Question about ASUS P5QL PRO Motherboard
Hi i my computer suddenly started to shutdown and turn on again after a fev seconds.some times it goes in to windows but soon after crashes.it has wrked for over a year and this was a home built computer. CPU temp is 36 MB temp is 39 Using intel core 2 quad cpu Q9400 2.66GHz Asus P5QL PRO motherboard Ati radeon 1650 No brand 2gb ddr2 ram 320gb sata hard disk 100gb ide hard disk Micronics 500w powersupply 64 windows 7
    Genius:
  • 1,672 Answers
Try these....
Overheating problem in your PROCESSOR!
Check the temp in your BiOS and the setting of your processor!
Check also the power supply and upgrade it to hifgher wattage!
Clean your processor HEAT SiNK, dust and dirt might have acumulated!
Check the HEAT sink position, if its flatly fitted on top of procie, and scrape the old silicon paste between ur proci and heat sink and put a NEW ONE!
Encountered this kind of prob.. the prob is in the PSU unit(Power Supply Unit)!
These might help you!
Posted on Nov 07, 2010
  • 3 more comments
  • f_san_h Nov 07, 2010
    pretty sure it isnt ovr heating because i have encountered overheating with third low quality heatsink
    temp in bios is cpu 36c,mb 39c and bios settings are at default
    heatsink was cleaned and instaled with new paste
    so i'll check the powersupply
    also it doesnt shud down,jst turns off and turn on
    btw im using the comp now and i hav seen on a foum that this cud be memory prob
    also now the comp desnt boot with the memory installed in the first slot but works in all other slots so cant use dual mode which is very annoying
    thanks and appreciate any help
    and how much watt powersupply would you recommend
  • Bayyagg
    Bayyagg Nov 07, 2010
    Install a new 600 wattage!
    hei do u think the ram slot is broken,have been using that slot since i built the comp n it mulfunctioned after the crashes n also bios settings are lost after the crash n i hav to go into bios before i can go in to windows
  • Bayyagg
    If that is a mem probs, it won't start at all, and there'll be a ram sound "BuZZ"!
    Bios setting comes out in the start, means new hardware have been detected in mobo, HD, Mem, and PCI cards!
    Have u tried another mem card w/ lower capacity?
    ram slot don't just get break or somet'in, it depends of how u install the cards!
    Try cleaning the contact point of ur mem card by using rubber pencil eraser!
WidwsVista hw to exit from safe mode
If your computer always starts to safe mode, go through the following steps:
· press <windows kwy> + <R>
· type MSCONFIG then press enter. This will open the System Configuration window.
· click on the BOOT tab and make sure nothing is checked/ticked in all the boxes you see.
· click OK button
· check/tick the box that says "Don't show this message again..."
· press RESTART COMPUTER button.
Your computer should boot to normal mode.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Feb 22, 2011 | Computers & Internet
My comouter first blanked out and opened and closed windows/programs and then went back to normal. It then did it again for quite a while until I finally did a hard shutdown. When I turned it on it...
Errors on the hard drive or corrupt files/programmes are the usual cause of that sort of erratic behaviour.
When you get it back start it up and as soon as you get into Windows, run CHKDSK/F straight away, the computer then will shut down, or you must shut it down. As you reboot it, it will be in DOS mode and CHKDSK/F will run and try and fix the errors.
If that is not succesful, start the laptop up with your Windows System Disk and choose repair system.
Hopefully that will solve your problem. If not, you may need to format your drive and start again with a new system.
Nov 20, 2010 | Acer Computers & Internet
Improper Shutdown Message
1. Disconnect the power cord from back of printer ( while printer is powered on )
2. wait for 10 seconds
3. hold and press the Power button and connect the Power Cord.
4. Release the Power button after 3 seconds
5. Follow the Instructions on the printer screen.
Later try to shutdown it, it should not give the message again
Jun 16, 2010 | HP Photosmart C6180 All-In-One InkJet...
I have a compaq presario laptop with windows vista, 2 weeks ago it was working fine and now it loads up fine but crashes everytime i try something, what can i do appart from wiping off and starting again
Hi. I think the best to resolve this issue is to restore again your system to its factory settings or reformat again your system, then after doing it you should disable the automatic updates from the control panel so that you're system would not automatically update itself, because most of the time Vista crashes because the updates it made and sometimes you tend to shutdown your system without finishing the updates from microsoft then it would cause that crash the next time you open up your system. To disable the automatic updates just go to control then click classic view on the upper left side then look for the Windows Update icon on the control panel, and from ther just turn off the automatic updates. I would also suggest that if you to maintain the automatic update you should make sure that the updates are already finish before you shutdown your computer or you could change the schedule of the updates depends on what date have you chosen. Hope This Helps
Jun 03, 2010 | Compaq Presario 700 470024-192 Notebook
Compaq nc6120 keeps crashing/powers off immediatetly
i guse its cause by some virus only .... best solution for this take all the data backup full format the c drive and reinstall the os
Dec 07, 2009 | Compaq NC6120 P-M 730 XGA Notebook
How to rebot acer 4220 laptop
usually holding down the power button for a long time will force a reboot. I am not sure if that is what your asking
Dec 05, 2008 | Computers & Internet
E153fp goes dark into power save mode after Windows start up
may be your power saving option have small time .
check in control panel power option check power shemes.set it to 20 minutes.
Nov 27, 2008 | Dell E153FP 15" LCD Monitor
System crashes frequently after got the board repaired
hi dude,
          better format d old windows and install new windows...my frend had a similar shut down problem, by formatting and installing new windows, solved it...dis can solve ur problem
                                                good luck,
                                                trendsetter
Jul 03, 2008 | Intel D845GVSR Motherboard
For solving blue screen error
HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
Description
Windows XP may not start and the following error message may appear on a blue screen:
This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
Solution
If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
use the link to know how to use recovery option with hp laptop
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&dlc=en&product=18703&docname=c00608578#
_____________________________________________________
Thanks and Regard
dilipbagdi
Technical Associate
May 18, 2008 | HP Pavilion dv9000z Notebook
Open Questions:
ASUS P5QL PRO Motherboard Logo
155 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
