Question about Car Audio & Video
I have a 99 intreped im trieng to put in a radio
    President:
  • 1,851 Answers
Remove the old factory radio - toss it out the window. Install a newer radio using an adapter. Replace speakers as needed - enjoy your new radio.
Posted on Nov 07, 2010
How to replace factory radio in a 99 s70 volvo with a new model store bought radio
I imagine that you installed the code in the radio after installing it. Check that you picked up the correct power wire (accessory [power )
Aug 01, 2014 | 1999 Volvo S70
Im trying to wire a road king mike to corba 29,i got key up but no auido,wich wires do i change
you would have to look at the wires in the mic also. 99% are wired for cobras./galaxy's etc..
just follow the audio wire and put on pin 2.. grounds on pin 1 tx on pin 3 rx on pin 4
Feb 20, 2011 | Radio Communications
Put a ignician in my 2000 intreped and now it is locked in securety and wont start
You need to first disarm the alarm which is the Light Green/Orange wire located in the drivers door harness, connect this wire to ground trough a 680 Ohms resistor, (you can find this resistor at your local radio shack, ask for it and they will help you up). So the best way get a piece of wire connect the resistor at one of the ends, get another piece of wire and connect to the other side of the resistor.
Now connect one of the wires to the Light Green/Orange wire of the car and the other wires just touch ground and you're done, try to turn the engine on.
Nov 25, 2010 | Chrysler Vehicle Parts & Accessories
I have a dodge intreped 2002 2.7 v6 im trying to remove trans
Remove both drive axles first. Remove started.. remove transmission blots and torque convertor bolts. remove engine mounts. Support the engine with another jack to keep it level. 2 or 3 hours to do by yourselt...Good Luck!!!
Nov 03, 2010 | 2002 Dodge Intrepid
99 sunfire radio reset code
check out radio-code.com
Apr 18, 2010 | 1999 Pontiac Sunfire
I have a 1999 intreped and sometimes it wont start after i drove it for a while, and it will cut off with out any warning while im driving
Check the fuel pump & pressure. The pressure should be 35 psi & shouldn't drop with the key off. If it does, replace the pump.
Jun 24, 2009 | 1999 Dodge Intrepid
I have a 1999 dodge intreped. All windows excpect
I HAVE A 98 INTREPID AND I WENT TO A JUNK YARD AND JUST PULLED THE PASSENGER SWITCH OUT OF THE DOOR AND UNHOOK.WIRES....VERY EASY....PUT IN YOUR CAR AND THAT SHOULD WORK...ITS PRYS OUT OR PULL OUT WITH PLYERS....THESE SWITCHES CONNECT LIKE A CIRCUIT AND IF PASSENGER DOOR SWITCH IS BAD IT WILL NOT WORK FROM DRIVERS OR PASSENGER SIDE...98 TO 2000 ARE ALL THE SAME PARTS....HOPE THIS HELPS.....
Mar 05, 2009 | 1999 Dodge Intrepid
99 ford expedition radio problem
This is not a fuse problem, it is a burnt out display backlight bulb, you have to pull the radio out of the dash and remove the top cover of the radio, you will see a tiny bulb socket, twist it out, replace that little bulb.
Oct 13, 2008 | 1999 Ford Expedition
Car Audio & Video Logo
21 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
