Question about Cerwin Vega VE-28S Subwoofer
Dear Sirs; I bought Cerwin Vega VE-28S from dealer in Thailand, The problem is the active subwoofer does not operate when I use line in input (R+L) and High level input. I must increase the volome of pre-amp, or A/V receiver to the highest level, the subwoofer operates. However, after the subwoofer operated, if the volume of pre-amp or A/V receiver is decreased, the subwoffer did not operate again. How to solve the problem? Thanks. Best regards; Chamnan
    Top Expert:
  • Cerwin Vega Master
  • 12,594 Answers
U have an issue with the amplifier in the subwoofer.
Posted on Jun 12, 2017
SOURCE: Cerwin Vega ve-28s subwoofer and new Cervin Vega 2-way satellites
I bought my VE-28s and it did exactly that crackled, cerwin replaced part in amp but few months later problem persisted. they then replaced entire amp assembly and its been fine. i really push it to and its been fine. to test it, unplug the connection from amp/ reciever and see if it persists. if so its the sub, if not its the amp/ reciever. dont dump it, these subs really crank and can put out some deep loud bass.
Posted on Mar 05, 2008
SOURCE: Buzzing Cerwin Vega LS-12 Subwoofer
i also had a problem with buzzing on my eltax atomic a8 weather the amp was switched on or off.
i followed many solutions and the one that worked was isolating the earth pin on the plug.
now not even a hum
Posted on Mar 06, 2008
JULIANFIX
  • 975 Answers
SOURCE: Cerwin Vega V-35 Horns Drivers Model TMH-1
first you need a multimeter set to OHM , check on the back of the horn , remove the leads and do some reading , it should read 4 , 8 , 16 ohms depending of the brand , if you get no reading its means that need to be replaced , some horns you can detach the back (magnet w/the coil ) so you can replace it without buying the whole unit . good luck
Posted on Apr 19, 2008
  • 308 Answers
SOURCE: cerwin vega passive subwoofer model sw-12b
Passive woofers are hooked up to the output of a sub amp.
Active woofers are hooked up to the sub out of a receiver. They have the amp built in.
Posted on Mar 09, 2010
SOURCE: V-35 Cerwin Vega
Turbo 37: Did you ever root cause your V35's? I just ran across this post. I own a pair and have done some amateur / professional speaker building. Let me know if you still want to repair. tro
Posted on Apr 02, 2011
I have a cerwin vega ve 28s sub and noticed static sound coming out even when no music was playing. The next day sub went into standby in the middle of a song. If I turn it off for a couple hours it works...
First, disconnect it and let it run with no input. Problem here is that it probably has an auto-turnoff and will shut off. My bet is that either your connection wiring is faulty and/or your amp is sending down either RF or DC signals. I would get it close to the amp with another connection cable and check... Good Luck !
Aug 12, 2014 | Audio Players & Recorders
Where can i find an amplifier for a cerwin vega hts 12a
Subwoofer Plate Amplifiers
What you need is a plate amplifier. You'll get more bang for the buck by using an after market one. They are simple to replace. Dayton is a popular brand. They use an active variable crossover .
May 22, 2014 | Cerwin Vega HTS12A Subwoofer
When turning on the power on my cerwin vega 15" sub the protect light which is a built in protection on the amplifier keeps coming on the power on light does not come on at all just the protect light
The sub could be shorted or the wire connections of the sub could be shorted, or there could be an internal problem with the amplifier such as a shorted output stage or failure of some other component(s)
Feb 21, 2013 | Cerwin Vega Audio Players & Recorders
Hello. My ve 28s crackles when in standby mode, and also plays crackly bass. Please help me by telling me which component to replace within the amp. as I have no Cerwin Vega agent support here in South...
This "Crackling" Problem is common with the Cerwin Vega VE-28S Subwoofer. If your subwoofer is out of warranty, and you know how to solder, you can fix the problem by replacing a few resistors, and transistors inside the amplifier. Get the parts on ebay: http://cgi.ebay.com/250756306868/
Sep 09, 2010 | Cerwin Vega VE-28S Subwoofer
Cerwin vega passive subwoofer model sw-12b
Mar 09, 2010 | Cerwin Vega Audio Players & Recorders
I have a blown LW12 Cerwin Vega Speaker. Can
You have several ranges of options.
1) Contact Cerwin-Vega customer service: http://www.cerwin-vega.com/
2) Do a google search on "cerwin vega speaker replacement". You will find companies both that offer repair or repair kits (e.g., www.simplyspeakers.com) or sell replacements. Contact them - they have the expertise to tell you which of their products are most suitable for your model.
Nov 01, 2009 | Cerwin Vega LW12 Subwoofer
Crackles and pops,even in standby mode
Does it only pop and crack when its connected to your amp or receiver ? i have the same thing with my sub [its not cerwin vega] but when i turn my amp off the sub doesnt pop anymore so i think my amp is the problem not the sub , yours might be the same problem .
May 19, 2009 | Cerwin Vega VE-28S Subwoofer
Cerwin vega ve-28s
I have the same problem and was told that it is failed amplifier....
Dec 02, 2007 | Cerwin Vega VE-28S Subwoofer
Oct 28, 2007 | Cerwin Vega VE-28S Subwoofer
Cerwin Vega VE-28S Subwoofer Logo
74 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Joe Lamb
Joe Lamb
Steve
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
