you have to go in safe mode and change the graphic setting.you have to change frequency hertz from advance setting to 60hz or 75hz which is mostly compatible with all moniters.And restart pc.you also check display driver correctly installed.
in the case of 2 problem change card or connec it with built in vga card and check your graphic card with another pc.you should find what is problematic by follow these steps.
Jul 13, 2011 | Computers & Internet
Within the last few days the moniter "blue light" when it is turned on suddenly turns yellow and the screen goes dark. I move the mouse briskly and turn the moniter off and on again and...
You should check the "Power Options" when the computer "Sleeps" & "Hibernates". Go to the "Control Panel" if you Win 7 or below, if you have Win 10 just type "Power" on the "Search Box" on the bottom left of the screen and then click "Edit a Power Plan" and set when the Computer "Sleeps" and when it "Hibernates". Basically when you move your mouse you are waking up the Computer from "Sleeping" or "Hibernating". Goodluck.
Dec 14, 2017 | Acer Brand ACER P191W 19" LCD Monitor
Everytime I turn on moniter it goes into sleep mode and won't wake up!!
If there was something wrong with the monitor itself it wouldn't go to sleep it would just turn off. It sounds to be as if there is an issue with the signal going to the monitor itself, try restarting your PC and ensure that the connection on the back of the monitor and the connection on the back of your PC are secure.
Mar 07, 2011 | HP f2105 21" LCD Monitor
Hi...I have a Flatron W2234S that is about one year old. It has been problem free until recently when I moved. Now all of a sudden it comes on and immediately goes off and I have to turn it on and off 3 or...
You can take it apart and inspect for bulging capacitors - the tops should be perfectly flat. Even a slight bulge at the top is an indication that the capacitor is bad.
Nov 11, 2010 | LG 22" FLATRON LCD Monitor
My hp w2207h goes to sleep
Turn off the "powersaver" feature on your monitor by pressing <menu> then <management>then <powersaver> select off.
Nov 20, 2008 | HP f2105 21" LCD Monitor
Need control switch for time when moniter goes to sleep
The setting is controlled by your computer not the monitor. I'm assuming you are running Windows - open the Control Panel (from the Start button) and go to Power Options. You can find it in here. If you have problems, get back to me with the specific Operating System you are using and version or service pack level and I can give you more specific details.
Oct 06, 2008 | HP Pavilion F1703 17" LCD Monitor
Pc moniter trouble
Is it actually going to sleep or is it just really dim in the background? I'm currently investigating one I've been given to fix, and have ordered a new inverter board to try and fix the problem.
Aug 31, 2007 | Dell E172FP 17" LCD Flat Panel Monitor
HP Compaq WF1907 Monitor Logo
96 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
