Question about Samsung LE40R73BD 40 in. HD-Ready LCD Television
I have a Samsung LCD 40" TV model number LA40S81BX/XSG and am trying to connect my PC to it, but have been told that i need the unlocking code. Can anyone help with this code please
SOURCE: Samsung LN-T4042H 40" LCD
This may not really be a solution to your problem, but here it goes. If you are not sitting a particular distance from your tv you will experience slight pixelation. I have this tv myself and I think it looks great. Now when I am sitting up close on a station that is broadcasting in 720p(which is pretty much every HD station) It looks only pretty good...I sit back and it is fantastic. The good rule of thumb is take the number or inches your TV is in yours and my case 40, divide by 10 and then multiply by 2...and that is the number of feet you should be for optimal viewing distance. So 8 feet, you would be surprised to see how sitting this magic number away makes a difference.
Posted on Feb 12, 2008
ginko
  • 19396 Answers
SOURCE: Samsung 40" lcd - Connecting to PC saying 'MODE NOT SUPPORTED'
First of all, check that the TV is set on PC input when you use PC video input at the back.
Then you may also need to go to video and display properties>>settings, from control panel (personalize on Vista).
There lower down resolution and ensure that frequency is set the same as tv.
Posted on Jan 02, 2009
SOURCE: I bougth a lcd samsung 40 inch tv. I cannot connect my gamecube
You need to get a special scart lead which you can connect your red, white and yellow leads to then connect the scart lead to your tv it should work then
Posted on Feb 01, 2009
SOURCE: Need Comcast Remote Code for Samsung LN32A330 TV
I contacted Comcast and here are your codes for the three way remote with DVR Samsung 10812, 10766, 10814. I have the same TV Samsung LN32A330 and it was the very first code for my TV! Hope this cuts down your frustration!
Posted on Feb 04, 2009
SOURCE: SAMSUNG 32 IN LCD LE32R73BDX (MASTER RESET)
* With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
* The TV will turn On with the Service Menu displayed.
go to reset
* Press the {POWER} button to exit the Service Menu.
Posted on Mar 28, 2009
Bent hdmi port for sansung tv
no, the board it is on is sold as a unit---I have seen several techs try to replace the socket---there are some sites on the internet that stock by model number all the boards Google Samsung boards/parts.
The only other option I see is connect the set via another input like component--that connector and the board are history.
Oct 22, 2012 | Samsung LN-R408D 40 in. LCD HDTV
I have a Samsung LE40S8 tv. When connecting my
Do you have any further details on your Telergy Set Top Box, Model No. so I can look into this for you.
Jul 08, 2011 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
I get the "Digital noise
Try this method :
1. Menu, select setup
2. Plug and Play
3. Enter pass code by entering 4 digit number (0-0-0-0)
4. Select language
5. Switch to Home Use
6. Follow the instructions.
Good luck.
Mar 07, 2011 | Samsung LE40R74BDX 40 in. LCD Television
Hi there i need code for sky remote to pair up to samsung lcd tv model number LE40b652,have tried 0060 in the book but not working sky bloke said that there is a tv model number code
if you look inside the battery compartment there should be a revision number for the remote.
for a LE40b652 use -
Rev 4 or 6 Remote - 0646 or 0502 or 0615
Rev 8 Remote - 0646 or 0840 or 1340
Feb 28, 2010 | Samsung LE40B650T2 40 in. Full HD Crystal...
Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
Apr 02, 2009 | Vizio L32 32 in. LCD HDTV
Locked control pad
Try a Logitech Harmony universal remote, they can be uploaded with the drivers from the internet and this might do the trick. Otherwise you can contact Samsung and ask for a replacement of the original remote.
Jul 05, 2008 | Samsung SyncMaster 403 T 40" LCD Monitor
LCD TV with broken screen, good picture??
samsung.com says it has to be repaired by local dealer. get quote first. probably cheaper to just buy a new one.
Jan 08, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Samsung LE40R73BD 40 in. HD-Ready LCD Television Logo
226 people viewed this question
Jerry Greenberg
Jerry Greenberg
