Question about GE DPGT750GC Gas Dryer
No heat blower motor no working
How hard is to replace the blower motor on a gas dryer?
  • 10 more comments
  • mylilsaab Jun 15, 2008
    thank you for responding.
    i had a service tech come out and that is what he said.where is the thermal fuse located at in the dryer?
    what it did before it finally quit is, it would work properly for
    about 4-5 loads then no heat. on the display panel it would say "sensing" the dryer would keep running but no heat.
    also, is this something i can myself..i.e.thermal fuse or blower motor?
    thanks again
  • mylilsaab Jun 16, 2008
    thanks again,
    the drum does turn....but no heat...so..would i be better off taking the back off the dryer and seeing if the wheel is broken? and yes saving some dollars is a must.
    i do have the diagram printed out.
    thanks for your help
  • mylilsaab Jun 17, 2008
    back again, it is a gas dryer...no air flow coming out of the vent...before when the dryer was working properly you could hear the igniter light up.....now nothing. drum does turn..but no air flow.
    thanks again
    i can do that....there is a round cap on the side of the dryer on the bottom near the gas line...not sure if that will let me see if the ignitor is lite up...if not i will have to take the back off....a faulty igniter makes sense
    thanks
  • mylilsaab Jun 18, 2008
    ok i had to take off the front panel of the dryer to see the igniter along with taking of the top part with the controls. help me here as to how to check the igniter with the dryer apart..i dont want to blow up.
    ok i ran the dryer with the front panel off and the igniter did not light up..i ran it for ten minutes...could anything else cause this not to work properly?
  • mylilsaab Jun 20, 2008
    ok back again, i replaced the igniter and still nothing...the model number is DPGT750GC
    gas dryer.....
  • mylilsaab Jul 04, 2008
    after two weeks of finding time to replace the blower motor and the ignitor. i put most of it back together and did aa test run and nothing....the control panel does not light up..the light on the door does work .i check the circuit breaker. it has power.
    frustrated.
    ok i am back once again,,,i replaced the blower motor and the ignitor...the flame comes on for about ten seconds and then shuts off...is this common or is it suppose to stay on longer to get the inside of the dryer warm?
    i ran the dryer for 30 minutes..the ignitor would light up and the gas would come on for 2 seconds(the flame)..it should stay longer ....i have the front panel off and actually see it come on..i think i am just spinning my wheels into something that is a money pit....
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    I'm not trying to second guess a tech that has already
    diagnosed this problem, but it just doesn't make sense to me. If the blower motor
    isn't working, the drum would not be rotating. The blower motor is also the main drive motor and it is used to drive the belt that spins the drum. The symptom that you would
    get is a dryer that just would not start, but the heating circuit may still function. Basically, a hot dryer that doesn't rotate. Normally a problem associated
    with a dryer that runs, but does not heat, is a heating circuit problem or the
    blower fan has broken off the drive shaft. The blower motor lists for about $216 at searspartsdirect.com, while the blower wheel only lists for about $63. That's why I asked the question in order for you to make sure you aren't spending money on any unnecessary parts. You need to double check the symptoms see if the drum is actually turning. Refer to the website I mentioned and type in your complete model number. Look under the "Drum Motor and Blower" heading to see what I am talking about. The drive motor is item number 450. The blower wheel is item number 481. Let me know what you find.
  • Jeff Rockwell
    Are you sure its the blower motor? A blown thermal fuse will cause the same symptoms.
On this dryer the blower motor and drive motor are seperate motors. If the blower motor is not running there will be no activation of the gas ignitor circuit. Probably it is the blower motor but could be in the electronics module.
Posted on Jun 21, 2008
  • 5,911 Answers
Okay, I think we need to back up a bit here. I need to know, first, if the dryer ignites. This is a GAS dryer, correct? I need to know if the igniter is glowing, and if you can hear the gas start flowing when you have ignition. If not, this could be a simple igniter or gas coil problem. If there is ignition and the drum is turning, do you have air flow coming out of the dryer vent exhaust? If there is air flow, you cannot possibly have a blower wheel problem. We need to rule out some possibilities before we start disassembling the dryer. I'm a bit miffed as to why someone would tell you that the motor was the problem. Since I was not there, I need to know as many symptoms that you can provide, so I can give you with a correct assessment.
