Question about Garden
I have recently purchased an old DeWalt 7790-3431 Type 4 radial arm saw and am looking to wire it for 220v. Anyone know where I can find one online? The motor cover plate is too limited in it's diagram.
rockitman187
  • 2559 Answers
SOURCE: Cannot find specs for my DeWalt Radial Arm saw
Here you go.hope this is what you wanted and Please rate this a fixya
Posted on Feb 09, 2009
  • 25 Answers
SOURCE: dewalt power saw wiring diagram for trigger switch
The Switching should go like this
(single letters denote wire color)
Y---o o---R
B---o o---B
The contacts where the black wires attach are the points on the switch that break when continuity is checked.
Posted on Apr 18, 2009
efs_perpends
  • 1996 Answers
SOURCE: crafstman radial arm saw owners manual model #113-29440
Go to this link and you'll be able to download the pdf file of the operating instructions for you saw.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 11, 2009
  • 384 Answers
SOURCE: craftsman radial arm miter saw parts discontinued
Any hardware or home improvement store will have a replacement.
Posted on Jul 22, 2009
  • 34 Answers
SOURCE: dewalt 7749 radial arm saw
According to the service manual this saw has a 120VAC single phase 2.5 Hp motor with a 5/8" x 1.5"long arbor. It has a maximum vertical cutting depth of 2 and 15/16". It has a maximum cutting depth at 45 degrees of 2.125" (2 and 1/8") without the lower guards. The maximum cutting depth at 45 degrees with the lower guards in place is 1.625" (1 and 5/8"
The service manuals (approximately 24 megabytes each) are available on line at Dewalt.com After creating an account. Then you should go here:
http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=18624&typeId=1495&documentId=574
for the manuals.
Posted on Nov 24, 2009
I have recently bought a B and D Deluxe Power Shop radial arm saw, but without a manual. I cant find how to adjust the angle of cut. my old dewalt was simple but I cant find the adjustment on this one
Should be able to find manual on line---put in make---model number in address bar (search engine Google) and you'll all types of info---GL
Jan 21, 2017 | Dewalt Saws
Need a manual for old DeWalt radial arm saw. Serial:60022464. NO model # on the plate.
check this out
http://www.fixya.com/support/t26033757-dewalt_radial_arm_saw_gw1_single_phase
20 Most Recent Dewalt 10" Radial Arm Saw 2 Hp Questions ...
www.fixya.com/support/p3534275-dewalt_10_radial_arm_saw_2_hp_403044_ma
Recent Dewalt 10" Radial Arm Saw 2 Hp 403044-made In Usa - Miter Capacity: 45° R 9.25" questions, problems & answers. Free expert DIY ... Serial:60022464.
Dec 11, 2016 | Dewalt Saws
I'm after dewalt radial arm saw dw320 manual where
Best place to get it would be to contact dewalt and ask them for a PDF file or photocopy of the manual sent via email. There are not very many places online that carry that manual.
Oct 07, 2013 | Radio Communications
Hi my name is Pat I need the rewiring diagram. So I can rewire my dewalt radial arm saw motor, it is a single phase capicitor motor with built in brake.It`s 120/208-240 volts, 11/5.5 amp, 3450 rpm, 236...
Here's a Google search on the subject:
https://www.google.com/search?q=dewalt+radial+arm+saw+wiring&ie=utf-8&oe=utf-8&client=firefox-b-1
Feb 04, 2018 | Saws
Need replacement parts - accessories
If the kickback arm you seek is the type that is a round bar with pointed fingers on the bottom, I had the same problem. (different model DeWalt) I gave up trying to find one, and finally just made one. It was pretty easy, and works very weill I bought a piece of steel rod (1/2 inch I think) a steel repair plate (from which I cut a pair of tear-drop shapes with a hacksaw and file) a 1/4 inch hex-head bolt (which had about 1 inch not threaded) and a 1/8 inch roll pin. I looked at various pictures on the web to determine the shape of the teardrops. I drilled a 1/4 hole in the 1/2 rod. I cut the threads off of the 1/4 bolt so it was still long enough to accept the 1/2 rod, the two teardrops, 2 washers and the 1/8 roll pin. Then I put an 1/8 hole in the bolt allowing enough clearance so that the teardrops would swing freely. It works like a champ. One minor flaw is that with only two of the teardrops (instead of several) and being separated by 1/2 inch, it would be possible to make a skinny enough rip that only one teardrop would contact the board being ripped, leaving the other peice unguarded.
Jan 23, 2010 | Delta Machinery 10" Professional Radial...
I HAVE JUST BOUGHT AN OLD DEWALT DW1201 RADIAL ARM SAW WHICH DID NOT HAVE A CUTTING TABLE ONLY THE METAL FRAME. COULD YOU PLEASE TELL ME WHERE I CAN AQUIRE AN OWNERS MANUAL AS I AM HAVING QUITE A BIT OF...
Normally DeWalt owners manuals are available from DeWalt ServiceNet (Click here),
But I have been unable to get any hits on that model number when I search the site. and I'm thinking you have probably purchased one of the older cast iron models, a 12 or 14", am I right?
Sometimes I've had luck finding manual for older machines at this link, but in your case I wasn't able to turn anything useful up there either...
In general, those saws had a two piece table, with a strip of 3/4" ply or particle board about 3-4" or so wide in back, and a wider piece in front, both about 3-4' wide. Between the two, on edge, sat a fence, approx.2 1/2" tall. The back table was sized so that the fence would be located in the correct reference to the blade, i.e. in front of the blade when the saw was pushed all the way back against its stop.. Then the thumbscrew clamps on either side of the table would squeeze the fence between the back section and the front section of the table.. The leveling screws beneath are used to level the table with respect to the path of the saw along the arm, so that, e.g., a tooth of the blade just skims along barely touching along its entire path of cut...
You can probably learn the correct sequence of adjustments for squaring the blade vertically and horizontally and adjusting for heel by examining other radial arm saw manuals, or perhaps consulting books on the subject...
Here's a link to an online forum on the subject
I haven't actually seen this book, but it looks interesting...Mr Sawdust
And finally, if you check back issues of Fine Woodworking online or at your local library, there are bound to be some articles on radial arms saws to help you along...
Sorry I couldn't hook you up with a manual, but I hope this helps... Good luck!
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 10, 2009 | Saws
Does anyone have a manual for a dewalt 710 radial arm saw
Go to Dewaltservicenet.com and in the middle of the page towards the bottom type in either 7710 or 710 it will take you to another page and find the model 7710 on the left hand side and then click on the user manual section to the right of it. The manual is 24 pages long. Hope this works if not let me know and I will look further. Thank you in advance for rating the information.
Apr 05, 2009 | Dewalt Saws
Feb 09, 2009 | Dewalt DW746X 10" woodworker's table saw...
Dewalt 7749 radial arm saw
for the manuals.
Jun 25, 2008 | Dewalt DW746X 10" woodworker's table saw...
Hi there i'm wondering if anyone can help
Hi Beth.
I have listed a link bellow to try this lists all the radial arm saws that you can still get spairs for.
You will see on the list there is a DW125a then b then c and d all diferent parts to the saw click on one at a time then click on drawing onthe right side of the screen hope this helps you and yor dad please let me know.
Thanks. Sean.
ps. the rest of the sight is good think your dad will enjoy just looking through
https://service.toolcommerce.com/Products/SearchResults.aspx?Type=Products&Filter=radial&CNType=
Mar 02, 2008 | Dewalt DW746X 10" woodworker's table saw...
Garden Logo
115 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
