Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
MACHINE NOT EMPTYING
Is checking the impellor on the end of the pump an easy job or do I need to get somebody in to do it?
Maybe you could give me some instrustions.
Thanks
M
    Problem Solver:
  • 12 Answers
Most newer machines and a lot of older ones have a removable filter on the front of the machine. Some have a small hinged door others you have to remove the bottom trim on the machine to access it. Once you have screwed out the filter and removed it you can usually see the impellor which is a cross shaped plastic piece about 2 inch's across and down. Check to see if it moves freely or if there's something jamming it.Only other way is to remove the pump from it's housing, it's usually held in by 3 screws, sometimes phillips sometimes torx head screws. Once you've removed the screws the motor will just pull off. You can usually do this by just leaning the machine back so you can get at the under side of it. Be sure when you refit the pump it goes back in the same position and that the rubber o ring locates properly..
Posted on Jun 16, 2008
Indesit iwe8123 not spinning
Its an old belief that the motor is at fault when a machine doesnt spin on full speed.
Most of the time its because its not emptying properly. Firstly check the filter for any blockages and if thats clear unplug the machine and tilt it over so you can see the pump. If your not sure which is the pump then follow the drain pipe in from the back and what that connects to is the pump. You will have to remove the pipes from that and make sure they are clear and also the pump if possible. If thats all good then it may be a carbon brush problem in your motor thats at fault. That is an easy job even for a novice. If you get no joy with the pump then let me know and i'll talk you through that too.
Nov 11, 2011 | Indesit W 123 Front Load Washer
My washing machine won't spin or drain the water. It washes then there's a hum from the motor but it won't progress. There's no reset button to press; I've tried changing the cycle; turning machine off;...
The pump has a blockage that is stopping the impellor from spinning, hence the hum and not emptying. You need to gain access to the pump and remove the item, usually I find hair ties or plastic lolly sticks have worked their way in there.
Different types of machine require different methods to do this, so provide the make/model and further help may be provided.
Mar 20, 2011 | Washing Machines
Water not emptying out, spin hold light not working, door locked and program end lights both on
maybe pump is clogged up or faulty or timer is not advancing....... To get the door open try a manual drain, pull out machine and lower the waste hose into a basin as low as you can. after that should enable you to open the door give it a minute tho....
Dec 30, 2010 | Hotpoint First Edition WMA22 Front Load...
Not emptying, ho0w to get to the pump?
If nothing obvious like blocked / obstructed outlet pipe
You need to check if the outlet pump motor in line with the outlet hose is spinning when in the outlet mode. First check if it is spinning by looking at it and see if the small fan is spinning. If it is turnning this means that it has power and the internal "impeler" that pushes the water out has become loose. Remove the pump (easy job) and repair. If it does not spin you need to determine if the 2 push on terminals have power on. If there is voltage and the motor does nut spin this indicates that the pump motor is open circuit and must be replaced.
Mar 26, 2010 | Dishwashers
Hose connected to pump blocked, now clean but machine still not emptying or spinning.
Make sure that you can actually see or hear the pump working.
If it is, then could be a blockage in the hose from the pump to the waste discharge outlet.
The other possibility is that although the pump may appear to be working,it could be the impellor is loose or worn in the pump.
Hope this helps.
Dec 12, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Asko D1706.The washing arms have stopped turning.
Can you hear the motor running? If the motor is runningand machine is full of water, but not pumping water around, you have one of the following problems:
-a blockage in the filters or sump preventing enough water getting to motor impellor,
-blocked jets in spray arms themselves,
-or I have had cases where the impellor has broken off the motor, hence motor runs but doesn't pump any water around. Check for blockages first, wouldn't suggest you take motor out and disassemble unless qualified or confident to do so (it's not an easy job if you haven' done it before!!)
Aug 04, 2009 | Dishwashers
I am having problems with an electrolux 12680 W. PNC 914522501 2007 production yr. It was making a strange sound and not pumping out water. No problem, I removed the front plug and cleaned out around the...
the hose coming from tub to the pump has a filter in it.you need to pull filter out and empty it.E20 means that you have a slow drain,or clog.If the pump is noisier than ussual then you may need to replace pump.but check filter first.
Apr 20, 2009 | Electrolux EW1000i Front Load Washer
Front load whirlpool AWM285/3 washer won't drain or spin
I would suspect that there is a blockage possibly in the pump itself, or the outlet hose from the pump, the other possibility is that the impellor inside the pump is worn or being slowed down by something twisted round the impellor..
If you can establish that there is no blockage any were, then I would change the pump.
Plz rate my solution.Thanks.
Jan 10, 2009 | Washing Machines
Not emptying
what that signals is the impellor on the end of the pump is jammed or loose. Check to make sure it is free.
Jun 15, 2008 | Hotpoint Ultima WD72 Front Load...
Tricity bendix aw1400w
not only check filter but when filter out check for foreign objects fouling pump impellor. (bra wires are the favourite) if pump impellor not visible, then put onto drain and listen for a low humming noise in vicinity of pump. this confirms that pump is powered but jammed. all you can do after that is to check continuity of pump and check there is power to pump when on drain - assumes you have a multimeter
May 03, 2007 | Tricity Bendix AW1000W Front Load Washer
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
