Question about Samsung Refrigerators
Hi, I have bought a refrigerator RA21F/RA19F on 2nd Nov 2010. It gets hot on the sides immediately after switching on the power
    Problem Solver:
  • 9 Answers
Get serviced from Authorised Service Centre if the Co. does not replace it with a New one.
Posted on Nov 07, 2010
  • om73392 Dec 30, 2010
    Read the instruction carefull i have also bought the same
Bosch KTR18420 fridge. motor does not run but hums very quietly, radiator cold. if hot water put in cabinet, radiator gets warm
call atechnician to check the start/run capacitor for the compressor for the hum
but what you describe is normal
it takes heat in the cabinet tp evaporate the liguid gas which the compressor then converts back to liquid
in that process the back fins get hot or the back of the fridge gets hot
and that will remain hot until the thermostat switches off the compressor in which case the fins will get cold
Mar 23, 2018 | Bosch Refrigerators
What could be wrong with my 2006 Honda Odyssey. It has no heat, but the engine is running hot. I thought maybe coolant level was low but overflow tank was right at max
Temp gauge runs hot but car makes no heat...... HELP ...
honda-tech.com/honda.../temp-gauge-runs-hot-but-car-makes-no-heat-h...
Mar 28, 2010 - Temp gauge runs hot but car makes no heat. ... Honda-Tech Member ... I figured my theromstat was going bad so I replaced that and it did nothing. ... Any help would be awesome, im losing my patience fast and I have a real big hammer ... This is between the engine and the heater core (under the hood).
Overheating Issue - Honda Odyssey Forum
www.odyclub.com/forums/9-problems.../151854-overheating-issue.html
Nov 13, 2011 - 10 posts - ‎5 authors
I have a 2000 Honda Odyssey with 200K+ on the odometer. ... small head gasket leak,but not enough to see coolant pouring out and no ... 4) Bad thermostat (your new onecould still be bad) - Since your engine is getting hot but you are not getting any heat, ... My coolant was changed at 10yrs/150K miles. Thread: 2007 Odyssey LX - cabin heating issues, no heat ...
Nov 19, 2012
Hot air on driver side vents - Cold on passenger side ...
May 9, 2012
Thread: Overheat while idle
Feb 29, 2012
Thread: No or very low Heat - Wife Is Pissy
Dec 13, 2010
More results from www.odyclub.com
Dec 28, 2015 | 2006 Honda Odyssey
Buck stove 27000 fan runs on low but when goes to high will shut down moved temp gage to front and rewired with harness won't fun on manual either.
Buck Stove ' Hearth.com Forums Home
www.hearth.com/talk/threads/buck-stove.45094/
Jan 6, 2010 - I replaced the blower motor. immediately blower would run for... ... Buck Stove 26000 insert (1982, in the living room fireplace) Has kept ... I throught the same thing so I fired the stove really hot, motor would not run past low setting and ..... I have a pre-1979 Regular Buck 27000 where the thermal disks are ... Anyone burn an insert without the surround?
Jan 8, 2012
Insert Blowers - to use or not?
Jan 3, 2011
Buck Stove Fan Noise
Dec 27, 2010
Any HVAC Techs or Electric Motor Gurus Here?
Nov 22, 2010
More results from www.hearth.com
Nov 08, 2015 | Cars & Trucks
On a Paragon 8145-20 Defrost Timer, I know you land the refrigeration circuit on terminal 4, the heater on terminal 3, but what goes on terminal "X" and terminal "N"
Link below has 8145-20 wiring diagram:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
Terminal N is 2nd wire needed to complete circuit.
In 240V 8145-20, there are two hot wires.
One Hot connects to terminal 1, with jumper to terminal 2.
Second Hot connects to terminal N, and this will power the clock motor and timer.
Terminal X is for temperature or pressure termination switch.
Defrost cycle works like this:
Timer is running but switched OFF.
Refrigeration fan is ON.
Timer switches ON, defrost cycle begins.
Refrigeration fan turns OFF.
Hot gas defrost turns ON.
When temperature-or-pressure limit switch reaches trip point, it switches timer OFF.
Refrigeration fan turns ON again.
Hot gas defrost turns OFF.
Aug 01, 2010 | Paragon 8145-20 Defrost Timer
Bought in Nov 2007 online from circuit City. Has
Change printheads,Issue will not get fixed then its a hardware failure.
Jul 11, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
FRIG. NOT GETTING COLD
Switch off the fridge immediately and allow the compressor to cool off. It is possible that the defrost element is not working, causing a build up of ice in the freezer side. But this should not cause the compressor to overload. The compressor thumping and then stopping can be caused by low voltage supply or a blockage in the refrigerant system
Mar 02, 2009 | Maytag MZD2766GES Side by Side...
My Waring Pro Ice Maker is not cooling. The water pumps through the system but the machine does not freeze. The machine is 18 months old.
JUST SWITCH ON YOUR ICE MAKER AND TOUCH THE COOLING SIDE HOT OR COOL ,
1st . COOLING SIDE IS HOT THE MACHINE COMPRESSOR IS FAULT REPLACE THE COMPRESSOR
2nd. COOLING SIDE IS JUST COOLING CLEAN MACHINE CONDENSER COIL
Jul 19, 2008 | Refrigerators
Top portion of rrefrigerator on refrig side is hot
Check to see if refrigerator door is even with freezer door at top, or is it lower. If lower, the light switch may not be contacted fully. Remove toe plate , bottom front on fridge. Under refrigerator door bottom hinge is a threaded rod. Adjust this to raise door to make level.
Nov 20, 2007 | GE GSS22JFMWW Side by Side Refrigerator
Refrigerators Logo
116 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