Posted on Jun 16, 2008
  • 3 more comments
  • Jeff Rockwell
    Jeff Rockwell Jun 17, 2008
    If the igniter does not function, you will not get any gas flow. That may be why you aren't hearing any gas flow. In order for gas flow and ignition to occur, the igniter must reach a certain current potential before the gas safety valve will open. My guess is that you have an igniter problem. Can you please let me know if you can access the igniter and see if it is glowing? It will be located under the dryer drum.
    PS Keep in mind, a glowing igniter STILL does not neccessarily mean it is good. A weak igniter will cause the same problem.
  • Jeff Rockwell
    Jeff Rockwell Jun 18, 2008
    Replace your igniter if it is not glowing. In order for the dryer to ignite, the igniter should come on and begin to glow. It takes 30-90 seconds (depending on the age of the igniter) for the proper current potential to be reached. The gas valve opens, you hear gas flow and "phooom!", you have ignition. I tried looking up the pat using the model number you have this question posted under, but found nothing. Double check your model and number again, please. It will be located around the door opening, or on the back of the control panel.
  • Jeff Rockwell
    Jeff Rockwell Jun 20, 2008
    I found your model number listed at repairclinic.com. It lists a thermistor, but I do not have a wiring diagram to look at. I looked for a tech sheet, but couldn't find one, either. A thermistor acts much like a fuse. I would also be suspicious of the control board too, but (again) I do not have a schematic to see how this dryer is configured. There should be a wiring diagram under the control panel, along with troubleshooting advice. I'm sorry I have led you on a lengthy trail here, but it is difficult to make assessments without actually seeing the appliance. Normally, a burner assembly also has safety coils too, but I don't think this would fail to provide power to the igniter, and I did not see this part listed anywhere. So...I'm afraid I'm leading you on a wild goose chase here. If you can refer to any technical documentation or provide me with a wiring diagram, I may be able to assist you further.
  • Jeff Rockwell
    Jeff Rockwell Jun 22, 2008
    Thank you "papabutler", for your input. I did not know there was a separate motor. I could not find any drawings with this information. I'm sorry I have led "mylilsaab" in circles here.
  • Jeff Rockwell
    Jeff Rockwell Jul 04, 2008
    Mylilsaab,
    I don't know if you want any more feedback from me since I led you in circles the first time. From my experience with gas dryers, the flame is not continuous. The dryer will ignite and heat and periodically re-ignite as the dryer cools and reheats. 10 seconds seems like a short time interval, though. Have you tried lettting it run for a while to see if the dryer stays warm and cycles? The only other item that can cause ignition problems that I know of are the gas valve coils. Most gas dryers have two of them and they are often sold as a set. It is recommended that you replace both at the same time. I'm not telling you to buy more parts. Test the dryer, first. And, again I do apologize for all the troubles you've had. I hope something goes right for you.
    Jeff
GE Profile Harmony Gas Dryer not heating/drying clothes.
let me ask you this does the ignitor glow orange but no flame when you have no heat?usually on a gas dryer if at first you have heat and then after 10 to 30 minutes no heat it's usually the gas coils located on top of the gas valve,common problem,after the coils cool down they will work again,that dryer is kind of complicated to work on seeing how it does have two motors in it but you should be able to get at the gas coils,if you send the model number i can look it up for you.but it sounds like you have bad gas coils,the only way to tell is run the dryer,when the heat stops working look at the ignitor,if it glows orange and the flame doesn't ignite you have bad gas coils.
