Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
How do you program the wireless keypad ? - Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
    President:
  • 3,197 Answers
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Posted on Nov 08, 2010
I am replaceing my keypad and panel with 6160 keypad and vista20 panel do i have to reprogram my 5881 for my wireless zones
Zones are not programmed into receiver(5881). They are programmed into V20 panel. You will have to reprogram zones.
Mar 31, 2011 | Honeywell Ademco 6160 Alpha Keypad +...
Sears Craftsman key pad is about 20 years old. Need to re-program code. I know you hit a few numbers then the 4 digit code but I can't remember the #'s.
If it is a wireless keypad do this:
If it is hardwired do this:
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Oct 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
My wireless keypad stopped working. I replaced the battery. It worked 1x and hasn't worked since. I'm able to program remotes. The keypad is backlit and flashes when I enter the code or try to program it....
I would make sure the battery contacts are clean and not corroded. Otherwise a new keypad is most likely the answer. Just FYI the keypad will still work when the wall control is locked.
Sep 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Programming of Ademco 5839
Program the house id to 8 And enable all keypads
Nov 21, 2009 | Honeywell 5804 Ademco Wireless Security...
Can i program homelink with out a remote
The only way to program Homelink without a garage door opener remote is if you have a keypad that allows access to your garage. I tried EVERYTHING and then realized I had the keypad which is wireless; I simply unscrewed the battery operated keypad from its location and held it 1"-3" from the Homelink buttons in my car. I then punched in my code and held the enter button on the keypad at the same time as the Homelink button I wished to program. It worked flawlessly. Good Luck!!!!
Jul 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
I need to re-program my 96LM wireless keypad for my garage.
If you have the wireless keypad it is easy. Find the smart/learn button which is just to the left of where all those white wires go. Press and immediately release it and then walk over to your keypad and enter any 4 digit number you like and press enter. You should be good to go.
May 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Model 13553965- programming wireless keypad
You have to buy a liftmaster or craftsman keypad
May 04, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
37 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
