Question about Garmin Rino 110 GPS Receiver
My rino 110 will not stay on in cold weather, it will turn on but then turn right back off again. What can be done?
  • 87 Answers
Batteries do not fuction well in cold weather. Use a better battery like the lithum or warm up the battery by rubbing back and forth on your pants both sides pos and neg.
-david
Posted on Nov 07, 2010
Rino 110 not transmitting to other rino 110
check your device if there is a hardware problem
Oct 23, 2013 | Radio Communications
I've got a pair of Garmin Rino 110 that we use when outdoors. Recently, with full batteries and clear skies in the desert, not surrounded by trees, mountains, buildings, etc... both of the Rino 110s...
  • That RINO should have no issues picking up satellite signals in the conditions you were in. If you were inside a building I may buy it but not in an open desert. Sounds like they are feeding you a line to me. I might try to get my money back on that one. One thing is for sure, you were in about the best conditions for using that unit. If it failed you then, it will more than likely fail you when your life may rely on it. It would seem that a different GPS/GMRS unit will be necessary to give you that security.
Regards, Tony
May 10, 2011 | Garmin Rino 110 (14 Channels) 2-Way Radio
Drivers side window comes up about 1/2 way and then drags and acts like it will not finish coming up the rest of the way. Tuffy Repair Shop already replaced the motor and regulator. That didn't work and...
Here is what I would have done in the first place. Get a new regulator and take it to an auto glass shop. Those guys have the tools, the fasteners, and the know how to take the door apart and put it back together right the first time. A muffler shop, especially a chain, is no place to have that done.
So now take it to a local glass shop and have them do it right and file a small claim suit against Tuffy.
Jan 31, 2011 | Oldsmobile Silhouette Cars & Trucks
It turns on i can barely see the screen; does it have a dimmer switch? and if so;how can I fix It if i cant see the sceen? thanks ssg figueroa
to brighten up the display, after unit is on press the power button again and you should get the light and contrast contols. works on all of mine.
Bob
Jan 14, 2011 | Garmin Rino 110 (14 Channels) 2-Way Radio
I have a 2005 V-6 mustang , here in the past month since it has gotten cold I have noticed on several occasions that my speedometer has been getting stuck at around 110 or 120 and staying. I unhooked the...
This is due to a problem with the gears in the gauges; there was a manufacturing defect that ford fixed in later years. The cheapest solution is to replace these gauges. I found a local mechanic that knew how to fix it, and did the job for $30 a gauge. I recommend checking craigslist for a local person, because this is a very common problem. I haven't heard of a correlation to cold weather, but perhaps it it because your gears are defected only slightly.
Jan 11, 2011 | 2005 Ford Mustang
Rino 110 will not aquire satilite signals.
To have a signal you have to go out in an apartment may not work
Apr 03, 2010 | Garmin Rino 110 (14 Channels) 2-Way Radio
Unit will not stay on. With new batteries installed, the unit turns on while power button is held down. It immediately turns off when power button is released. The batteries have never lasted long.
If using rechargeable batteries, your batteries are not getting charged. Check your charger, battery contacts and batteries. Clean contacts with a pencil eraser.
If using alkaline batteries, check placement of the batteries to be certain they are in the correct way, and also, clean the battery contacts.
Sep 07, 2009 | Garmin Rino 110 (14 Channels) 2-Way Radio
Garmin Rino 110 Posted by nightjar on Jun 29, 2008 My two 110's have same problem. With two new sets of different brand NiMh rechargeables the problem still exists. Both units get warm and flatten the...
Re : " Both units Garmin Rino 110, overheat and flatten the batteries within 2 hours"
That is a factory defect related to a bad contact inside the unit.
If you contact garmin and insist to talk to a supervisor (second line) you can have both Rinos replaced.
Ensure it is not a bad batteries problem first testing a replacement battery, both batteries may have deteriorated at same time.
Buy first a replacement battery at Garmin eTrek, Rino 110/120 NiMH Battery,
If that does not solve the problem call Garmin:
See: Garmin | Contact Us
Feb 09, 2009 | Garmin Rino 110 (14 Channels) 2-Way Radio
Rino 110 stuck in one mode
There was a change to the WAAS satelite protocols. There is a new software download to fix the problem. The link is: http://www8.garmin.com/software/WebUpdater_241.exe
Jun 09, 2008 | Garmin Rino 110 (14 Channels) 2-Way Radio
Garmin Rino 110 GPS Receiver Logo
95 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
