Question about Hotpoint Washing Machines
Hotpoint WMD960 ultima washing maching. Switched on, it will take in water and continue and continue and continue whilst, at the same time it is going rapidly out to the drain. Although it doesnt display any error, it actually says its on the wash cycle although it doesn't heat the water and doesn't wash, instead will carry on filling and draining at the same time for as long as I leave it. This washer in under 6 mths old and have had 3 engineers out from Comet who STILL haven't solved the problem. What to do next before i'm tempted to take a hammer to it. Thanks.
    Genius:
  • 1,672 Answers
I think you need to replace the timer switch, it makes those solenoids to close the DRAiN valves!
Posted on Nov 07, 2010
Testimonial: "Thanks, I'll be putting your suggestion to the next so called "expert" engineer."
What causes a hotpoint ultima wmd960 noisy spin ?
Tub seal leaking letting water get to tub bearings need shaft and bearings replaced.
Aug 31, 2014 | Washing Machines
Our hotpoint ultima wmd960 washing machine timer stops with one minute remaining, but continues the wash cycle on 'a loop', and does not pump the water from the drum. We turn it off and then put it...
Have a look at this and check if your pump is full of things lost from pockets:
How to remove and clean your Hotpoint washing machine pump filter
However, I suspect the problem is really that something is causing the controller to (falsely) register an unbalanced load, and continually running the wash to try and redistribute the items.
Sorry I'm not sure what the fix is for that - could be motor tacho, or could be controller itself.
Jan 30, 2018 | Hotpoint Washing Machines
Hi my hotpoint ultima wmd960 of 2 half years,when i put a wash on it starts and fills up for about 3 mins later it comes up :no water, check supply, then starts ti drain water away ,then fills up again,so...
Please check your inlet water hose for any clogging that may be stopping the proper flow. some machines are programmed to get filled in particular given interval of time. they need proper pressure to properly work. Remove the hose and clean the wire mesh filter.
Oct 02, 2017 | Washing Machines
The only problem is when program starts it does not take any water and after few minutes it starts indicate error code F1. Hotpoint Washing Machine 8KG WMD960 Ultima 1600
  • F1 - The level of required dryness has not been reached within the time period. Check that the correct programme has been selected
  • or
      • The thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing.
May 17, 2011 | Washing Machines
Brown sludgy marks and particles on clothes.
fill the tub with only water! use pinesol and bleach! half a gallon of each run through wash cycle 3 times before ever letting it spin out! then complete all cycles that should do it! if not them you need to remove and clean under tub and re install
Jan 13, 2010 | Hotpoint Washing Machines
I need a user manual for hotpoint washing machine wmd960 (8kg ultima)
go to hotpoint website, then support and you can download all manuals there
Aug 27, 2009 | Washing Machines
Washing Machines Logo
499 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
