Question about Garden
I have a Simplicity Sunstar garden tractor, model # 1691381 I bought it used it came with a snowthrower, it is a single stage 46', manuf. number, 1693761 Can anyone help me find mounting brackets and an illustration manual? Also, it has front and rear hydraulic's. I have printed off the parts manual and the owners manual, but I can't find anything on the attachment instructions.
SOURCE: Repair Parts Manual / Book Service Garden Tractor
C I am thanking a lot for dealing with my matter and very much I am counting for your help in getting the list of the spare parts with catalogue numbers of my model of the garden small tractor.
I am greeting Ted
Posted on Nov 25, 2008
  • 148 Answers
SOURCE: How to remove snow blower from Craftsman YS4500 garden tractor
Go to www.managemyhome.com to download the manual for free. Just type in the model # 944606950.
Posted on May 21, 2009
  • 9 Answers
SOURCE: brocken sway bar bracket for craftsman riding lawn tractor/48"cut
see if you can find a diagram of your model online there should be something
Posted on May 31, 2009
  • 202 Answers
SOURCE: i have a simplicity garden tractor with a 32 inch
http://www.simplicitymfg.com/manuals/index.cfm?rd=1
If you look at the manual you should be able to narrow down the year by the serial no.
Posted on Nov 01, 2009
  • 81 Answers
SOURCE: I bought this dozer blade uses and cant figure out
You can go to sears.com and lookup the tractor part number and snow blade part number and they will show you all the brackets and attachments needed. Also the site will show all tractors that the snowblade will fit. Hope This Helps Don
Posted on Dec 02, 2009
The drive shaft moves and causes my pulley to rub on the drive shaft housing on my 42" Simplicity MFG 1691522 snowthrower
if it's a simplicity then chances are good you have worn out the bearing shimms inside motor housing and it's allowing the shaft to move more , if you want to save it you'll need to open up motor housing and pull pullys off shaft and add new schimms ,bearings too would not hurt to replace, don't forget to replace the housing gaskets with new .
Nov 22, 2013 | Ariens Garden
I own a Sears craftsman dual stage snowthrower . I haven't used it for a couple years now and I took out the old gas. But it still won't start Model # C950-52846-0 9.0 T.P. 24 inch
If you haven't taken the carb. off and clean it yet. you may need to do so. thak the bowl of to see if the float got bent. and you will need to clean out the float pin hole
Oct 16, 2013 | Garden
Own a mtd single stage 21" snowthrower ( model
OH YEAH,. I am pretty sure that you have reverse threads on this. Try PB Spray (Penetrating Blaster available in most hardware & automotive stores,. it is a cousin to wd-40 and understand it has superior penetrating ability to get in there,. if you use it -- follow the directions and let it penetrate for about ten minutes.. The only other thing is that to be sure it is reverse direction you may need to try it both ways - perhaps use a 6-point (rather than a 12-pt) socket provided you can get it in there. In addition, try to PULL the wrench or tool TOWARDS you, in stead of away, for the obvious reason it is easier to get more torque, but also that if it slips, you do not break you knuckles apart!!
Finally, you may also need to go to the next level and apply some HEAT directly on the critter rapisly to get it to swell a bit, be careful not to overheat as the entire unit heats up - all of it shall swell together. Finally with heat if it doesn't work, you will have to wait for it to cool ENTIRELY before giving another crack at it.
PS, you may also be able to extend a wrench or ratchet with a pipe to gather more torque on it.
Good Luck withh the project and don't forget a "bigger hammer" method which may be used in combination to apply sharp torque 'hits' to give it a jarring momentum..
Best regards
Ck
Jan 15, 2011 | Garden
Manual
goto sears.com click parts. type in your model # when page opens will be on the right of page asks if you would like to see owners manual you have to sign in to manage my home ****, but I found it there.its free just wants email address to send you junk mail.
Dec 13, 2008 | Craftsman Garden
Garden Logo
273 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