Feb 14, 2014 | GE Profile Harmony DPGT750GC Gas Dryer
I have a Maytag SDG3606AWW Gas Dryer that is working but not drying the clothes. I have replaced the fuse, cycling thermostat on the blower motor. The gas flames is firing through the tube, goes on full...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Jun 13, 2011 | Maytag SDG3606A Gas Dryer
The motor and blower work fine - no heat
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 09, 2010 | Whirlpool Dryers
Will not heat. I can hear the motor/blower running, but don't hear the gas turning on.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Jan 04, 2010 | Kenmore 63942 Dryer
No heat in dryer
Hello there Here are some ideas that may help you
- Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
On the back of the dryer near the fan blower housing is a thermal fuse, if this opens up ( no continuity ) the gas burner often quits but the motor will still run. If the thermal fuse is open/bad, always clean, change, adjust the venting system and vent hood first and clean out the dryers air ducts. Sometimes it is a good idea to replace the operating thermostat at the same time.
Thermal fuse parts help link...on blower housing cover, can not be re-set, must be replaced if is open (no continuity between pins).
hope this is very helpful for you
best regards Michael
Dec 23, 2009 | Maytag MDG6400 Atlantis Gas Dryer
Dryer functioning but air not getting hot. this is a Maytag gas dryer
Glow bar igniter, thermal fuse (not all models), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
On the back of the dryer near the fan blower housing is a thermal fuse, if this opens up (no continuity) the gas burner often quits but the motor will still run. If the thermal fuse is open/bad, always clean, change, adjust the venting system and vent hood first and clean out the dryer’s air ducts. Sometimes it is a good idea to replace the operating thermostat at the same time.
Thermal fuse parts help link...on blower housing cover, cannot be re-set, must be replaced if is open (no continuity between pins).
Thank you for contacting Fixya.com
Aug 18, 2009 | Maytag Dryers
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Ge profile harmony gas dryer- no air flow in or out no heat
Replace the blower motor. Check condition of blower wheel and replace if found defective
Jan 16, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
The only sure way is to connect a good motor and see if it runs. In the last year I have replaced a few of those motors and no control boards. All the tests are electrical and the normal failure for that motor is mechanical.
Jun 21, 2008 | GE DPGT750GC Gas Dryer
GE Profile Harmony Gas Dryer DPGT750GC1PL not heating
post your email i will send you the book there are too many things to check via posting here
Mar 09, 2008 | GE Profile Harmony DPGT750EC Electric...
Open Questions:
Dryer is acting up. so, it hasnt been used in about 2 months.  it sat out in a cold garage.  but was back up to 'room temp' when we hooked it up.  the gas line is secure.  the venting is proper.  the dryer's level.   after turning it on, not much has happened.  a faint 'beeping' signal comes out of it every few seconds or so, and signal lasts about 2 secs.  the dryer will tumble and kinda gets a weak luke-warm.  i heard this clicking (blower motor i think) as if it were a rotating clicking noise.  then i heard what sounded like a piece of plastic drop.  then poof! the blower kicked on and the dryer started crankin'! working great.  thought maybe something needed to settle.   note* i did have this dryer on its side while moving it in the back of my pick-up truck.  (which was covered from the elements w/ a cap & laid on soft blankets).* after several uses some serious noises started coming out of it.  a severe clicking rotating plastic thumping, sounded like hard plastics banging, clicking rotating, hard to explain.. i reset the dryer.  now it starts up, and just rotates, blower never kicks on.  doesnt really get hot, back to a weak luke-warm.  (i threw a wet towel in there..nothing, no heat/blower)  nothing going through the vent either.  so..i was thinking about pulling the back off, but figured i'd ask you guys first. also, do you think it's worth it to call in a Sears professional?  costs involved?   yeah man, any help would be appreciated, the thing's out of warranty, and well..i need a working dryer, full household.  laundry piles up!   - thx, Angelo
Feb 28, 2017 | GE DPGT750GC Gas Dryer
GE DPGT750GC Gas Dryer Logo
157 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Are you a GE Dryer Expert? Answer questions, earn points and help others
