Question about Canon imageRUNNER 400S Copier
051 error - Canon imageRUNNER 400S Copier
  • 21 Answers
Home position sensor problem,change &check it
Posted on Nov 07, 2010
Smart drive 051 error code 32
Have you tried unplugging it and plugging it in again?
Nov 22, 2013 | Fisher and Paykel Washing Machines
Will a 090 carb fit a 051av
doesn't look like they will fit. Those saws are larger so require more fuel and would mot likely flood out the 051
Dec 19, 2012 | Stihl Chain Saw 051 075 088 090 +
Canon ir 400 error code 051
I m E220 Error how to clear the error of Ir 400
Jul 29, 2011 | Canon imageRUNNER 400S Copier
Reset 051 fatal error OKI C9600n led printer
Service Error 051: Error
CU fan Error CPU cooling fan of CPU PCB is abnormal.
- Is the connection of the CU PCB Normal?
No - Normally Connect
Yes Replace fan
- Replace and restore fan?
No Replace CU PCB (Must Replace EEPROM)
Jan 25, 2011 | OKI C9600n Led Printer
051 code showing in gp 405
E051 indicates that the side registration sensor is not detected try to switch off/on the machine but if the same error code display again thre is a small motor that drive the sensor assy should be change.try to move the sensor manualy by opening the upper right side peep inside you will see a long white plastic wth teeth push to this to right side hope this will help
Jul 09, 2009 | Canon imageRUNNER 400S Copier
CANON GP 405 ERROR E 051
My machine gave me an error E051 and it could not start. when i restarted, it still ended at that.
i decided to switch it off and wait for the technician to come and fix it.
the next morning i arrived before the technician came and when i switched on, it was very fine.
what could have happened.
Tonny Obwin Telecommunications engineer.
May 02, 2009 | Canon imageRUNNER 400S Copier
What does the code mean? How do I fix it?
051 means the printer motor is abnormal. I would try replacing the toner cart then switch off/on in the first instance.
Apr 14, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Oki c7300
Error 051 is a CU fan error.
It is solved by first replacing fan then the CU board.
I would call the seller or 1-800-OKIDATA
If you're comfortable with a screwdriver I would take the cover off
and look at the fan to see if anything is obstructing the flow.
Mar 24, 2008 | OKI C5200n Laser Printer
Cannon Copier image Runner 400/330 series error 051
E 051 problem is registration horizontal position gear is broken. this gear seem to paper pick up deck back side. remove paper pick up deck and see one small moter and see small gear is there u change it u r problem is solved
Mar 21, 2008 | Canon imageRUNNER 210S Copier
Error codes 051
it is around the horizontal registration home position switch (ps14) Check out the paper feed real good
Dec 18, 2007 | Canon imageRUNNER 210S Copier
Canon imageRUNNER 400S Copier Logo
20 people viewed this question
old marine
old marine
